2.0 LNF Engine: ZZP's ZFR Turbo Installion
Old 08-13-2014, 09:23 AM
  #176
dcrep06's Avatar
lol
Old 09-06-2014, 01:43 AM
  #177
Waka Flocka Fluff's Avatar
I currently have the zzp upper charge pipe with silicone couplers. Will the 90 degree coupler work on the zfr I just purchased? Or will I need an extended coupler for it to work? Also you guys recommend flushing the coolant after the swap as well?
Old 09-06-2014, 08:56 AM
  #178
Wert842's Avatar
You'll need the extended angled coupler unless you got a zfr that has the inlet extension on it. A good bit of the coolant will get flushed out upon doing the swap. Just top of all fluids off after it is done.
Old 09-06-2014, 10:21 AM
  #179
thanks man
Old 09-17-2014, 12:52 AM
  #180
I picked up the extended coupler and getting the turbo inspected tomorrow to make sure it isn't shot. How much/how long should I be looking at to get the turbo installed and retuned? I heard its a 6-8 hour install, is that true?
Old 09-17-2014, 12:59 AM
  #181
andrewcarr1993's Avatar
If you know what you're doing yes. ZZP does it in 4 hours
Old 09-17-2014, 01:33 AM
  #182
what about a shop that is very mechanically inclined and has the required tools but doesn't specialize in our cars. But they have extensive knowledge of turbo installations on many different types of cars. 4-6 hours?
Old 09-17-2014, 01:39 AM
  #183
Should be doable, going to be expensive for what you really should be able to do in a day.
Old 09-17-2014, 02:01 AM
  #184
I have done my own bolt ons to include a full 3" tbe, fmic, charge pipes, intake, and replaced my valve cover. Do you think I'd be able to do this myself if I follow step by step and have the required tools?
Old 09-17-2014, 04:09 AM
  #185
I don't see why not get a friend that knows cars and have an entire weekend in case it takes longer.
Old 09-17-2014, 04:57 AM
  #186
Dyn0mitemat's Avatar
Yea its not bad, I had mine done in 4-5 hours.
Just get a pan and plan on draining the coolant like it says in the OP. I had the stupid idea in my head that I could do like I did swapping the water pump on my jeep, and just plug the fittings/holes with rubber plugs when I took them off. I was under the car, unbolted the hoses, lost the one banjo bolt, had a rag and a few plugs with me under the car. No pan, funnel, anything... Yea I was soaked with coolant down to my waist lol. Other than that it wasn't any harder than bolting a fmic on IMO
Old 09-17-2014, 07:05 AM
  #187
dcrep06's Avatar
the first time i did mine it took about 8hrs, next time it took a little less. then i did pulled mine because my engine went pooooooo and it took me like 2.5hrs to take it all off on the ground. its real simple. everything goes on one way lol. bolt ons FTW!
Old 06-12-2015, 06:17 AM
  #188
Turbo Johnny's Avatar
*I edited my first sentence of my last post. Put bolts instead of gaskets*
Read my second sentence in my last post... When installing a ZFR turbo, you remove your existing oil feed line and install the AN fittings and use the new line they supply you. Even if you bought new oil banjo gaskets, you wasted money cause you won't be able to use them.
When installing the 02 housing to the turbo there is lock nuts with the new bolts so you can just hand tighten them. When installing the turbo to the exhaust manifold, torque the nuts/studs at 15lbs.
When I looked up the install info in AllData, says to use 26 ft/lbs? Is the 15ft/lbs. a ZFR install-specific torque setting? I'm about to pull my K04 for a gasket swap and manifold check this weekend.
Old 11-23-2015, 02:30 AM
  #189
Aroooo's Avatar
hey guys, I have to drop a new(used) engine into my 09 cobalt ss. if I install the zfr 6758 onto the engine before it goes into the car will I have any issues or should it just drop right in? thanks a million guys
Old 11-24-2015, 08:58 AM
  #190
dcrep06's Avatar
no you wont because the only obstacle you would have while installing the turbo with the engine in the car is the half shaft and frame stuff. which will all be out of the car when you drop the motor. you could probably leave the o2 housing on as well. just might be a little more tighter to wiggle around but should still be good.
Old 07-28-2017, 10:07 AM
  #191
Kickbutts228's Avatar
Because of Photobucket's stupid new third party rule photos cannot be shown on this website, but here is a link to his photo bucket ZFR Install Slideshow by rkoczab | Photobucket
Snail_SS (07-28-2017)
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
nathan112i
09-30-2015 07:12 PM
anotherslowlnf
09-29-2015 03:52 PM
09-27-2015 08:53 PM
Quick Reply: 2.0 LNF Engine: ZZP's ZFR Turbo Installion
