2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Honestly, it might be slightly larger, but there is nothing that's anywhere close to the snout on my M62 (and I have an Automatic as well). I need a picture to see what exactly you're talking about... I have a meeting in 10 minutes so I'll be away from my desk for 30 mins or so, FYI.
Also... My oh my... You're still a 2.4 (the displacement of your engine isn't changing at all...) and yes, the LSJ throttle body is larger than the LE5 TB to allow for more air to flow.
Hi guys this topic is great
I need to wire the 2.5 tmap
for the map sensor, it's not a problem
but for the IAT (from mAF) to the tmap, I read all this tread and didn't find how to do it
hope you could help me
thanks
thanks
If you're looking to do the IAT2 conversion I had it in my thread in the LAP section.
now I need to rescale de map for the 2.5 bar, and the 60 lbs injectors
otherwise someone as this base calibration file to help me
one should be tan, the other brown. if you have two tan wires, then they will have stripes. I cant recall specifics on the colors though...best to check the OP's diagram
nah its alot easier then it sounds, + I can run the 2.5bar instead of stock and read Ia2's
One thing I have been thinking about is We are removing the ground from the MAF, so dont we need to replace the it, with a new ground in order for the MAF to work?
Last edited by EcoTecDriver; Jul 19, 2010 at 11:30 PM. Reason: Automerged Doublepost
cuz you don't cut the ground, you cut the low reference and ia2 signal wires.
