2.2 L61 Engine: Intake Mod for 2.2L Cobalts with pictures!!
Old Sep 6, 2008 | 10:16 AM
  #251
Chad92's Avatar
Have you attempted the instructions on how to do so in the manual? Those worked for me.
Old Sep 9, 2008 | 02:41 PM
  #252
Element291's Avatar
**possible argument starter!** During one of my classes througout my diesel mechanic apprenticeship, we were shown a video on how K&N air filters cut your engine life in half. Due to the 'high flow' capabilities, K&N filters allow alot of smaller particles into your engine that other brand filters do not. Eventually all the small particles allowed in by your K&N air filter, build up in your cylinders and drastically decrease engine life. Sounds pretty logical to me, and has kept me away from them.
Lemme know what you guys think on it.
Old Sep 9, 2008 | 02:54 PM
  #253
ScottxKillyou's Avatar
i think you'll be ok if you change your oil regularly, do spark plugs, just maintain your car in general
Old Sep 17, 2008 | 09:45 PM
  #254
afireinside7710's Avatar
Originally Posted by Broke EF
Blktrax, I cant help but notice this in youre sig
"2007 Cobalt LS $12,385 New, Go ahead and try to do it cheaper."
I just have to bust youre ***** and tell you I got my 2007 LS for $11,900 brand new still in the plastic
Sean
Mine had 7 miles on it, 10,500
Old Sep 20, 2008 | 04:56 PM
  #255
i tried to do this and couldnt reach 2 bolts holding the silencer in, any tips?
Old Sep 20, 2008 | 05:08 PM
  #256
MP81's Avatar
Try harder. =P
They shouldn't be hard to access.
The one under the headlight is a 10mm bolt, while the one right under the airbox is not a bolt, but rather a pin.
Personally, I would recommend unbolting the wheel housing around the silencer (there's some bolts underneath the car, in that area, plus a few in the wheel-well area, you don't need to unbolt every single bolt, but about to the top of the wheel should be good). You'll have easier access that way.
Use pliers or a door-panel puller (fork-looking-tool) to remove the pin.
Old Sep 20, 2008 | 05:19 PM
  #257
Originally Posted by MP81
Try harder. =P
oh, so i need to take off the plastic around the wheel house..interesting
Old Sep 20, 2008 | 05:21 PM
  #258
MP81's Avatar
Yeah, it makes it much easier. You don't need to take the wheel/tire off, though. You can if you want.
Old Oct 12, 2008 | 11:45 PM
  #259
cjlee07's Avatar
PROBLEM!
So I cant even get my headlight out to start this process. I dont have a jack or a ramp so, removing this thing through the headlight hole is preferred. What are some helpful tips..... Cause I want this thing gone, but am having a bit of a problem
Old Oct 13, 2008 | 12:05 AM
  #260
MP81's Avatar
You don't need a jack. I didn't use one...
Old Oct 15, 2008 | 11:51 AM
  #261
KyleMinnis's Avatar
Originally Posted by cjlee07
PROBLEM!
why cant you get your head light out??
it takes like a 10 or 12mm so you un bolt and pull the light hosing out and then you unbolt the housing craddle (the same way) and then youre in good shape.
Old Oct 15, 2008 | 12:04 PM
  #262
ilovecars's Avatar
PROBLEM!
you do to have a jack look under your spare tire
Old Oct 15, 2008 | 02:24 PM
  #263
cjlee07's Avatar
I know that, I just dont trust it enough to get under the car when it is in use. I was saying I dont have a REAL jack.
Old Oct 15, 2008 | 02:29 PM
  #264
snake890217's Avatar
It's fine to hold it. I've used it a bunch of times. It's just a pain compared to a hydraulic.
Infact now I have to use it to get the good jack under my car lol
Old Oct 15, 2008 | 03:19 PM
  #265
MP81's Avatar
If it was a shitty jack, do you think they would include it? Talk about a lawsuit waiting to happen...
Old Oct 15, 2008 | 03:24 PM
  #266
ilovecars's Avatar
you dont have to get under the car realy untill you unbolt the silencer. so its pretty safe i did it just make sure its in well in place
Old Oct 16, 2008 | 12:31 PM
  #267
Maven's Avatar
Regardless of whther the jack is shitty or a CNC racing jack jack you shouldnt be under the car without it supported properly with blocks/jackstands, etc.
Old Oct 16, 2008 | 03:24 PM
  #268
MP81's Avatar
You shouldn't need a jack at all, though...
Old Oct 16, 2008 | 03:26 PM
  #269
cjlee07's Avatar
Thats what I hear... ha
Old Oct 20, 2008 | 07:37 PM
  #270
tru2nrtt777's Avatar
I went through the headlight hole, how cant you get yours out? there is two bolts and the light is out, two more and the black bracket is out, then start pulling, you will need to flex your bumper for it to fit though.
Old Oct 20, 2008 | 08:35 PM
  #271
MP81's Avatar
That works, or unbolting the wheelhousing a little, and you can get much easier access to the bolt and pin, and pull it out through the bottom. Either way, it's nothing hard.
Old Oct 20, 2008 | 10:03 PM
  #272
Idk, that pin is a biotch.
Old Oct 20, 2008 | 10:15 PM
  #273
pattersonn247's Avatar
i had no problems at all getting the pin out just take some needle nose pliers and just pull it out its not hard
Old Oct 21, 2008 | 07:57 PM
  #274
I did it before the write up and I did it through the headlight hole, I wasnt aware it was a pin until I broke it.
Old Nov 6, 2008 | 03:28 PM
  #275
gapsrollin's Avatar
i got the two screws off but at the top of the silencer their is a screw or something holding it in i cant seem to get it off its kinda hrad to explain but if ya get the picture any help
