Detailing: Polishing 101 (How-To)
Old 01-31-2007, 09:12 AM
EmperorJJ1's Avatar
nice write up... lol nice car too
would this work with pretty much any metal? i would love to polish the alternator and i can practice on the old one i have from my old car
Old 01-31-2007, 07:29 PM
BlilBT's Avatar
Yea it will, Just make sure you clearcoat IT! Otherwise it will Rust
Old 02-01-2007, 04:30 AM
EmperorJJ1's Avatar
whats the best way to clear coat? spray paint style?
Old 02-01-2007, 08:02 AM
BlilBT's Avatar
I Use a HVLP Sprayer, With HT Microclear 182. But engine cleatcoat works!
Old 02-11-2007, 04:26 PM
IMADreamer's Avatar
Quick question. How much compound should I have on hand to do this? I have probably about 6oz left of my tripoli and white rouge. Should I go get some more? It's supposed to snow most of this week so I may try and tackle the valve covers.
Old 03-24-2007, 03:41 PM
Evilfrog's Avatar
Where did you get the polish? Will brasso work?
Old 04-26-2007, 12:14 AM
Need4Speed0to60's Avatar
Awesome job, I'd like to do this if I could.
Old 04-26-2007, 12:16 AM
cblt12's Avatar
its really not to hard its just A LOT of work. make sure you have a lot of time on your hands if you do plan to do this.
Old 04-26-2007, 07:09 AM
SSKevinSC's Avatar
Talking
That looks AWESOME!!!!!! Great Job. I will have to try this on my Balt
Old 04-26-2007, 08:02 AM
06CobaltssOrange's Avatar
i want to try this but do u need to clear coat everything that u do?
Old 04-26-2007, 09:17 PM
  #36
BlilBT's Avatar
Ty >>> Its Worth it if you take your Time!
NO If it is aluminum you do not have to Clear coat,, But you will have to maintain it every Now & Then! Several Local People & Friends have Done it & It Does great as Long as you Maintain it! Steel's Need to be Clearcoated it will Rust! Get Good Clearcoat so it holds up to heat & Time!
Old 11-27-2007, 12:12 PM
  #37
blue06's Avatar
[QUOTE=BlilBT;718305]Ok I have had Plenty of People ask how to do this, So here you go! Not all tools are needed but Highly Recomended! To get a good result You must prep it good (ie: sanding), Because when you Polish it any Blemish's will show!
Now for the Tools needed,
1 Baldor Buffer or compatiable 8 inch or Bigger wheels (seen in Pic #1)
1 Sewn Cloth wheel & 1 Loose Cloth wheel for either the Buffer or Drill set (seen in Pic #1)
If you dont have a Buffer then Use a Drill with 1800 rpm to 2800 rpm with 4 inch wheels (seen in Pic #1)
1lb bar of White rouqe & 1lb bar of Tipoli (seen in Pic #1)
1 Dremel & attachments (seen in Pic #2)
1 set of 1 inch to 2 1/2 inch Sewn cloth wheels!(seen in Pic #2
1 Drill
1 Bottle of Metal Polish (liquid) (seen in Pic#3) No Paste it will dull the Finish!
Wet Sand paper 220 grit thru 1500 Grit
These supplies can be had at eastwood.com, Sears & sometimes Home Depot!
Pic #1
Pic #2
Pic #3
Ok Now time to start Polishing!
1st step is the Longest, I try to use a sanding Block where ever I can, makes for a Flat Surface Start by sanding your Piece with 220 grit, Then 400, Then 600, Then 800, Then 1000, then 1500 grit! Make sure to remove the scratches from the Prior grit Before you Move up to the Next 1!
If you Dont when you polish it, They will show!
Valve covers are Soft Metal so they require Up to 1500 grit, Motor Mounts & supercharger's only have to be sanded to 1000 grit!
when you say to remove the scatches from the prior grit before you move up to the next 1, what do mean are you supposed to buff or what?
Old 11-27-2007, 01:28 PM
  #38
BlilBT's Avatar
__________________
No what it means is that 600 grit scratches need to be removed with 800 grit before you Move up to the next Highest grit! Another words it is alot harder to remove 600grit scratches with 1500 grit, step up accordingly & makes sure that you get all the prior 1s out before moving up to the next grit!
Old 11-27-2007, 06:31 PM
  #39
blue06's Avatar
thanks that helped, I got some old manifolds that I can practice on
Old 11-27-2007, 07:32 PM
  #40
BlilBT's Avatar
No problem Any time you have a question about Polishing just post up!
Old 11-27-2007, 08:50 PM
  #41
powerz's Avatar
great work why dont you like paste ?
Old 11-27-2007, 09:01 PM
  #42
BlilBT's Avatar
Paste doesn't give you as good of a shine & will actually dull the finish after you are done Polishing!<< Been there Done that!
Old 12-28-2007, 07:48 AM
  #43
Cherry GT's Avatar
here is a link to valve cover removal....
and a pic...
http://www.g5club.net/forum/viewtopic.php?t=712
Old 02-03-2008, 10:59 AM
  #44
anthonyS88's Avatar
more loom please? lol j/k. but the valve cover looks awesome.
mine WILL be done today, im going to the home depot to get some white rouge and tipoli now
Old 02-18-2008, 06:33 PM
  #45
speed_demon05's Avatar
subscribed for later use
Old 03-09-2008, 09:00 PM
  #46
NOS2006's Avatar
How the heck do you get in the little crevices on top of the throttle body?!
Old 03-09-2008, 09:30 PM
  #47
laxguysix's Avatar
nice write up man
Old 03-09-2008, 09:42 PM
  #48
BlilBT's Avatar
Dremel tool! FTW
Old 03-10-2008, 01:38 AM
  #49
NOS2006's Avatar
Using which tools on the Dremel? I might do this tomorrow night...
Old 03-10-2008, 06:03 PM
  #50
BlilBT's Avatar
You have to use the little sanding disc & Polishing wheels!
Quick Reply: Detailing: Polishing 101 (How-To)
