Appearance: How-to paint your factory 18's
Old Jan 20, 2008 | 02:41 AM
  #76
CleanCut's Avatar
subscribed
Old Jan 22, 2008 | 12:13 AM
  #77
hatrickstu's Avatar
a little late to subscribe bro haha
Old Jan 22, 2008 | 12:50 AM
  #78
memphisr24's Avatar
I did mine the lazy way...I didn't strip my paint...I just used scuff board and scratched the F out of the wheels....seems to do the job as well....However, I do have my eyelash in one wheel....freakin eyelashes oh and 2 bugs in the other. I saw them land simeltaniously as I was spraying the wheel...it was too late...i covered them in a coat of clearcoat ....
Moral of my story...do this in a garage with no bugs and make sure your eyelashes don't get on the wheel lol
Originally Posted by spencer
if i want to do this to my 2.4SS will i use the same stuff and process. will it look okay because i have different wheels?
I don't think you can use the paint stripper since your wheels are polished...HOWEVER, I think you can use my method...I used scuff board and scratched the whole wheel with it to make it a little ruff so the paint would stick to it. I think that would work in your case and probabyl save you a lot of time as well
Last edited by memphisr24; Jan 22, 2008 at 12:50 AM. Reason: Automerged Doublepost
Old Feb 4, 2008 | 06:25 AM
  #79
dayton's Avatar
how much did this process run you? had you ever attempted this before?
Old Apr 7, 2008 | 09:48 AM
  #80
rockSTAR_SS's Avatar
I didn't use paint stripper either. Instead I'm sanding off the gun metal finish with 80 sand paper and a palm sander, then 120, then 320, then 400 grit. I'm only going down to the actual metal where the gun metal finish chipped off. I'm just feathering the edges and leaving the original primer coat, just scuffing it up a bit.
Also, here's a suggestion. After every coat of primer, wet sand with 800 grit paper. After every coat (except the last coat unless needed) of finish paint, sand with 1000 or greater grit sand paper. I'm sanding with 1500 just to be safe. This not only allows the next coat to stick a little better, it also gets rid of any over spray or dust or anything of the sort that might have settled into the previous coat. Nice write up though! I've refered to it numerous times in the past two days. If not for this write up, I would be using the enamel paint instead of lacquer paint right now... So thanks lol
Old Apr 10, 2008 | 11:27 PM
  #81
Whining-devil's Avatar
awesome
Old Apr 15, 2008 | 04:04 PM
  #82
CleanCut's Avatar
heres mine... sorta similar but not completely..
car at the beginning of the day
rims stripped off the car and washed with dawn soap
taped off the parts i wanted to stay the same (didnt strip off the original paint)
taped off the tires too (optional if you use flat paint like i did)
scuffed up the paint down to the primer
first coat of flat black duplicolor paint
after 3 coats of paint
3 coats of clear (looks like it will be glossy but comes out flat when it dries)
finished rims
on the car
Old Apr 16, 2008 | 12:54 PM
  #83
Strychnine's Avatar
I have wheels that were painted like this and would like to get the paint off without ruining them. Any suggestions?
Old Apr 16, 2008 | 01:34 PM
  #84
CleanCut's Avatar
i think your gonna have to bite the bullet and strip them to paint them how they used to be... imo
Old Apr 16, 2008 | 03:19 PM
  #85
Strychnine's Avatar
How exactly are the stock SS/SC wheels painted?
Old Apr 16, 2008 | 09:12 PM
  #86
CleanCut's Avatar
i dont know the name exactly but theyre like a gunmetal grey color
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
riceburner
Sep 26, 2015 12:57 AM
