Interior: How To: Make a Dual Gauge Cluster Bezel
Old Jul 12, 2011 | 11:19 AM
Tstonee's Avatar
2" pvc.
Old Jul 12, 2011 | 01:37 PM
C_A_D88's Avatar
Ive been using 2 inch abs or PVC
Old Jul 12, 2011 | 08:35 PM
Miko's Avatar
Chris's bezel looks really good and his general level of craftmanship on other customization is pretty high.
Old Jul 13, 2011 | 05:49 PM
C_A_D88's Avatar
^ thanks man
Old Sep 16, 2011 | 06:27 PM
Madlinx's Avatar
I wish I had this kind of craftiness.
Old Sep 16, 2011 | 07:59 PM
C_A_D88's Avatar
It's quite easy, just gotta take your time.
I didn't wanna pay the 300 bucks other ppl were charging, so I said **** it and tackled it myself, gotten pretty good at it now, the first one (my own) was not the best, but the rest since then are mint. Made another one for myself, ( tossed my original) and have sold 5 or 6 to local guys in Ontario with nothing but compliments on the fit finish and design.
Old Dec 2, 2011 | 11:38 PM
xtremecavy's Avatar
My Gauge Pod
Originally Posted by C_A_D88
but you dont have permission from us, sorry. if youd like to become a supporting vendor let us know, if not keep it to pms.
here is mine , i had to refinish a few spots afterwards, its been done for over 6 months but just got it installed with an aeroforce and AEM gauge now....suggest doing this to an extra bezel though just in case you mess up, which i do have 2 laying around or can make these for you as well , just PM me for info
Old Dec 3, 2011 | 01:25 AM
bratboy90's Avatar
Props broham!
Old Dec 3, 2011 | 03:17 PM
xtremecavy's Avatar
I did mine from PVC and featherlite body filler
Old Dec 3, 2011 | 03:54 PM
rekameohs_nire's Avatar
i did mine from 2 in pvc and bondo body filler.
Old Dec 3, 2011 | 11:59 PM
  #36
acillatem237's Avatar
thats sweet man i want to try but not good enough at it but great job man amazing look in the car
Old Dec 4, 2011 | 12:53 AM
  #37
C_A_D88's Avatar
Old Dec 4, 2011 | 01:15 AM
  #38
Pyros777's Avatar
Wow, that is impressive!
Old Dec 4, 2011 | 11:35 AM
  #39
Miko's Avatar
The matte finish almost looks OEM, me likey.
Old Dec 4, 2011 | 02:19 PM
  #40
C_A_D88's Avatar
The color is near identical the smooth finish is not, smooth finish looks better tho
Old Dec 7, 2011 | 06:13 PM
  #41
Mendomar06's Avatar
That is Impressive!!! You have some talent
Old Dec 20, 2011 | 06:11 PM
  #42
el_angelito's Avatar
great product
do you sell or make others?
Originally Posted by Miko
Okay here is a quick how-to based on my recent experience building a dual gauge cluster bezel.
What you need:
- Instrument Cluster Bezel
- Donor gauge pod OR plastic pipe (see step 2)
- 5 minute epoxy
- 2 part epoxy flexible plastic bumper filler
- plastic paint (most people use satin black)
- rotary tool
- sanding drum for rotary tool
- cut off wheel for rotary tool
- 220 grit sandpaper
- 600 grit sandpaper
1. Get a bezel
2. Figure out how you want to mount the gauges. There are mainly two choices, cut up a gauge pod to fit the bezel, OR use plastic pipe. Most people go the pipe route but I had the pillar sitting around and I think the curve at the back uncovers a lot of the speedo and tach. I have not tried the pipe route so I don't really know what to use but I heard that you can find 2 1/16 inch ABS pipe or PVC conduit at Home Depot or Lowes. However I suggest a trip to the store with a gauge to answer that question.
3. Figure out what angle you want to set the gauges to. I made a template to help. If I had to do it again I would angle the gauges inward (towards the driver) a bit more to cut down on glare.
