2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Old Dec 14, 2012 | 10:00 PM
  #301
jfin's Avatar
amazing man may i ask a total price range
Old Dec 21, 2012 | 11:39 AM
  #302
pjk91's Avatar
depends on if you get your parts new, used, rigged or pretty, tune yourself or someone else tunes. 750-1500+ is a reasonable range.
Old Mar 4, 2013 | 08:38 AM
  #303
Tjolley's Avatar
Think this needs to be bumped up..lol
Old Apr 15, 2013 | 10:56 AM
  #304
brewster's Avatar
im going from the 2.0ss/sc pulling the engine out and putting the 2.4 in do you know if the exhaust will bolt up?
and does anyone know of a tuner in the richmond va area?
Old Apr 16, 2013 | 12:16 AM
  #305
Beck's Avatar
Should bolt up just fine.
Old Aug 20, 2013 | 11:11 AM
  #306
Chaos_Six's Avatar
I can use the 2.5 bar sensor right? I don't need to spend 70 bucks on the 2 bar sensor that zzp sells for the LE5?
Old Aug 20, 2013 | 11:13 AM
  #307
drumrush's Avatar
It'll take a pigtail and rewiring but yes
Old Aug 20, 2013 | 11:15 AM
  #308
Twoozofjuice's Avatar
It'd actually be better lol. Well atleast it was for me idk what the rest do. I rewired pigtail in and then took the iat wire from the maf and wired it into the iat2 wire from the 2.5 so I can now monitor iat2 temps
Old Aug 20, 2013 | 11:19 PM
  #309
Chaos_Six's Avatar
Yay! 70 bucks saved :P
Old Sep 1, 2013 | 11:07 AM
  #310
Chaos_Six's Avatar
Because I can't find it anywhere, how far does the alternator have to be spaced out? 1/2 inch?
Old Sep 2, 2013 | 01:05 AM
  #311
Jacob4ta's Avatar
You shouldn't have to space the alternator at all? I didn't have to anyway. We just removed it, installed some parts and reinstalled it.
Old Sep 2, 2013 | 02:37 PM
  #312
Beck's Avatar
depends on the pulley set up you're using. If using the oem LSJ pulley setup the alternator is spaced by the bracket that holds the tensioner pulley. I believe its about 1/2" space but i cant confirm that.
Old Sep 3, 2013 | 01:47 PM
  #313
Chaos_Six's Avatar
Another noob question. -_- Where did you get your injector harness? I got one from ZZP and it's for the LSJ...
Old Sep 3, 2013 | 11:58 PM
  #314
Beck's Avatar
make your own, Buy the injector pigtails and wire them in to your oem harness. There's a few other things you'll have to wire in like the MAP sensor and also the throttle body pigtails unless you've got a harness for that
Old Sep 4, 2013 | 12:16 AM
  #315
Chaos_Six's Avatar
Okay. Yeah I have the throttle body harness. As far as an LSJ MAP sensor and pigtail, do you have extras of them by any chance? I asked Mongo, he wasn't sure.
Old Sep 4, 2013 | 07:58 PM
  #316
Beck's Avatar
nope i dont have an extra one, but i believe i posted the part numbers in the original post.
Old Sep 4, 2014 | 08:03 PM
  #317
Glum2.4l's Avatar
New to site have questions
Is there anyone still around that can answer questions to this build
Old Sep 4, 2014 | 11:43 PM
  #318
andrewcarr1993's Avatar
Yeah plenty.
Old Sep 5, 2014 | 03:53 AM
  #319
Glum2.4l's Avatar
If I'm using the intercooler pump off the lsj do I still need to get the bracket or is there one on the lsj I can use where can I find some good affordable injectors and harness also will the stock HE on the lsj work if so how would I plumb it and lastly for now does any1 have a picture of the custom idler pully and it mounted on the car Ty
Old Oct 19, 2014 | 10:31 PM
  #320
sandman's Avatar
For IC pump you can use the stock lsj brackets or you can buy zzp's little bracket and mount it pretty much anywhere.
stock H/e works great use it.
ask around for injectors someone is always selling em
Old Nov 2, 2016 | 02:22 PM
  #321
Dashernex's Avatar
What supercharger did you use and cost
Beck how much did this build cost what's the finished products power output and what supercharger did you get.
Old May 1, 2017 | 12:19 PM
  #322
Henry3959's Avatar
I saw someone did this to an 08 Sport... Does the ABS get in the way of a CAI?
Researching I have found some. ZZP said it took a special CAI which is why I asked.
Old Jun 18, 2017 | 11:10 PM
  #323
Henry3959's Avatar
The list of items and work necessary to do this that isn't in the build is too long to list. If your interested in putting a SC on a 2.2 or 2.4, contact me.
Old Jun 23, 2018 | 01:49 PM
  #324
OhSixBalt's Avatar
Hi there - I was reading the parts list for the LSJ supercharger swap - one item is a bit confusing:
Stage 2 Belt (Part# 12597993; requires one rib be cut off)
Ok can someone show me what is meant by cutting one rib off the belt?
Old Jun 23, 2018 | 03:07 PM
  #325
Henry3959's Avatar
The OEM belt is a 6 rib belt. The LE5 has 5 rib accessory pulleys. You can either source a 6 rib balancer, AC Compressor and alternator or cut one of the ribs off to fit the OEM accessory pulleys. A new utility knife can easily cut an entire rib off if done safely.
