Interior: how to swap clusters
Old Jun 7, 2008 | 12:22 AM
  #101
Jn2's Avatar
Jn2
yes sir, plug and play, i had to try it since alot of people were being flamed wanting to swap...than i did it, and said up urs to everyone that said it wouldnt work
Old Jun 7, 2008 | 12:25 AM
  #102
mrsilent13's Avatar
good on you....way to shove your foot in theres....
i hate all those that say its not possible theres always a way
Old Jun 15, 2008 | 07:50 PM
  #103
kingarthur's Avatar
Ran into a small problem when trying to put the G5 cluster.
My RPM is about 300 lower than with the original cluster.
Tried to replace the needle but everytime the cluster drops the needles below 0 after about 5 seconds of inactivity.
Anyone else experience this?
Thanks
Old Jun 15, 2008 | 09:08 PM
  #104
dasudevil's Avatar
Actually some clusters do not transfer over the mileage. Check before changing. I had a Trailblazer that did not work like we think it should.
Not saying it wont just check before spending your money. You may be wasting it.
Old Jun 15, 2008 | 09:26 PM
  #105
kingarthur's Avatar
I installed a G5 cluster and all the settings got transfered.
I seems that everything is kept in the computer, not the cluster it self.
Having said that, I still have my issue with the tach.
Old Jun 18, 2008 | 12:17 AM
  #106
YzRider452's Avatar
Mine works PERFECT!
Old Jun 18, 2008 | 12:26 AM
  #107
mrsilent13's Avatar
clusters need to match the year of the vehicle.....like 05-06, 07 or 08...since they like to switch up our computers....so if you have an 06 you need a cluster thats off an 05-06 car....and if its an 07 you need an 07 cluster....the wiring changed...if you try and install an 05 cluster in an 07 the DIC wont work....so good luck
Old Aug 20, 2008 | 03:55 PM
  #108
Blue_Balt's Avatar
Do you have to remove the trim on both sides of the steering wheel, or do you just remove the part of the trim with the dimmer knob on it?
Old Aug 21, 2008 | 06:42 AM
  #109
Jn2's Avatar
Jn2
you remove both side pieces, you this by simply pulling on them, firt pull on your plastic thing under the wheel the cover, it will pop off, than pop the pieces out, than take the 2 nut things offf than pull the bezel out, helps to wiggle it out towards the driver side, with your door open, than take the bolts that hold the cluster off
Old Aug 27, 2008 | 07:42 PM
  #110
BULLETSSMOKE's Avatar
Swapped the 2.4L SS gauges for SS/SC gauges, direct fit.
BEFORE:
AFTER
Old Sep 10, 2008 | 07:01 PM
  #111
JL-KA's Avatar
Will 07 gauges work in the 08? I've heard ppl say both yes and no...Any 08 guys have personal experience with this?
Old Sep 10, 2008 | 08:49 PM
  #112
ProjectBolt08's Avatar
^^^^ i would like to know this also
Old Sep 10, 2008 | 10:05 PM
  #113
JL-KA's Avatar
Bump for an answer to my (and ProjectBolt08) question
Old Sep 11, 2008 | 01:19 AM
  #114
Cobalt2921's Avatar
05s-06s will work in only those. 07s and up will work perfectly alright in 07s and 08s. I assume 09s too but don't take my word for that..
Old Sep 11, 2008 | 04:14 PM
  #115
blu3_v1p3r's Avatar
i anyone is looking for a SS/NA gauge i have one that i can sell it is 05/06
Old Sep 11, 2008 | 08:55 PM
  #116
JL-KA's Avatar
Yes Yes YES!!! Time to E-Bay it up!
Old Sep 13, 2008 | 04:16 AM
  #117
0redline6's Avatar
good idea they look alot better!
Old Sep 17, 2008 | 02:34 AM
  #118
antwonk's Avatar
THANK YOU SO MUCH!!!! I have just moved to Canada with my US Cobalt and was having trouble with the KPH thing so I bought a speedometer from LKQ near Toronto. I was worried I would have to get the PCM reprogrammed for the ICP like I did when I installed an MP3 player. I read your post and took a chance - now I have an ICP that works and converts all the speeds and mileage etc to the metric system. Amazing!!! I think you saved me about $400. Much appreciated.
Old Sep 17, 2008 | 02:44 AM
  #119
Jn2's Avatar
Jn2
Old May 22, 2009 | 02:13 AM
  #120
Acey's Avatar
Swapped to a 2.0L cluster tonight and it looks good, works flawlessly.
Old Jun 28, 2009 | 11:04 PM
  #121
jlong3382's Avatar
subscribed
Old Dec 21, 2009 | 03:54 PM
  #122
LSKid's Avatar
For all those who switched to the white face/140mph cluster, does the DIC display the original mileage without taking to the dealer?
Old Dec 22, 2009 | 09:57 AM
  #123
Jn2's Avatar
Jn2
all mileage info is stored in the BCM, not the cluster, ur mileage will not change
Old Jun 25, 2010 | 09:42 PM
  #124
Xmetalhead2003X's Avatar
I just ordered an 08 G5 cluster for my 08 Ls last night, saw this mod and knew it will help with my plans, especially with a full interior LED swap, will let you know how it goes when it arrives and I get around to installing it
Old Jun 29, 2010 | 11:18 AM
  #125
Blue_Balt's Avatar
I have the same cluster in my LS and it looks great.
