Appearance: How-To: Wire Up Halos For Projectors
Old Feb 23, 2008 | 01:18 PM
  #51
cooljake73's Avatar
is the ccfl ones direct plug in or do you have to wire those up too
Old Feb 23, 2008 | 01:31 PM
  #52
denlou's Avatar
NEVER run a live wire to a switch.... always run GND to teh switch and power directly to the source.
Uhhhm, I would have to disagree. If you switch the ground, there's the potential that when you switch it off, your finger on the switch could become the ground, and that hurts, trust me.
Originally Posted by http://www.thecircuitdetective.com/bkgrd.htm
Switching. By code, convention, and good reasons, only hot wires are supposed to be switched, never neutrals or grounds.
Old Feb 23, 2008 | 01:38 PM
  #53
RobHole's Avatar
why the hell would you switch the ground?
You would put it in the positive to break the positive current... ground you still have the positive current running through everything. denlou is 100% right on this lol.
Old Mar 10, 2008 | 05:01 PM
  #54
dnovel's Avatar
Great wright up Im looking to get some halos, which ones are the ones that you in your wright up .
Thank you.
Old Mar 10, 2008 | 11:54 PM
  #55
speed_demon05's Avatar
posted for later use indeed
Old Mar 20, 2008 | 07:52 PM
  #56
boosted06ss15psi's Avatar
got mine hooked up, followed this how to and worked perfectly thanks man!!!!!
Old Apr 5, 2008 | 06:26 PM
  #57
dman090's Avatar
very good how to
Old Apr 7, 2008 | 11:59 AM
  #58
xtrmsnd's Avatar
has anybody here hooked up or have a how to on putting HID 's in these projectors . should i have gotten H1 HID's instead of 9007 ?
Old Apr 7, 2008 | 12:01 PM
  #59
yes you need the H1 for mine at least i have the 2nd gen
Old Apr 7, 2008 | 09:49 PM
  #60
Mike's Avatar
Anyone know what gauge wire our stock wires on the harness are? I'm planning to use quick connects and they have them for different gauges of wire - I want to get the right one.
Old Apr 8, 2008 | 09:09 AM
  #61
i believe it is 18
Old Apr 8, 2008 | 05:37 PM
  #62
Mike's Avatar
Originally Posted by boosted06ss15psi
i believe it is 18
Thanks!
Just got the projectors today...looking forward to installing them.
Old Apr 11, 2008 | 09:24 PM
  #63
Pyros777's Avatar
My halos came with 22 AWG, and the wiring on the car doesn't seem to say, but it looks to be the same.
What I would like to know, is would it matter if I used 14 AWG instead? I can see how a thicker wire would cause more attenuation/resistance, but it's what I have on hand already and the inline fuses I got (just to play it safe) are also 14 AWG.
Thanks in advance.
Old Apr 11, 2008 | 11:15 PM
  #64
denlou's Avatar
Thanks in advance.
Yeah that'll be just fine, wouldn't really get to worried about resistance over a span of 3FT (tops), it's when you start getting into the double digit feet that it starts to be an issue.
Old Apr 12, 2008 | 01:14 AM
  #65
Pyros777's Avatar
Thanks. I just needed a little reassurance since I'm not too electrically inclined.
Old Apr 12, 2008 | 05:04 AM
  #66
EmperorJJ1's Avatar
yup but 14g would give u less resistance then 22g...
Old Apr 12, 2008 | 07:33 PM
  #67
denlou's Avatar
Other way around heh...
Old Apr 12, 2008 | 07:47 PM
  #68
veloom's Avatar
Great write up. Installed my projectors with the HID kit, and love them.
Old Apr 13, 2008 | 04:47 AM
  #69
EmperorJJ1's Avatar
yup hence everyones goal in audio is bigger wire
Old Jun 1, 2008 | 07:29 PM
  #70
BL4Z3FURY's Avatar
so i did all this and my halos and LED's will only come on with the headlights, and my headlights are now
ALWAYS on, and my DRL are the headlights, did i do something wrong?? cause shouldn't the DRL be the turn signals
i just realized my dash doesn't light up now, Like WTF!!
Old Sep 11, 2008 | 03:22 AM
  #71
stretch89's Avatar
Nice
i think i did bad wiring cause at first only the halos light then i switch the wiring and now only the bulbs turn on then i re did it and nothing would power on? i noticed my rear lights went out also in the process and the cluster doesnt light up too, i juss gave up and put my stockers back in and those light up fine, anyone know what i possibly did wrong? i did exactly like it read except i cut the wires... pleasseee helllp!
Old Sep 11, 2008 | 12:48 PM
  #72
Viper33884's Avatar
Originally Posted by stretch89
Nice
Without pictures it's kinda hard to pin point the problem.
Old Nov 10, 2008 | 08:56 PM
  #73
Stetson's Avatar
great how to, so easy cant wait to use it when my projectors come in
Old Jan 7, 2009 | 12:23 PM
  #74
Roose00's Avatar
the 3rd gen projectors come with two sets of wires. white and black for the LEDs and a set of red and black for each of the halos. i suppose i can wire them all together into the harness? anyone deal with the wiring of the 3rd gens?
edit**
wired up today. everything looks great. anyone run into some light escaping through the top of the lens, right along the hood line?
Old Feb 5, 2009 | 04:41 PM
  #75
BlackLS's Avatar
subscribed for my install tomorrow
