Appearance: How-to paint your factory 18's
When you take off the stock paint with the thinner, should you also get those sections that are in the back area and in between the spokes, or just tape off those parts when you are using the paint thinner?
I told the mechanic I know about this. He told me not to do it because I would "hate the finish". He said it would be very uneven and "blochey" and that I should take it to a place to have it done. Is your finish uneven or bumpy or runny?
Originally Posted by ssnipes
could you photoshop this? please. Thanks.
Originally Posted by Kemble
Nice write up. I'm curious to see how this will look with my accented blue rims.
No, I mean the section that Kemble has painted blue.
If you want it to stay like stock just mask that section off as is
Originally Posted by SS33
Heres a quick one I think it turned out good, I didn't realize it'd look so much better leaving the lugs and center caps as is,, I'll hafta re-do mine this way\
Since my car is going to be down for a while with clutch problem i might have to do that, looks better on red then i thought
No problem Kemble, I was having too much fun w/ paint that day anyways, lol
You will probably get the best results by removing the tires while you do this, it will also make the rims easier to handle.
However, I don't think it'd cause you any problems if you left the tires on while you painted. It would just make the masking step more difficult, and it will not be as easy to handle as the rim alone.
Okay, got it. Thank you. Also, should I take off the tires from the rims and then just have them remounted, or just tape of the edge of the tire?
Okay, I will have them taken off. It is good to be freinds with the Manager of a Tire Kingdom. I will let you know how it goes. Thanks for the help.
