Appearance: How to paint fuel rail cover and spark plug cover (56k=DEATH)
Old Oct 14, 2006 | 10:02 PM
Dead Zen's Avatar
Ok so i was bored on my day off and decided to do some painting. You will need, brake cleaner, 1 inch blue masking tape, 1/4 inch green masking tape, Razor blade, red 3-m scuff pad, self etching primer, your choice of paint color, and clearcoat.
Step 1:
using the blue tape run a line over the ecotec badge twice(always good to double wrap). cut out along the badge and you will have a nice clean edge.
Using the 1/4 inch green tape, cover up the raised part of your spark plug cover, u will need to use it 2 times across to cover it, trim a straight line if needed
Here is your finished masked off and cut pieces
did the bowtie with the green too, it sucked, lots of small pieces.
Step 2:
Take your 3-M scuff pad and scuff all of the surfaces. Wipe clean with a dry towel, wet towels will ruin your masking job.
Step 3:
Prime with the self etching primer. ONLY 2 coats, any more and it loses its purpose of making a good sticky contact area. Wait 15 minutes before painting.
Step 4:
Paint with your paint of choice. I went to the local autobody supply shop and had em mix up some laser blue, it was dead on. Take your time and spray about 4-5 coats, waiting 5 minutes between coats.
Step 5:
AFTER waiting 15 minutes start clear coating. if you have never clear coated before it is important that you do not put to much on at once. Dont expect it to shine with 1 coat. Coat about 4-5 times waiting 5 minutes between coats.
Step 6:
After drying for about 1 hour carefully remove your tape. It helps if u run a razor along the edge of the tape and paint where they meet, it will prevent it from lifting up.
Heres the finished product
Rick
Old Oct 14, 2006 | 10:07 PM
Cobalt_Supercharged's Avatar
Very nice looking. Good write up.
Old Oct 14, 2006 | 10:10 PM
Dead Zen's Avatar
Thank you, I try. But after seeing it on the car i now have decided to paint the whole valve cover laser blue as well.
Rick
Old Oct 14, 2006 | 10:15 PM
calmb4dastorm's Avatar
note>>> non-high heat paint has the tendancy to crack at the temperatures our cars run at.
Great write up all-in-all tho. I'm gonna do the same in due time tho.
Old Oct 14, 2006 | 10:20 PM
xspyder85x's Avatar
nice job man, i wish the 2.2 had a fuel rail cover
Old Oct 14, 2006 | 10:44 PM
Dead Zen's Avatar
Yeah i asked the guy at the paint store, really good, been there for years, told him bout the conditions and he told me it would hold up and if not bring it in, so, i really cant loose. APS is an awesome paint store.
Rick
Old Oct 14, 2006 | 10:48 PM
M-Dub's Avatar
I really wish I would have bought the color matched paint... looks really good!
Old Nov 13, 2006 | 10:33 PM
Dead Zen's Avatar
Just an update cause im bored, the paint is still holding up and looks as good as the day it was done
Old Feb 10, 2007 | 12:07 PM
1BadBlueSS's Avatar
I think i am gonna do this!
Old Feb 10, 2007 | 04:29 PM
Coop's Avatar
Hey laser you got the same color as me on my SS. Where did you get your paint? If it is local think he could mix me a a spray can too?
Old Feb 10, 2007 | 04:35 PM
Cobalt_SSTuner's Avatar
great job
Old Feb 11, 2007 | 12:23 PM
Dead Zen's Avatar
wow back from the dead. I got the paint at a local auto body store. They got my color code and custom mixed it into a spray bomb. All you have to do is go to a local auto body store and thet should be able to mix it.
Old Feb 13, 2007 | 04:16 AM
Red06LS's Avatar
Dupicolor has all GM colors in spray cans. Any local parts shop should have them.
Old Feb 27, 2007 | 04:56 PM
1BadBlueSS's Avatar
Where would I get that 1/4" green tape???
Old Feb 27, 2007 | 05:51 PM
blu3_v1p3r's Avatar
... try like a sherman williams... or even walmart might have it in ther paint section
Old Feb 27, 2007 | 09:47 PM
Dead Zen's Avatar
it is used for fine lines. You most likely only gonna find it at an auto body supply shop
Old Feb 27, 2007 | 11:41 PM
blu3_v1p3r's Avatar
Rick
Hey did you paint your valve cover, and how easy was it if you did?
Also do you have pics?
Old Feb 27, 2007 | 11:50 PM
Dead Zen's Avatar
never did the whole valve cover. i am prolly gonna polish it. I think it would be to much blue
Old Feb 28, 2007 | 01:59 AM
blu3_v1p3r's Avatar
i was thinking about buying a valve cover from someone... so in case I didn't like it I could still keep the one I have, but as far as difficulty goes for painting it... pretty easy?
Old Mar 3, 2007 | 12:12 PM
1BadBlueSS's Avatar
Whats the Hex bolt size on the FRC?
Old Mar 3, 2007 | 01:14 PM
Dead Zen's Avatar
they are all t-25 torx bits
Old Mar 3, 2007 | 11:13 PM
06_SS_S/C's Avatar
Thanks for this write up, I did mine today and it looks great!
Old Mar 4, 2007 | 03:20 AM
Dead Zen's Avatar
dude that looks good in red
Old Mar 8, 2007 | 04:59 PM
1BadBlueSS's Avatar
Mine used t-27 torx...
The fuel rail cover nuts were really easy to break loose...but those spark plug cover bolts are a bitch! I havent been able to break em loose yet.
Oct 20, 2015 09:56 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
