Interior: How TO: Gauge colors
dude those are awesome man, i was just wondering if it wasn't too much trouble, can i see a day shot of your l.e.d. strip showing against your gauge clusters, cuz the other pic was a lil blurry and dark, so i kinda have no idea what i'm doing haha. thanks cobaltic!
Ive done the same mod but used different leds. I found these at a local Autozone only 12 bucks there. They work really well, light up the white the gauges and not the entire area. Ill get pics later on tonite. Heres a link to them on amazon.
http://www.amazon.com/Type-LM02003-6.../dp/B000CRKAJW
hey this is a little off topic but i saw that the person that started this post has a tv in his car i was wondering if you have to keep your stock head unit cause i want to put my tv in ther on friday when i pick mine up form the dealer its a 07
nah, you could leave these on for like a year and you'd still be fine. l.e.d.'s take out very little power from the battery.
Last edited by streetracinazian; Apr 12, 2007 at 04:09 AM. Reason: Automerged Doublepost
to tap into the cig wire i just spliced into the wire that was attached and used the wire that came with the LED's if you want you canthrow a fuse onit but it's not gonna draw that much power and also the cig liter is on a fuse already
-drew
-drew
Ok so alot of people have asked me how i changed the color of my gauges.. and her is how i did it:
your need:
ultra thin LED strip (can be found at pep boys)
electrical tape
a switch
wire splicers
What your going to do is, on the back side of the steering wheel there is a flat part where your going to mount the LED strip to.. measure that and then cut the Led strip down remeber to only cut off the side that is not attach to the wires..
then clean the surface with rubbing alcohol or windex and let it dry.. position it so that the leds will glow twords the gauges and up into the cluster.
run the wires back behind the steering colom and down under the kick pannel..attach the (+) wire to any 12v source.. i used the second cigg litter in the center consol.. you can also use a fuse tap and attach that to a 12v fuse in your fuse box.. attach the (-) to a grounding source.. you can place a switch anywhere in your car i placed it just under the radio next to the cigg litter... here are some pics of where it is located and what it should look like
this is where the LED's are located
this is my first "how to" so if anything seems confuseing just send me a PM and I'll help you along
-drew
your need:
electrical tape
a switch
wire splicers
-drew
Sl0wbaltSS
Nov 21, 2018 11:11 PM
