Interior: how to swap clusters
Old Nov 14, 2007 | 08:46 PM
Jn2's Avatar
Jn2
well i made a thread about this a week ago(<-it got locked due to some childish behavior), but the cluster i ordered finally came in, now for those that dont know, i bought a 2.4 cluster online, the one white the white faces(140mph), well here goes my first how(<-hopefully it gets approved)
tools:
7mm socket
rachet extention
rachet
cluster
your choice drink
step 1:
take off the trim pieces, the ones with the dimmer knob, and the cluster button on it, to take it off, just simply pull on them hard(<-b4 this make sure to loseen the top of the bottom part of the dash, part right aboce your feet, you simply pull on it starting from the bottom, they're only clipped on.
step 2, you will see 2 screws holding the cluster in place, they are 7mm bolts, remove them, now if i recall there will also be some black thingys holdin thecluster in aswell(sorry i have removed my cluster b4 to paint it, and didnt bother putting these back on so i dont remember how they work)
step 3, now that the bottom bolts are off remove the ones on the top of the bezel, there are 2 of them, a simple phillips(+) screwdriver will take them
step 4, remove the bezel, i found it easy to pull on it and take it out by slidding the corner over the turn signal stick, and then pulling it towards the driver door
step 5, there will be 4 bolts now that are holding the cluster in place, they are 7mm aswell, get the rachet and the extention ready, make sure to take a sip of you *insert drink name here*, cuz this will be tiring, remove these bolts now, they will be anoying b/c of the amount of space you have to work wth, but dont let up, just keep turning, and keep drinking
step 6, once the 4 bolts are off, pull the cluster towards you, do not take it off all in a hurry pull it enough so that u can reach into the back of it and unclip the wires that connect to it, this is simple, just push down the tab with your fingers and pull it away from the cluster, now you can pull it off
step 7, put the new cluster in, be sure not to forget to connect it, once you connect it line it up with the 4 bolt holes, now b4 u do anything, turn the car on to see it light up and watch that the needles work<-this is to make sure that you didnt forget to connect the wires back
step 8, now that you see it's all functional, proceed to put everything back the way it was before
now that you have everything back, and connected, start the car, and begin to drive around to make sure that everything works ok
now the pics(the first 2 are in 5th gear at around 2k rpm, and both show the same speed, 45)
Old Nov 15, 2007 | 03:38 AM
REIGN SS's Avatar
Original Hayden Fanatic
Nice
More pics of the install steps would be helpful
Old Nov 15, 2007 | 07:00 PM
Renesis's Avatar
you should've went with G5 clusters, red backlighting is better looking IMO.
Great how-to nonetheless!
Old Nov 15, 2007 | 08:50 PM
Jn2's Avatar
Jn2
i'll take a look at the G5 cluster, if its nice i'll get it, as long as it cheaper than the ss/sc one, cuz im planning on upgrading to it, now that that i know that'll work too
Old Nov 15, 2007 | 08:58 PM
cobaltguy88's Avatar
I got an automatic 2.2 and my cluster goes up to 120mph as well... by swapping clusters, will my car go up to 140 or what? how do u know if the mph is correct?
im really considering this mod....
Old Nov 15, 2007 | 08:59 PM
RollOver360's Avatar
Nice. I was thinkin about doing something like that back when i had the LS but never got around to it.
later
Old Nov 15, 2007 | 09:03 PM
HatedCobalt's Avatar
im wondering about the MPH deal too. i have a 120mph cluster. wont it mess itup goin ot the 140 from 120....
Old Nov 16, 2007 | 05:13 PM
JamesJJP's Avatar
Now here is my question... Was this a 2.4 before the conversion? so it was a straight swap etc...
I wanted to do this with my ss/sc but im not sure its entirely possible - first cause I live in Canada and 2nd cause I was told that it wont function the same as the stock hence why I've left it with the green and instead of white and red...
if you know or if anyone know please let me know.
Old Nov 16, 2007 | 05:50 PM
Jn2's Avatar
Jn2
well i included pics of the b4 and after, i have a LS, mine came with the 120mph cluster, this swap will let u go to 140, it is a appearance mods, for those that are tired of the black face, the swap is straight forward, read the how to, i had to mod nothin, i have a 2.2 eco ls, the cluster is from a automatic 2.4 ss, it is simple plug and play, there were no problems as far as speed reading wrong, if you look at the first 2 pics, the first is of the new lcuster, im in5th gear at 2000rpm, im going 45mph, on the second pic im in 5th gear at 2000rpm again, and once more it reads 45mph, the speeds reads right, no problem, its best not to question how this it, cuz it works the speeds reads right, the rpm's read right, the shift light comes on right, everything WORKS!!!!
