Interior: Installing aftermarket Tacho on Redline (with pictures)
Old Mar 24, 2008 | 01:20 AM
secondstringsoldier's Avatar
Like many of you, I'm not a fan of the position of our factory tachometer. It's a little difficult to change your view back and forth from the road/track to the tachometer all the way on the right in our cluster. The easiest fix here is installing an aftermarket tachometer that you can position right where you want it.
The first thing I did was mount my new tachometer on top of the steering column where it wasn't obscured by anything. I drilled a small hole in the plastic molding on top and ran the wires through.
This is an Autometer Phantom II Mini-Monster Tach that measures 3 3/4" in diameter, perfect for viewing through the steering wheel. There are 4 wires coming out of it: black (ground), white (illumination), red (12 volt power supply), and green (signal).
I grounded the tachometer up above the hood release lever.
Next I located the wire for illumination. It's the gray wire that feeds into the connection on top of your steering column underneath the molding.
Then, I located the 12 volt supply. This one's a bit tricky... it's underneath here...
The blue wire leading into the green connection under the column is the easiest 12 volt to splice into. My tach didn't come with a fuse on the 12 volt line so I had to put one it. Make sure you do the same to avoid frying your $200 tach.
The final step in installing the tachometer itself is to feed the green signal wire through the firewall. You'll find that your old friend the wire coat hanger is a perfect tool for assisting you through the grommet just above where the driver's feet sit.
Now that we're all done setting up the tachometer, it's time to set up the tachometer adapter. This adapter allows the tachometer to read a true signal off of the coil harness since our car has 4 coils and no distributor. Depending on your tachometer you may not need this adapter. Some tachometers have a setting that will allow you to "tell" the tachometer that it's only reading 1, 2, 3, 4, etc. cylinders. The tachometer I got DOES allow me to do this, but splicing into one single coil's signal made me feel a bit uneasy. With this adapter you're sure to get a true signal from the 12 volt supply to all 4 coils.
First I mounted my Autometer Tachometer Adapter (part number 9117) under the hood away from excessive heat.
There are 4 wires coming out of it as well. Black (ground), gray (signal), red (12 volt ignition signal), and red with either a gray or green line (coil positive).
First I grounded the adapter.
Then I attached the gray signal wire to the green signal wire that we put through the firewall grommet earlier.
Here's where you begin to remember your four-letter vocabulary. This next part is a pain in the ass.
You'll need to remove the coil cover and identify the coil harness.
Follow the harness down the driver side of the engine and you'll soon run into a quick disconnect for the harness.
Make sure to disconnect your negative battery terminal to avoid getting engine codes before continuing.
Disconnect this using a long standard screwdriver by applying pressure to the tab on the right side of the connector. You may need a pair of long needle nose pliers to pull it off. There's not a whole lot of space in there.
After you get it off you'll see that there are 7 wires coming out of it. A green wire w/ white stripe, a red wire w/ black stripe, a light blue wire w/ white stripe, a purple wire, a black wire w/ white stripe, a brown wire w/ white stripe, and a dark blue wire w/ white stripe.
The red wire with a black line on it is the 12 volt coil ignition power supply wire. There's not a lot of space to do this in so be very careful when proceeding. Cut this wire giving yourself space to strip it on both sides. Run the two red wires from the tachometer adapter and splice them as follows: The red wire with green line on it coming from the tachometer adapter splices to the red wire with the black line that is still connected to the quick disconnect. The plain red wire coming from the adapter splices in the red wire with the black line that goes to the ignition.
After you've done that reconnect the quick disconnect and tuck any extraneous wire away from any moving engine parts (shouldn't be too difficult). Now reconnect the negative battery terminal.
And you're done! I ran the two red wires and the signal wire back behind the engine and cased them in wire loom so it looks more tidy. If you have a strut tower brace bar you can cable tie the loom to it to ensure it the loom doesn't make contact with your header (this would be disastrous).
Old Mar 24, 2008 | 01:27 AM
DC52NV's Avatar
nice write up. thread approved.
Old Mar 24, 2008 | 03:32 AM
Jn2's Avatar
Jn2
good write up, i honestly got lost at the diagrams, i followed i thru than ended up lost at sea lol,
Old Mar 24, 2008 | 03:22 PM
Jn2, are you installing an aftermarket tachometer or were you just looking? If you're doing it it makes more sense while you're looking underneath the hood. But I agree, it would be a bit confusing if you're not doing it.
Old Mar 24, 2008 | 04:56 PM
invisible's Avatar
My god thats a sexy RL, do you have a pic of the tach?
Old Mar 24, 2008 | 05:49 PM
06_SS_S/C's Avatar
Nice work Tristan....need a pic of the tach from the driver seat though!
Old Mar 24, 2008 | 06:09 PM
ifknrock09's Avatar
great how to man. but where you put it it looks like it would be more in your way than anything. unless its just for the track or whatever. but even then just daily driving. i don't maybe its not.
sorry man just saw that you have a redline. in that case it makes sence.
Last edited by ifknrock09; Mar 24, 2008 at 06:09 PM. Reason: Automerged Doublepost
Old Mar 24, 2008 | 06:13 PM
impulseballer's Avatar
he has a saturn redline due. there tach and speedo r in the center of the dash.
Old Mar 24, 2008 | 09:30 PM
Old Mar 25, 2008 | 09:24 AM
ifknrock09's Avatar
Originally Posted by secondstringsoldier
looks good man. clean. saturn was stupid for putting the gauges way over there. you think that it would cause an accident.
Old Mar 25, 2008 | 06:54 PM
Tach
You get used to it after a while. It's kind of nice to not have to battle with the steering wheel for a view of the cluster. However, the stock tach is just too far away for my liking. They should have put it all the way to the left side of the cluster rather than the right side.
Old Mar 25, 2008 | 07:10 PM
black06ss's Avatar
at first i was gonna ask why the hell are you installing that on a car with a tach then i remembered the guage setup is not the best for racing. nice write up great pics, and great looking car.
Old Mar 27, 2008 | 02:51 PM
37#4Z's Avatar
off topic
but what does that tattoo on your forearm say...
Old Mar 27, 2008 | 09:48 PM
"...We have lingered in the chambers of the see, By sea-girls wreathed with seaweed red and brown, Till human voices wake us, and we drown." The last three lines of T.S. Eliot's The Love Song J. Alfred Prufrock.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
dieGone
Oct 1, 2015 06:27 PM
