2.0 LSJ Engine: How To Install Big Bore Throttle Body For Cheap!
Old Jul 10, 2008 | 10:25 AM
  #76
djt81185's Avatar
Ya IDK but i know chevy does fiddle with the ecm numbers. 06blacks car was a early 06 and the dynamic air was at like 2600, my 05 redline was 5800, and witts early 06 cobalt was at 5800...chevy has changed the motor ecm settings a few times on cars
Old Jul 10, 2008 | 10:31 AM
  #77
06black's Avatar
yes sir.
there are 4 different base OS files for the car as well. let alone in version changes.
Old Jul 15, 2008 | 07:16 PM
  #78
JapEatr's Avatar
South Central *********
there is the number 4 stamped in the blade...i realize it is on the backside of the blade but is the number upright(ie readable) when it is in the right way?
Old Jul 17, 2008 | 01:25 AM
  #79
theneelster's Avatar
Originally Posted by djt81185
Witts car with the TVS had a similar issue...the car was basically undrivable in low gears. There was nothing we could do cept put the stock tb back on. Its a setting somewhere we dont have access too cause even with the original tb u can still feel the jerkiness but the tb isnt large enough to cause the car to go into convuslions like the ls4
I have no idea on what table could be causing it but my money is on its somethign we dont have control of
I only have that problem on uneven pavement for some reason...it's kind of hilarious but then you just short shift into 2nd and it's not a problem at all. Great mod for little scratch...+1
Old Aug 15, 2008 | 01:51 AM
  #80
aja342's Avatar
Some pics of the housing. Will finish tomorrow
http://www.fquick.com/garages/viewga...wimg&id=180100
http://www.fquick.com/garages/viewga...wimg&id=180101
Old Sep 20, 2008 | 10:16 AM
  #81
ACESSbalt's Avatar
click
Old Oct 29, 2008 | 08:26 AM
  #82
FrankTheTank's Avatar
click
Old Nov 11, 2008 | 01:45 AM
  #83
M88ArRamadi's Avatar
Sorry to bring up a dying thread....but I have some issues.
I just installed the LS4 TB and keep throwing codes: P1516, P0507, P2119. I can't figure it out. I've tried to adjust some of the tables but it doesn't help. I know a couple of you said you had a problem...what did you guys do to fix it? I'm thinking about putting the stocker back on...I can't drive the balt when it keeps going into limp mode!
Old Nov 11, 2008 | 10:32 AM
  #84
csementuh's Avatar
Mine threw a couple codes before my scalar values were adjusted in the tune... Did you adjust them?
Also what codes are those?, I don't feel like searching...
Old Nov 11, 2008 | 10:52 AM
  #85
I have the idle set to 850 but it's idling at 1000. The car also goes into wild convolsions then into limp mode.
P0507 Idle Speed High ECM, PCM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance- ECM, PCM
P2119 Throttle Closed Position Performance ECM, PCM
Old Nov 11, 2008 | 11:40 AM
  #86
csementuh's Avatar
Ohh wow, yea those ones are new to me... But I would def set your idle a little higher than 850 anyways. The one code I got was something about "Throttle Body ECM Performance" and it was not a big deal so my tuner just disabled the CEL.
Sorry I don't know any more than that... Good luck with getting it fixed... You might want to throw the stocker back on for right. The LS4 TB makes driving the car a PITA anyways, ultra touchy...
Old Feb 11, 2012 | 06:34 PM
  #87
Joemaster70's Avatar
how long should it take to grind the supercharger outlet to get the LS4 tb to open wide?
Its taken me a long ass time. Using a dremel with aluminum grinding bit
Old Feb 11, 2012 | 07:40 PM
  #88
zfissette's Avatar
its not something your supposed to do. euthanasia has done side by side tests and the m62 loses power if you open the throat instead of running an adapter plate. but if its what your going to do then use a more aggresive bit to remove the bulk of the material then use progressively lesser bits to polish it up.
Old Feb 11, 2012 | 07:44 PM
  #89
ItalianJoe1's Avatar
A grinding bit will take forever, the aluminum loads it up and really slows the process. Get a single-cut carbide cutter for porting type use and you can do it in no time. Just go over it with some sandpaper by hand after to smooth it back out and it will work just fine.
Old Feb 12, 2012 | 11:35 AM
  #90
i havent taken much off. I got a TB spacer plate but still need to port that so the ls4 tb can open up
http://menards.com/main/tools-hardwa...49-c-10099.htm
is that the right tool?
ill still need it if i decide to use the spacer
Old Feb 12, 2012 | 02:22 PM
  #91
Dremel 5/16" Cone Tungsten Carbide Cutter at Menards
Still a grinder. Look for something more like this
Dremel 1/8" Carbide Cutter at Menards
I'd suggest getting a full-size bit and a die grinder, those little bits take forever and dremels suck a big fat hairy one. Air tools FTW.
Old Feb 12, 2012 | 04:51 PM
  #92
i got a drill. should i just get a drill bit?
Old Feb 19, 2012 | 11:06 PM
  #93
cobalt_sport08's Avatar
Sorry if someone already asked (i doubt) but for my 2.4 would the LSJ or LS4 be better?? and if i did this would determine which type of intake i would be able to put on, plus would have to get a tuning adjustment?? :/
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
