Drivetrain: How to Install Axles and CAB's (56k time to upgrade)
Old Nov 8, 2008 | 10:54 AM
  #76
Tennpenn83's Avatar
ss33.. how are the cab's holding up? i've read a few threads on how they have failed..
Old Nov 8, 2008 | 12:29 PM
  #77
ItalianJoe1's Avatar
Originally Posted by SS33
click, boom
Lawls
If you are looking, I have come up with a much better solution to the poly CAB issue. I have the prototypes in my car right now, and since I seem to be having good results with no issues, i'm thinking of releasing a few sets to other people as needed. They are a little more money, but they work better, will last longer, and are servicable, meaning you don't have to replace the whole ******* thing when it does eventually wear out.
PM me for more info.
Last edited by ItalianJoe1; Nov 8, 2008 at 12:29 PM. Reason: Automerged Doublepost
Old Nov 22, 2008 | 03:05 PM
  #78
SS33's Avatar
Originally Posted by ItalianJoe1
Lawls
I'm on my 2nd set, but I thinkl I replaced my first set due to the scares everyone else was experiencing, both of my sets look to be holding up fine with only minimal gap at the inner sleeve
Italian Joe
I am interested in hearing more about your set-up, hit me up with a PM or reply here please
Old Nov 22, 2008 | 05:52 PM
  #79
Italian Joe
I'll PM you some pics and details later.
Old Nov 22, 2008 | 06:26 PM
  #80
SSdan's Avatar
Me too me too!
Old Nov 22, 2008 | 06:30 PM
  #81
Originally Posted by SSdan
Me too me too!
Ok
Gimme about an hour, i'll get on it.
Old Nov 24, 2008 | 08:43 PM
  #82
SS33's Avatar
Just got the pics, I'm blown away,, those look amazing Joe
Old Nov 24, 2008 | 09:33 PM
  #83
Edubs's Avatar
Joe, when you get a chance...
Thanks for the PM Joe. They look great! Definitely interested in production information. I could potentially work this into my winter project...
Old Mar 13, 2009 | 03:08 AM
  #84
RooTBeeR's Avatar
saved for later
Old Mar 13, 2009 | 08:23 PM
  #85
JonyyB's Avatar
Site Founder
badass
Old Mar 28, 2009 | 12:49 PM
  #86
SS33's Avatar
Originally Posted by JonyyB
badass
O man, I saw that you commented, and I thought maybe, just maybe I had my first Sticky, lolz
It's okay,,, I still love you for being my twin,,, even in winter mode
Old Jun 3, 2009 | 09:24 PM
  #87
valentino0214's Avatar
how do u get the trans axle out of the center shaft???? the snap rings??? im so lost trying to do this
Old Jun 4, 2009 | 02:22 AM
  #88
There aren't any snap rings, it's just tight. Slide hammer?
Old Jun 4, 2009 | 01:53 PM
  #89
i found 2 snap wrings on it... yeah been using the slide hammer no luck
Old Jun 8, 2009 | 08:20 PM
  #90
SS33's Avatar
I had a hard time separating mine too. But those snap rings have nothing to do with holding them together. I found this out after spending hours trying to get them off.
Just get the old axle clamped in a solid vice and get a good grip on the intermediate shaft and pull like hell
Old Jun 11, 2009 | 06:29 PM
  #91
i got it out... it was stuck in there cuz of the weather... need a air tool to take it out
Old Sep 30, 2010 | 04:09 PM
  #92
CobaltVenomSS's Avatar
is this really hard to do??? my friends kinda have experience but nt alot...
Old Feb 25, 2012 | 01:29 PM
  #93
tanelk's Avatar
Is the axle suppose to just pull out?? It wont come out
Old Feb 25, 2012 | 01:48 PM
  #94
SS33's Avatar
Not sure exactly which point you are at. But as long as you have removed the obstructions I listed, there is nothing mechanically holding the axle in at the inboard side, just the tight fit of the splines.
Old Feb 25, 2012 | 02:29 PM
  #95
Dart_SI's Avatar
A crowbar makes yanking the axles cake. That's what I did when I had to change my friends clutch. Just make sure your careful and use rags for padding.
Old Feb 25, 2012 | 03:23 PM
  #96
tanelk's Avatar
The axle wont come out the shaft, I took out the shaft with the axle on it n it wont come out
Old Feb 25, 2012 | 04:10 PM
  #97
tanelk's Avatar
Bump for help, the passanger side axle doesn't want to come out the shaft
Old Feb 25, 2012 | 06:00 PM
  #98
I've had them so rusted together that you almost have to destroy them to get them apart. Best bet is to take a hammer to it and try to beat the axle out of the intermediate shaft. Put some grease on the splines when you re-install so you don't have that issue in the future, they are dry as a bone from the factory.
Old Feb 25, 2012 | 06:08 PM
  #99
tanelk's Avatar
I have been beating the **** out of it for 2 hours. It just wont budge. I'm thinking of tieing a chain to the bracket on the shaft and another chain on the axle and tieing both ends to separate cars and driving off
Old Feb 27, 2012 | 05:34 AM
  #100
tanelk's Avatar
I don't think I have the driver side axle in right. When I started refilling the tranny with fluid it started to leak out from under the axle. There's a gap between the tranny and where the end of the axle steps up in diameter. Is tye step up in diameter suppose to be flush against the tranny?????