Old Nov 16, 2007 | 06:10 PM
Just because u changed the cluster and the cluster says 140 doesnt mean u can get up to 140. Ur stock PCM still has the governer set at 105 for the LS.
Old Nov 16, 2007 | 06:14 PM
djblass's Avatar
wat RollOver360 said sounds just about right
Old Nov 16, 2007 | 08:22 PM
Jn2's Avatar
Jn2
yup, the governer is still the same, which is why said ths is a appearance mod, a very good mod for those that dont wanna pay 80 bucks for just a face, this one cost me 40 from ebay...it works fine, and looks nice
Old Nov 16, 2007 | 08:49 PM
Halfcent's Avatar
I'm old school
While I don't doubt that the cluster physically works, I would be cautious about the indications it is giving you. It might not be calibrated. The two clusters have different flash PROM programs, and while the needle might be moving, it might not be pointing to the correct number.
Old Nov 16, 2007 | 08:57 PM
madmark's Avatar
the cluster reads signals from the wss. it converts it into a signal the cluster can read. im sure everything will work perfectly
i bet if he goes out side and pulls the plug for the maf sensor the check engine will go off.
if he starts it then pulls the power on the alternator then the battery/check engine light will go off
Old Nov 16, 2007 | 09:02 PM
um i hate to tell ya mine goes 128 to 130 no problem and its an LT2. ive bottomed out my speedo b4.
Old Nov 17, 2007 | 12:40 AM
Halfcent's Avatar
I'm old school
Um, what? The cluster is controlled by the engine control module. What is a "wss"? The ECM communicates with the cluster over the CAN bus. There is a software switch in the ECM that tells the ECM which size wheels are on the car specifically for the speedo calibration. Besides for changing the wheel diameter, it also recognizes that a Cobalt with the 16" wheels will also have the 140 speedo, and hence send the proper signal.
Old Nov 17, 2007 | 01:26 AM
The LS will only go up to 105. U have the LT2 which probably is the "sport" package with the alloy wheels and higher speed rated tires so ur gov will be set higher. Notice how I said "LS" before not "LT".
later
Old Nov 17, 2007 | 08:39 AM
nope mine didnt have alloy wheels....it had steelies...and **** tires...but yes you did say LS.
Old Nov 18, 2007 | 12:03 AM
Jn2's Avatar
Jn2
um, half cent, i dont wanna try to argue with u(cuz ur a mod), but the cluster physically works fine, it reads fine, i try not to question hoq that is, but it does, i have already hit the 105 governer, at exactly 105mph on the cluster, i even matcheed it with the old one, which i included pics of, i ran at 5th gear at 2k rpm, the speed read 45, and with the new cluster i did the same, i ran in 5th gear at 2krpm, guess what? same speed. it works fine, i even had a friend drive along side me and tell me what his read, we did this at 20, 30, 40, and 50, we were both the same, speed and tach wise, it all works the same
Old Nov 18, 2007 | 12:36 AM
Halfcent's Avatar
I'm old school
Then I would say that's a good find. If you ever get the larger wheels, go get the ECM switch thrown for it and you can take advantage of the higher limiter.
Old Nov 18, 2007 | 01:21 AM
But isnt urs a 07? Maybe thats got somethin to do with it... i dont know...
later
Old Nov 18, 2007 | 01:26 AM
Scythe_Snake's Avatar
The sport LT's have a much higher governor than an LS. I just got out of a 05 LS.
This is a great how to, more pics as a way of walking through though. But yeah! This is nice!
Old Nov 18, 2007 | 11:01 AM
later
ya mine is an 07. that might be it. but i know in gonna do this mod asap. funny thing is the sport clusters on ebay are like 100 bux shipped and the ss/sc clusters are like 75 shipped. the ss/sc clusters are 160mph so i dunno if i want that and then get a custom gauge overlay or just run the sport cluster...
Old Nov 18, 2007 | 01:24 PM
cobaltLS4dr's Avatar
my 2005 2.2LS came with that cluster from factory and my governor kicks in at 127 on the button every time
Old Nov 18, 2007 | 02:19 PM
Jn2's Avatar
Jn2
i got mne from lkq, they hve the 2.4 cluster for 40shipped
