Electrical: How to install an Auto Meter Voltmeter
This is the next thing i wanna do to my cobalt but the problem is how do i wire it to a source on where i cut on the ignition it starts up and lights up instead of haveing to cut them on manually, and if i dont have a pillar pod just yet here would be a good place to mount them?
So say you are reading like 14 volts and turn the car off. Your needle stays at around 14-13.5? t when you start back up it jumps back to running voltage? Another thing, I cant get the illumination to work correctly
My needle will stay at whatever voltage it was at when I shut down. When I restart, since it's an electric full-sweep, it goes through a startup sequence, which means, it does a full sweep, and back to zero, then to the current reading.
What brand of gauge do you have?
Cobalt series shortsweep. mine doesnt have the harness to plug in the back. just the terminals. one for lighting, one for lighting ground, one for power, and one for power ground, i just wont the illumination to kick on with ignition and turn off with ignition off, dont really care if it dims or not.
well the dimmer wire you tap into is gray correct? is it coming directly off dimmer knob(2 wires) or is it in that bunch of wires that the 2 dimmer wires come off of? cuz i tapped the gry wire in that bunch of wires and it didnt do anything
Yes, it's gray. It comes right off the dimmer knob, correct. You have to have interior lights on for it to work, I'm assuming you did that, though...
Do you have a test light?
Hmm...very odd. Mine was gray. Maybe it's not coming directly off of the knob, I can't remember, since it's been a while...but there's one that is part of the dash lighting, and the dimmer controls its voltage.
got any idea of what i could do to figure it out? could i tapp into just one of the 2 wires going to the dimmer? i dont wanna start hacking apart wires though lol. already have to reconnect the gray one since it didnt work
The gauge I used was an Auto Meter Cobalt-series Full-sweep Voltmeter. PN 6191
Not sure on the gauge pillar PN. You can find them on this site in the classifieds all the time.
Delta coupe
Sep 30, 2015 08:11 AM
