Interior: How TO: Gauge colors
Old Dec 31, 2006 | 02:42 AM
c0baltic's Avatar
these are what the ultra thin LED's look like.. this was the day i put them in
-drew
Old Jan 14, 2007 | 12:27 AM
streetracinazian's Avatar
dude those are awesome man, i was just wondering if it wasn't too much trouble, can i see a day shot of your l.e.d. strip showing against your gauge clusters, cuz the other pic was a lil blurry and dark, so i kinda have no idea what i'm doing haha. thanks cobaltic!
Old Jan 15, 2007 | 03:45 PM
c0baltic's Avatar
no problem... during the day the leds are not that bright so it really cant be seen but i'll take a pic of the strip so you can see better where it is located
-drew
Old Jan 15, 2007 | 03:52 PM
TCarter's Avatar
thats mine.
Old Feb 4, 2007 | 01:38 PM
cobaltic, thank you for the great idea, props to you on this man!
here are mine:
Before
and what they are now
Old Feb 4, 2007 | 01:59 PM
Xavipheus's Avatar
that just seems like a little too much
Old Feb 4, 2007 | 02:01 PM
Psykostevo's Avatar
Looks cool. Did you put the SS seats in your LS?
Old Feb 4, 2007 | 02:27 PM
=) i like it alot, it kinda livens up the interior!
Old Feb 4, 2007 | 10:32 PM
c0baltic's Avatar
looks awesome man... good job glad i can be of some help
-drew
Old Feb 7, 2007 | 10:41 PM
NP05Cobalt's Avatar
that ultra thin stuff is that the strip that comes in like 10 or 15 ft pieces? if it is can you cut those down? i was going to get it but i didnt know if i could cut it
Old Feb 7, 2007 | 11:42 PM
  #36
dude, no not the l.e.d. strips, those are neon strings. 15feet of l.e.d.s would be long and awesome haha
Old Feb 8, 2007 | 12:06 AM
  #37
spencer's Avatar
i think this might be my next mod. you think it would look sick w/ red lights though?
Old Feb 8, 2007 | 12:21 AM
  #38
i wondered the same thing man, i was thinking of purchasing the red l.e.d.'s and trying it for gigglez.
Old Feb 8, 2007 | 07:29 AM
  #39
halo's Avatar
Ive done the same mod but used different leds. I found these at a local Autozone only 12 bucks there. They work really well, light up the white the gauges and not the entire area. Ill get pics later on tonite. Heres a link to them on amazon.
http://www.amazon.com/Type-LM02003-6.../dp/B000CRKAJW
Old Feb 16, 2007 | 08:57 PM
  #40
IanWilson2007's Avatar
hey this is a little off topic but i saw that the person that started this post has a tv in his car i was wondering if you have to keep your stock head unit cause i want to put my tv in ther on friday when i pick mine up form the dealer its a 07
Old Feb 17, 2007 | 12:13 AM
  #41
c0baltic's Avatar
it's an indash dvd player with am/fm/cd/dvd/mp3... well it was till it all got stolen a few days ago but i'll have a newer one this week.. thank you insureance
-drew
Old Apr 11, 2007 | 10:35 PM
  #42
utibalt's Avatar
quick question, if i tap into the cig lighter and forget to turn off the switch to turn the lights off after i turn ignition off. will the lights go out and not drain battery?
Old Apr 12, 2007 | 04:08 AM
  #43
nah, you could leave these on for like a year and you'd still be fine. l.e.d.'s take out very little power from the battery.
Last edited by streetracinazian; Apr 12, 2007 at 04:09 AM. Reason: Automerged Doublepost
Old Apr 13, 2007 | 12:50 PM
  #44
utibalt's Avatar
What size wire did you use?
Old Apr 13, 2007 | 06:47 PM
  #45
c0baltic's Avatar
to tap into the cig wire i just spliced into the wire that was attached and used the wire that came with the LED's if you want you canthrow a fuse onit but it's not gonna draw that much power and also the cig liter is on a fuse already
-drew
Old Nov 22, 2007 | 11:59 PM
  #46
cobaltLS4dr's Avatar
Originally Posted by c0baltic
Ok so alot of people have asked me how i changed the color of my gauges.. and her is how i did it:
your need:
ultra thin LED strip (can be found at pep boys)
electrical tape
a switch
wire splicers
What your going to do is, on the back side of the steering wheel there is a flat part where your going to mount the LED strip to.. measure that and then cut the Led strip down remeber to only cut off the side that is not attach to the wires..
then clean the surface with rubbing alcohol or windex and let it dry.. position it so that the leds will glow twords the gauges and up into the cluster.
run the wires back behind the steering colom and down under the kick pannel..attach the (+) wire to any 12v source.. i used the second cigg litter in the center consol.. you can also use a fuse tap and attach that to a 12v fuse in your fuse box.. attach the (-) to a grounding source.. you can place a switch anywhere in your car i placed it just under the radio next to the cigg litter... here are some pics of where it is located and what it should look like
this is where the LED's are located
this is my first "how to" so if anything seems confuseing just send me a PM and I'll help you along
-drew
just wondering how you managed to keep the LED strip attached under your radio. i have one there right above the 1st cig lighter ad it keeps falling off
Old Nov 23, 2007 | 12:11 AM
  #47
BigTizzle903's Avatar
i like it. i jus wonder how it wood look with black faced gauges
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