4. Cut your pods out of your donor gauge pod or pipe to fit the contours of the bezel. Test fit repeatedly! Check the angle against what you want.
5. Once you are happy with the dry fit of the pieces, you are ready to glue them together. To join the two pieces to the bezel I scuffed the area around the mating surfaces up real good then liberally used 5 minute epoxy to hold them in place. Don't skimp on the epoxy here, you can add a lot of strength in the places that will be hidden from view later. It is also a good idea to clean the surfaces you are joining to get rid of grease etc.. I used just soap and water but you could use something more agressive as well.
6. Once the epoxy glue had set up I scuffed up the areas where I wanted to blend the pieces together. Then I used 2 part epoxy flexible bumper filler to build up the area and create the blending between the two pieces. Wait until it is hardened. The pods I cut out of my donor A pillar gauge pod were not symetrical so i had to make some relief cuts and use a heat gun to roughly shape the back of the left side pod to match the curve of the right side. You can avoid this by using pipes or a donor gauge pod which is symetrical.
7. At this point your bezel should be strong enough to be considered one piece. Now you can cut out the areas needed for the gauges to fit. I used a cutoff disk on a rotary tool cutting in from the outside. Test fit the gauges and make sure they sit flush and even to each other. Adjust as necessary. Aeroforce gauges are pretty shallow and will mount easily but if you are using anything else you will probably have to cut down the mounting studs. It should be obvious how much you will need to trim. Keep in mind any wires or tubes that will be plugged into the back of your gauge and allow room for them.
8. Use the sanding method of your choice to roughly shape the blended areas. I used a palm sander for the flat front area and a rotary tool with a fine sanding drum to quickly remove large amounts of material from the inside curves. Then I used my finger and a strip of 220 sandpaper to get the finer finish and feather the filler to the piece. You may have to fill in voids or pits in the filler material so don't be surprised if you need to do a couple coats or spot fix ups.
9. If you are really good you can get away with just the bumper filler to get the final blending. I could not so I also used Spot/Glazing putty and more sanding to get to a smooth finish. Use some 600 grit sandpaper once it looks like the blending is done just to smooth it out some more.
10. The bezel comes textured but likely you have made your blended areas and the "pods" smooth by now. Do a quick sand with 220 grit sandpaper to knock down the rest of the bezel texture. If you are so inclined you could go so far as to also use glazing putty to make a super smooth surface.
11. Now you are ready to paint! Spray a test coat and look for any more pits in the blended areas that you missed, it's easier to see with paint. Repeat step 9 until perfect then paint another coat to check that everything is good. Once everything looks good continue painting the rest of the coats.
12. Mount your gauges, install your new dual gauge cluster bezel and enjoy!
Old Dec 24, 2011 | 08:08 PM
  #43
thebucky84's Avatar
I still have to make one, I think I'd rather have someone do it for me lol
Old Jan 15, 2012 | 02:35 PM
  #44
574's Avatar
574
Attempting this today... haha hope it goes well.
Old Jan 15, 2012 | 03:01 PM
  #45
whyyoumadson?'s Avatar
ill play...
most recent i did..... no paint pics because i surprised the customer with it since i was running behind.... didnt want him to see until it got to his door.
wasent a fan of this one but its what the customer wanted.... fit an aem WITHOUT hitting.
scythe snakes single
evo pod
solstice kappa racepak dash pod
misc bezel pics
most know this one
Old Jan 15, 2012 | 09:25 PM
  #46
574's Avatar
574
I made mine with fiberglass. I'll post pics when its done if it turns out good.
Old Aug 2, 2012 | 06:12 PM
  #47
Attempting next week
Old Aug 2, 2012 | 06:48 PM
  #48
TX.SS.TC's Avatar
Subd
Old Aug 3, 2012 | 12:22 PM
  #49
Dipped_Cobalt's Avatar
nice nice!
Old Aug 3, 2012 | 12:33 PM
  #50
LaserblueSS's Avatar
whoa, the one with the 3 gauges ON the dash looks amazing! i really like that. i imagine that took quite a while to do.
