Appearance: How To: Paint Yo Plastics (Pics)
Old May 17, 2006 | 04:16 AM
Beck's Avatar
Aite Children... Today we gonna learn to paint Yo' Plastics.
And by plastics i mean anything thats plastic in or on the car you want to paint... (Dash, pillars, Center Console, Engine Covers, etc) NO SANDING OR PRIMING REQUIRED
THIS IS A GENERIC HOW TO I KNOW ITS NOT A COBALT DONT FLAME MY ASS AND I DID NOT DECIDE ON THIS COLOR SCHEME
Bascailly this is a 98 civic project car. It will be the same basics for your cobalt. You will need some general kowledge to remove the desired parts and reinstall them.
Paint used - I reccomend krylon fusion spray paint for plastic. You can get it at walmart for about 4 bucks a can.
Before - Today's project.... a Center Console/armrest
1.) Before painting anything you should remove the piece from your car. Make sure you are painting in wide open areas free from dust and well ventilated... i am not held responsible for any ******* mistakes on your part. I would also reccommend lying newspaper down or placing the item inside a cardboard box to prevent paint from getting on your floors or whatever surface you are painting on.
Dismemberment
2.) Apply a plastics cleaner to ensure all residues and bodily secretions are vacant and go over the surface once more to ensure the surface is dry and free of debris.
3.) Tape off any areas you do not want to be affected by the paint. Use an razorblade to cut any fine lines with the tape to get a clean look.
4.) Shake can well for about 30 seconds and apply a light thin even coat of paint while holding the can UPRIGHT. It is recommended that you paint holding the can erect and not tilted at an angle or you may just end up splooging all over your project rather than spraying paint. Use a fan like motion about 5 to 9 inches away from plastic
5.) You will apply somewhere between 3 to 5 thin coats total, while waiting approx 7 minutes bewtween coats. After all coats are applied let dry for 20 minutes.
Painted Inserts
Painted Console
6.) Go back over with one light coat just to get a good cover of paint and let dry for 30 minutes.
7.) After it is compete dry remove tape from the desired areas and once again wipe down the plastic pieces with a clean cloth to remove any debris..... once again no sanding or priming is required. This technique was used on a previous car and has lasted four years without chipping or cracking! Still looks good as new.
AND HERE ARE YOUR RESULTS....
Go crazy, be creative and be unique!
After
After - Different Angle
Installed
***Pics and info courtesy of Snobird... if you have anymore questions you can PM Snobird or contact him on AIM as 'SlabEnt' ***
Old May 17, 2006 | 08:02 AM
RollOver360's Avatar
nice write up. I have never used that Fusion paint before, might have to give it a try.
later
Old May 17, 2006 | 08:34 AM
3fo893013L's Avatar
I have to ask... what color is the civic? Also, it looks good but I hope you do something with the color of the cushion. looks so out of place. nice job though! credit!
Old May 17, 2006 | 08:46 AM
Asphalt Assault's Avatar
how appropriate and honda civic that is black and blue...... if he wants that just race a cobalt. the car will be black and blue after that meet.
Old May 17, 2006 | 05:56 PM
biohazard's Avatar
Get low
no primer sanding or clear coat? i hope it stays on man, not doubting u, i just have all of that stuck n my head form doing a buddies firebird dash..... suggestion, never paint a dash white is was too tricky.... ill get a pic later
Old May 17, 2006 | 06:02 PM
Brian MP5T's Avatar
IMO Paint unless done by a pro body shop, looks Ghetto..
Old May 17, 2006 | 10:11 PM
snobird's Avatar
it has been tested for four years no sanding or priming and after 4 years no chiping cracking and nothing fading or n e thing
and brain we are a professional paint shop i belive an average person can do a good job though and the civic is black
Old May 17, 2006 | 10:14 PM
2K5SS/SC?'s Avatar
Not always true. I have a procedure down pact to make it look like factory paint utilizing Duplicolor spray paint, a lot of prep work, and some very clean sterile paint areas.
Old Jun 5, 2006 | 07:44 PM
skydragon26's Avatar
how does this paint hold up to engine heat?
Old Jun 6, 2006 | 09:56 PM
joeworkstoohard's Avatar
not very. there is special point for that. duplicolour makes it as do a few others. see your local pepboys
Old Sep 12, 2006 | 04:39 PM
cawpin's Avatar
Also, if you're going to do black, grey, tan...any standard interior color on vinyl, like in the pictures, just use vinyl dye instead of paint. It won't chip or come off. This plastic paint may do ok, but not as good as dye.
Jan 12, 2016 12:01 AM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
