Appearance: How-To: Wire Up Halos For Projectors
is there any way to make the halos brighter other than swapping out for ccfl? i bought some leds that are like 15000 mcd and they arent any brighter than the led's that came in my gen 1s. im wondering if having all of the leds wired up together is under powering them. any ideas?
what do u think i could wire them to? right now both halo rings and the 3 leds on top are all wired to my parking lights like this how to says to do it. what else could i wire the halos to to have them on all the time?
Your driving lights. That or do a little custom work and maybe do an add a fuse to the IGN fuse?
I've never seen the taps before but I know the add a fuse is pretty safe. It says it's only rared for a certain amps and the IGN fuse is rated a little higher, but I've been running my gauges off them for over 2 years now and it's cool.
http://www.amazon.com/gp/product/B000CQDRTI
thats the taps im talking about. it just slides over one side of the fuse and u wire it to that
Are the bulbs in the projector headlights the same as stock bulbs or are they different
Where can I get replacement l.e.d.s
after messing with it for hours last night and just calming down and going over everything i looked inside the connector and saw that the prongs inside there might not have been making contact so i bent them down some and reconnected it and it worked. the good thing is they fit a lot nicer than my stockers.
just got mine, same as the OP but i only have 2 wires of each on the back for the halo/led. and just noticed my housing say "caution no hids" does that REALLY mean i couldnt put them in at a later date?
got a promlem!!!!!!!!!!!!!!
i bought a kit that came with the HIDs. its plug an play as far as that goes..
problem is, when i turn on the lights, the driver side HID and the passenger high beam come on, then when i switch to high beams, the passenger HID and driver high beam are on. i also noticed that the passenger harness is not color coded, they are all black, and the turn signal is a completely different type of plug than on the driver side.
is it possible that a simple wire switch can fix this? i am thinking that of the three wires that go into the headlight only one of them controls the high beam? maybe the previous owner switched them somehow?
if it helps, the passenger light has always reached farther than the driver side, and i always assumed it was just aimed wrong...
also... my kit came with four "quick splicers". are they safe and efficient to use for the halo and LEDs or should i use the technique explained here? will the connections be weaker with the quick splicers?
can i get sum help with this?? ^^^^^^^^
im an electrical newb, so i have no idea what to do?
im assuming that the wire controlling the high beam and the wire controlling the low beam got switched, and i was thinking about just switching them and seeing if that works????
all three wires are black (thanks previous owner...) but i can use the other side to determine which of the wires i need to switch. black if the return line, correct? negative i guess i should call it...
i wish i could help you.. my personal suggestion would be to hit up some kind of pick n pull junk yard w/ a cobalt and nab a harness.. i dont know much more, im tryin to look at this thread myself to fig out my lights lol.. good luck bro. ^
