Appearance: How-To: Wire Up Halos For Projectors
Old Oct 23, 2009 | 01:56 AM
  #101
Viper33884's Avatar
Originally Posted by chitala383
is there any way to make the halos brighter other than swapping out for ccfl? i bought some leds that are like 15000 mcd and they arent any brighter than the led's that came in my gen 1s. im wondering if having all of the leds wired up together is under powering them. any ideas?
I believe all 4 are wired in series, try wiring them separately, but I haven't looked at mine in forever. That and no matter what route you go with the stock 2 LED per block set-up they will only run off 2 volts, I don't think it's worth the time and effort to mess with the stock set-up anymore. I'm going with the LED rings eventually, and I gave up on the stock LEDs, got tired of replacing them once a month.
Old Oct 23, 2009 | 07:51 PM
  #102
chitala383's Avatar
what do u think i could wire them to? right now both halo rings and the 3 leds on top are all wired to my parking lights like this how to says to do it. what else could i wire the halos to to have them on all the time?
Old Oct 23, 2009 | 07:56 PM
  #103
Viper33884's Avatar
Your driving lights. That or do a little custom work and maybe do an add a fuse to the IGN fuse?
Old Oct 23, 2009 | 08:31 PM
  #104
chitala383's Avatar
ign fuse sounds promising i think. i have some of those little copper fuse taps, could i just use that or do u think i should spend a few extra bucks and get that add a fuse thing
Old Oct 23, 2009 | 09:04 PM
  #105
Viper33884's Avatar
I've never seen the taps before but I know the add a fuse is pretty safe. It says it's only rared for a certain amps and the IGN fuse is rated a little higher, but I've been running my gauges off them for over 2 years now and it's cool.
Old Oct 23, 2009 | 09:19 PM
  #106
chitala383's Avatar
http://www.amazon.com/gp/product/B000CQDRTI
thats the taps im talking about. it just slides over one side of the fuse and u wire it to that
Old Oct 23, 2009 | 10:10 PM
  #107
Viper33884's Avatar
Go with an add a fuse, much safer and you run 2 fuses.
Old Nov 21, 2009 | 03:04 AM
  #108
jayson94538's Avatar
where can i find some brighter halos. ones you see on beamers
Old Nov 23, 2009 | 05:45 AM
  #109
EmperorJJ1's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-swap-ccfl-halos-1st-gen-projectors-125327/
Old Jan 3, 2010 | 04:40 PM
  #110
wesg631's Avatar
Are the bulbs in the projector headlights the same as stock bulbs or are they different
Where can I get replacement l.e.d.s
Old Feb 10, 2010 | 03:49 PM
  #111
ericgt79's Avatar
anyone have a issue with the drivers side bulb not working? everything works except that one headlight
Old Feb 11, 2010 | 01:36 AM
  #112
EmperorJJ1's Avatar
check the bulb and the fuse box. low high left and right are all fused separately
Old Feb 11, 2010 | 07:52 AM
  #113
ericgt79's Avatar
after messing with it for hours last night and just calming down and going over everything i looked inside the connector and saw that the prongs inside there might not have been making contact so i bent them down some and reconnected it and it worked. the good thing is they fit a lot nicer than my stockers.
Old Feb 16, 2010 | 04:48 PM
  #114
mkulrey13's Avatar
I Sell replacment LEDS and HIDs for the projectors.
Old Mar 18, 2010 | 08:36 PM
  #115
tanelk's Avatar
i still havent seen a answer if hids fit on the projector headlights, the headlights from the first page
Old Mar 18, 2010 | 08:38 PM
  #116
TommyP's Avatar
AWD > FWD
yes, they do. They are H1 bulbs for the low beams and H7 for the high beams. You can put hids in any headlights
Old Mar 18, 2010 | 08:40 PM
  #117
tanelk's Avatar
i have hids that i used when i had the stock headlights but when i got the 1st gen projectors i just couldnt see how you could install them.
Old Mar 18, 2010 | 08:43 PM
  #118
TommyP's Avatar
AWD > FWD
You can't use the ones you put in the stock headlight, they are a different bulb type. You need to get h1 bulbs. The stock bulbs are 9007
Old Jun 5, 2010 | 09:26 PM
  #119
rekameohs_nire's Avatar
I followed this how to exactly like it says and only my leds work. non of the halos work replaced the leds in the halos and they still dont work. any ideas?
Old Jun 5, 2010 | 09:37 PM
  #120
mkulrey13's Avatar
You will need to rewiire them moost likely as the wiring is crap and the resiisters they use are crap.
Old Sep 24, 2010 | 08:45 PM
  #121
BeradSS's Avatar
just got mine, same as the OP but i only have 2 wires of each on the back for the halo/led. and just noticed my housing say "caution no hids" does that REALLY mean i couldnt put them in at a later date?
Old Sep 24, 2010 | 11:15 PM
  #122
mkulrey13's Avatar
you can use hids, there just not designed for them.
Old Jan 15, 2011 | 02:20 PM
  #123
shredout's Avatar
got a promlem!!!!!!!!!!!!!!
i bought a kit that came with the HIDs. its plug an play as far as that goes..
problem is, when i turn on the lights, the driver side HID and the passenger high beam come on, then when i switch to high beams, the passenger HID and driver high beam are on. i also noticed that the passenger harness is not color coded, they are all black, and the turn signal is a completely different type of plug than on the driver side.
is it possible that a simple wire switch can fix this? i am thinking that of the three wires that go into the headlight only one of them controls the high beam? maybe the previous owner switched them somehow?
if it helps, the passenger light has always reached farther than the driver side, and i always assumed it was just aimed wrong...
also... my kit came with four "quick splicers". are they safe and efficient to use for the halo and LEDs or should i use the technique explained here? will the connections be weaker with the quick splicers?
Old Jan 21, 2011 | 11:53 AM
  #124
shredout's Avatar
can i get sum help with this?? ^^^^^^^^
im an electrical newb, so i have no idea what to do?
im assuming that the wire controlling the high beam and the wire controlling the low beam got switched, and i was thinking about just switching them and seeing if that works????
all three wires are black (thanks previous owner...) but i can use the other side to determine which of the wires i need to switch. black if the return line, correct? negative i guess i should call it...
Old Jan 21, 2011 | 04:55 PM
  #125
MoJoJoSSsc03's Avatar
i wish i could help you.. my personal suggestion would be to hit up some kind of pick n pull junk yard w/ a cobalt and nab a harness.. i dont know much more, im tryin to look at this thread myself to fig out my lights lol.. good luck bro. ^
