2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Old Apr 7, 2009 | 09:19 PM
  #201
bulls'ss's Avatar
well i have all the things you need and also a wideband kit, boost gauge, pillar pod for 2 gauges, heat exchanger and belt
oh also have an lsj throttle body
Old Apr 30, 2009 | 01:52 AM
  #202
slobalt08's Avatar
How to video?
Old Aug 18, 2009 | 08:05 PM
  #203
thesteed46's Avatar
is it possible to do this and buy the ottp stage one kit and use the pretuned pcm??
Old Aug 18, 2009 | 08:17 PM
  #204
HunterKiller89's Avatar
no. its a different ECM. You can call OTTP and see if they will send you a 2.4 PCM with the tune on it though....
Old Aug 18, 2009 | 08:23 PM
  #205
thesteed46's Avatar
oh ok i wasnt sure. thanks
Old Aug 18, 2009 | 10:31 PM
  #206
Gene Culley's Avatar
Talking
Get a custom tune. It is worth the money.
Old Sep 28, 2009 | 11:58 AM
  #207
tcjb87's Avatar
Thumbs up supercharger for the 2.2
will this same set up work for the 2.2 as far as the parts go
Old Sep 28, 2009 | 03:14 PM
  #208
yes.
Old Sep 29, 2009 | 06:01 PM
  #209
Illini_06SS's Avatar
I have a question. I noticed the 1/4" hose lines, 1/8 NPT drill tap, and barb fittings being used to install the Cobra H/E. Did you tap into the end tanks of the H/E to install those bleeder lines? If so, how did you prevent fluid from flowing through those lines instead of through the H/E? Is it absolutely necessary to install those bleeders or can I just do the standard bleeding of the H/E in a bucket of coolant? What is the normal method of plumbing a Cobra H/E on the Cobalts with a surge tank instead of the stock filler neck?
Old Oct 16, 2009 | 10:21 PM
  #210
G5 Prospect's Avatar
So the stock heat exchanger off of a ss sc work witht this setup?
Old Oct 18, 2009 | 01:27 AM
  #211
Beck's Avatar
yup as long as you can fit it.
yep right into the end tanks. the bleeder lines ensure air escapes the heat exchanger. if bled properly you dont really need to worry about these, however if you're using a surge tank from a cobalt, you might as well utilize them since the surge tank has the bleeder inlet. a small amount of fluid will always pass through the bleeders, but simply due to the amount of fluid circulating most of it passes through the heat exchangers as it should.
btw im back if you guys need any assistance, pm me or ask away here
Old Oct 18, 2009 | 11:37 PM
  #212
lol. whered you go?
ive been handling all the swaps since you left. Pk91 disappeared too
Old Oct 18, 2009 | 11:43 PM
  #213
Beck's Avatar
was ******* around with a toyota for a while... bad news lol.
what sort of tuning do they have for the 2.2 now?
Old Oct 18, 2009 | 11:55 PM
  #214
blackbolt89's Avatar
awesome how to
+rep!
Old Oct 22, 2009 | 02:59 PM
  #215
wilson79's Avatar
Old Oct 23, 2009 | 01:33 AM
  #216
Trifecta. Its effectively Vince (and whoever else is a vendor of him can do tunes as well, though most tunes are received directly from Vince) sending a canned tune, then you send him back a data log (using hardware/software he provides), then he edits the canned tune to be specific to your vehicle, so its like any other custom tune sent through email for HPT on this forum.
He plans on releasing DIY tuning software in the future, but he's a busy guy, and doesn't have a specific release date at all. Im not sure how much else he wants me to share, since he hasnt made any of this info public yet.
Old Oct 23, 2009 | 02:38 AM
  #217
Beck's Avatar
so HPT still isnt compatible with the 2.2?
Old Oct 24, 2009 | 04:13 AM
  #218
they are with '07 and up i think? at least the LAP 2.2 is.
they announced though that they will never release tuning software for the '05-'06 2.2.
Old Oct 31, 2009 | 07:08 PM
  #219
cobalt123's Avatar
^i second that, ive heard the same thing
Old Nov 1, 2009 | 05:10 PM
  #220
Beck's Avatar
gotcha. we'll just have to see what im going to do with this 07 2.2 i just picked up then haha
Old Nov 1, 2009 | 09:31 PM
  #221
Jimmys2007CobaltSS/C's Avatar
well interesting driving home 3 weeks ago my car shutsoff not boost, battery light comes on i mean everything comes on and my idler pulley snapped off!!!!!, Any ideas guys? hard to fixed?? Pm me with tips
Old Nov 1, 2009 | 09:45 PM
  #222
Zdeuce4's Avatar
wtf that happened to two tx guys too...
Old Nov 1, 2009 | 11:32 PM
  #223
buy my connecting rods build your engine up
Old Nov 3, 2009 | 08:43 PM
  #224
cobaltss86's Avatar
me and dragon? i just got internet turned back on
Old Nov 5, 2009 | 06:03 AM
  #225
SRodSS007's Avatar
i got tired of trying to S/C my 2-4... sooo i traded it for a T/C instead lolz
