Interior: How to remove shift knob...(5 speed)
Old Jun 16, 2017 | 12:38 AM
  #51
EVODNA's Avatar
Removing cobalt ss shift knob
Originally Posted by slowbalt
First of all FORGET EVERYTHING YOU HAVE READ ABOUT DRILLING!!!!! Now that I have kept you from making a big mistake read on...
This is a two min. job!
First lower the boot by twisting it and pushing it down. There are some "teeth" that have to line up with some slots before it will slide off.
Next, with boot down, take a small flat headed screw driver and carefully bend back a few of the pins that are holding into a groove in the shifter shaft. (there are four of these pins)
I only had to bend back two and the knob pulled right off.
Thats all there is to it, the knob is now off. There are no threads on the shifter so I will just glue of epoxy another knob on. The base ones are hedious!!!
Good luck and I hope this saves someone from drilling needlessly!!
Dan
Please follow steps it's is simple to remove the shift knob.
you will need a hammer
you will need a screwdriver FLAT HEAD
you will need a ball sack.
FIRST YOU NEED TO TAKE THE GEAR GUIDE ON TOP OF THE SHIFT KNOB OFF. USE THE FLAT HEAD!.
SECOND THERE WILL BE A SCREW WITH AN ODD STAR SHAPE ON IT. GERMANS USUALLY BUILD THE ENTIRE CAR WITH THIS KIND OF SCREW.
SECOND USE YOUR HAMMER TO REMOVE IT
USE AN UPWARD MOTION DUE TO.THE SHIFT KNOB BEING INSTALLED WITH A PRESS.
AND THAT'S SHOULD REMOVE YOUR SHIFT KNOB
Old Jun 16, 2017 | 09:23 AM
  #52
double clutch's Avatar
This is a 12 year old thread bud
Old Jun 16, 2017 | 09:56 AM
  #53
Tdubbs's Avatar
What is with all these thread revivals on new accounts lately?
Old Jun 16, 2017 | 09:57 AM
  #54
Not to mention the cap-lock is not needed.
RaginChopsuey
Oct 27, 2015 01:27 PM
ThoR294
Oct 4, 2015 08:44 PM
2009blackSS
Sep 30, 2015 05:57 PM
Extremespeed
Sep 29, 2015 04:34 AM
ThoR294
Sep 28, 2015 05:31 PM
