Drivetrain: How to Install Axles and CAB's (56k time to upgrade)
Old 02-27-2012, 10:26 AM
  #101
ItalianJoe1's Avatar
Originally Posted by tanelk
I have been beating the **** out of it for 2 hours. It just wont budge. I'm thinking of tieing a chain to the bracket on the shaft and another chain on the axle and tieing both ends to separate cars and driving off
You would just destroy the carrier bearing doing that, or the axle, or both.
Old 02-27-2012, 10:36 AM
  #102
I don't think I have the driver side axle in right. When I started refilling the tranny with fluid it started to leak out from under the axle. There's a gap between the tranny and where the end of the axle steps up in diameter. Is tye step up in diameter suppose to be flush against the tranny?????
It shouldn't leak, so it's probably not in all the way. If you can see the shiny spline part of the axle it isn't in far enough. It should pop in to place, there's a spring clip on the end of the inner spline that keeps the axle snug in the diff.
Old 04-02-2012, 01:41 AM
  #103
conerboner's Avatar
nice write up! didn't read through all of it just the first page but do you know the torque specs for everything you need to swap axles out?
Old 04-12-2012, 04:33 PM
  #104
conerboner's Avatar
anybody know the torque specs? i'm changing mine tomorrow
Old 07-08-2014, 07:22 PM
  #105
iToastie's Avatar
Thanks
Old 07-08-2014, 08:18 PM
  #106
tazmanian devil's Avatar
saved for later and nice write up!!
Old 07-09-2014, 10:03 AM
  #107
Fidget's Avatar
Would you need an alignment after you replace your axles?
Old 07-10-2014, 07:29 PM
  #108
No you don't need an alignment after an axle replacement.
Old 07-10-2014, 07:43 PM
  #109
chris88z24's Avatar
I was looking at the OP's rust-free suspension and noticed he was from Michigan. First I figured there was no way this guy drove his car in the winter. Second I thought those bushings came out way too easily.
Then I saw the thread was from 2006... lol
Turbo Johnny
02-21-2019 09:41 AM
chefhhr
10-26-2015 10:36 PM
Jacque8080
09-09-2015 09:21 PM
Macgyver2484
09-02-2015 05:44 PM
Quick Reply: Drivetrain: How to Install Axles and CAB's (56k time to upgrade)
