Interior: How To: Paint your dash
Old Jun 18, 2007 | 06:33 PM
  #126
Jusday's Avatar
Originally Posted by jkabaseball
OK i'm very noob, and this will prove it......
How do you remove the trim? I checked the piece by the passenger side under the glove compartment and not budging at all.
search the how to's. and you use a screw driver on the clips and pull like hell. blue man group haha
Old Jun 27, 2007 | 02:59 PM
  #127
jkabaseball's Avatar
mines turning out nice. How do i get the door things off? i have electric windows and mirrors, so i'm guessing there is a lot of wireing on them. I don't even know what they are called to search for them.
Old Jun 27, 2007 | 04:22 PM
  #128
Viper33884's Avatar
In the bottom of each plastic piece there is a flap you need to pull up with a small flat blade screw driver then there are 2 phillips heads #2 I believe then then pull up and back same time, then just some quick disconnects and some plastic clips, sanding, and pretty pretty.
Old Jun 27, 2007 | 04:37 PM
  #129
PinkStripedCobalt's Avatar
i forgot to post pics of my car done, so here are a few
Last edited by PinkStripedCobalt; Jun 27, 2007 at 04:37 PM. Reason: Automerged Doublepost
Old Jun 27, 2007 | 05:44 PM
  #130
Viper33884's Avatar
^^ Looks good, can't wait to do mine red.
Old Jun 27, 2007 | 08:21 PM
  #131
blu3_v1p3r's Avatar
This Why You Shouldn't Paint The E-brake Handle
I painted the E-Brake handle to match the rst of my car and now i know why i shouldn't have, but oh well i'll try something else now...
Old Jun 27, 2007 | 09:37 PM
  #132
Viper33884's Avatar
@ blu3_v1p3r - If you prep it with some primer it might stick better or use a Scotch Brite pad??? But looks good if it didn't peel.
Old Jun 28, 2007 | 01:29 AM
  #133
blu3_v1p3r's Avatar
I didn't want to sand it since it is like rubber/plastic, and the roughness of a scotch bright pad would leave deep scoures in the part. Also the primer came up with the paint. I have an adhesion promoter, which if for pieces that flex. Not only does the e-brake lever flex, but there is a few spots that it rubs in the console, resulting in scratches that makes the paint chip away. I think what i'm going to do is use the paint that i painted my doors and everyhing else with and ty to mak it the gloss black to match the rest of the pieces that i painted.
Old Jun 28, 2007 | 04:09 PM
  #134
Dave104's Avatar
Looks like I'll be trying this soon but i would use steel wool instead of sandpaper. Since you're working with finished plastic pieces it works better IMO. Used steel wool when i painted my headlights and it was flawless.
Old Jun 28, 2007 | 04:56 PM
  #135
Jusday's Avatar
Steel wool FTW! I love that stuff it does work perfectly on the lights. I would try it on the e-brake also...
Old Jul 2, 2007 | 03:34 PM
  #136
blu3_v1p3r's Avatar
Sand paper is your best choice, becasue you can choose the grit, and it sands evenly. I use a high grit sand paper, to just rough up the surface. The steel wool will work, but you have to be more careful as to how hard and where your using it. When i re do the e-brake piece, i'll be using the adhesion promoter/flex primer, so when the piece flexes and bends it will not crack
Old Jul 4, 2007 | 05:32 AM
  #137
studderin's Avatar
Siqqqqq
Old Jul 10, 2007 | 02:32 AM
  #138
Quicksilver83's Avatar
how do u take that fog light switch wiring off the panel?
Old Jul 12, 2007 | 10:26 PM
  #139
SlyBlu7's Avatar
haha, once I get those parts off the inside, I have some plans I wanna run by you.
I have a LaserBlue exterior, I'm thinking make a nice brushed-gunmetal interior. But the real kicker is the fact that I can airbrush, and wanna make some killer stripes along the long passenger side.
Gonna look okay? I was wondering what accent color I wanted allover the car, because nothing goes with blue!
Old Jul 22, 2007 | 06:29 PM
  #140
thedub784's Avatar
Did you take out the dash to paint it?
Old Jul 23, 2007 | 03:41 PM
  #141
Viper33884's Avatar
White would look good with blue or maybe black?
Old Jul 23, 2007 | 04:55 PM
  #142
EmperorJJ1's Avatar
white, silver, black, orange
Old Jan 14, 2008 | 11:50 AM
  #143
DoMiStIc_RuSh_06's Avatar
How do you get the window bezel pieces off of a cobalt ss, I took that piece out and the 2 screws out, now what????
Old Jan 14, 2008 | 12:39 PM
  #144
hinow41's Avatar
This is mine, Im thinking about repainting the trim black and the shifter. This is a nice and easy how too
Old Jan 14, 2008 | 12:51 PM
  #145
cobalt_864's Avatar
whats the easiest way to paint the glove box. thats all i have left
Old Jan 14, 2008 | 03:48 PM
  #146
R1-Graphics's Avatar
everyones looks good.when this weather gets abetter im gonna paint mine
Old Jan 18, 2008 | 04:48 AM
  #147
r0k0's Avatar
a fellow member of the CobaltSSQuebec.com redid the interiour customa bit..!
Old Feb 4, 2008 | 06:36 AM
  #148
dayton's Avatar
how do you take all of those parts off?
Old Feb 4, 2008 | 11:46 AM
  #149
blu3_v1p3r's Avatar
you have to take them off in order, start with the peice above th glove box, then get the peice on the other side of the stereo, by the steering wheel, and the the one on the other side of oif the wheel, then get the one around the stereo. To get them off i used a snall screw driver and used it kind of as a prybar, but if you can get a hold of it you can pullit off with you hands, some where here is a how to about taking off the trim
Old Feb 15, 2008 | 01:57 PM
  #150
VibrantCOBALT's Avatar
i want to try this so bad but im afraid of screwing it up ;(
