Mid Central NE, KS, IA, MO, and IL
KC area random talk thread
Old Aug 26, 2009 | 12:24 AM
  #2751
EXsoccer1921's Avatar
no you dont
Old Aug 26, 2009 | 12:36 AM
  #2752
revhigh18's Avatar
So it was fun to say it lol
Old Aug 26, 2009 | 03:20 PM
  #2753
revhigh18's Avatar
people need to post in here morel ol
Old Aug 26, 2009 | 03:29 PM
  #2754
BIGGSS_SuperCharged's Avatar
no **** this thread is gettin boring
Old Aug 26, 2009 | 08:30 PM
  #2755
theres nothing to post about
Travis heres the parts list for that mustang.
Engine
Modularpowerhouse(MPH) built 4.6L engine bored and stroked to 5.0L (281ci to 302ci)
Manley H beam connecting rods
Ross .20cc pistons (8.5:1 compression ratio)
Cobra 8-bolt Forged Steel crankshaft
ARP main, rod, and head bolts/studs.
MPH Stage 2.5 heads with new valve train(Manley and Ferrera components)
MPH custom ground camshaft for supercharger
Canton 8quart oil pan with high volume oil pump
03-04 Cobra Aluminum radiator
03-04 Cobra Sumped fuel tank and fuel pumps
Siemens 60lb injectors, stock fuel rails and lines.
KenneBell Boost-a-pump,( sends higher voltage to fuel pumps for more pressure under boost )
Power Adder
KenneBell 2.2 Twinscrew supercharger kit, Installed by MPH.
2.5in blower pulley, 7.5in crank pulley for total boost pressure of 21psi.
GIJoe's 8 Rib Pulley kit with tensioner
Riechard Racing A/C delete tensioner
Lightning Force Performance Heat Exchanger (intercooler)
Exhaust
KOOKS 1-3/4in stainless longtube headers with 3in collector
KOOKS 3in X-pipe,
Magnaflow dual magnapack mufflers with turndowns all 3in.
NO CATS
Suspension and Brakes
QA1 K-member
stock front struts and A-arms
Eibach front and rear Sportline springs
QA1 rear adjustable shocks
Steeda upper (adjustable) and lower rear control arms
Steeda Bumpsteer Kit
Energy Supsension transmission, engine and k member mounts
No rear sway bar, stock front sway bar
Kenny Brown subframe connectors
Steeda Caster Camber plates
--Brembo 4piston front calipers with carbotech brake pads w/ 13in slotted rotors( off of 2000 Cobra R)
Stock rear brakes except for carbotech pads
Stainless steel brake lines up front only
Tremec TKO-600 5spd transmission built by ModularMustangRacing. The internals have been cryotreated to withstand 900ftlbs of rearwheel torque...basically its built to handle cars running 8.9's in the quarter mile.
Mcleod 12puck 11in clutch disc
SPEC pressure plate and billet steel flywheel
FRPP aluminum driveshaft
MGW orange handle short throw shifter
Steeda Clutch quadrant kit
Steeda Shift knob
Redline synthetic transmission fluid
Lakewood SFI approved ''scattershield'' bellhousing
--8.8in live axle, with:
Eaton Limited slip differential
MOSER 31 spline axles
TA peformance differential cover with added fluid capacity
stock 3.27 rear gear
Interior and Exterior
Stock front seats
Rear seat delete kit
No stereo or door speakers, factory stereo was removed and replaced with aftermarket that I had installed. But, I removed front and rear aftermarket speakers and headunit to put in another vehicle. The 2guage power wire and JL audio battery terminals are still in place to hook up future stereo system.
4 packs of silver/black Dynomat under rear seat delete and in trunk...turn downs used to be too much, not anymore lol.
The wheels are FR500 black with polished lip 18x9 in front and 18x10 in the back
Tires up front are 245/40/zr18 Nitto 555,
Tires in rear are 305/35/zr18 Nitto 555DR (drag radials with little over half tread life left)
No rear wing,
Cobra R hood with cowl vent modification
Roush Stage 3 front fascia
Last edited by EXsoccer1921; Aug 26, 2009 at 08:30 PM. Reason: Automerged Doublepost
Old Aug 26, 2009 | 11:46 PM
  #2756
revhigh18's Avatar
holy mod list batman
Old Aug 26, 2009 | 11:58 PM
  #2757
holy 600whp pumpgas bat man. he says the only reason he doesn't use the racegas tune off the dyno is because the fuel system cant keep up even with boost a pump. if i can get a better fueling solution on there, with race gas, easy 700whp. i was talking with the guys at kenne bell and mph and they said when i get the car, send it to mph. they'll fix the fueling and put the 2.8 blower on there for an easy 800whp on pump gas. but on the current pump gas tune the car has zero fuel problems and is right at 600whp. he says he raced a 700whp cobra from 40-110 and was neck and neck with him untill 110 and the cobra started to pull
Old Aug 27, 2009 | 12:04 AM
  #2758
revhigh18's Avatar
very nice im looking for selling my car for a cobra soon because i have a strong feeling if i keep it somethings going to go south
Old Aug 27, 2009 | 12:09 AM
  #2759
yeah probably hahaha. here. after the 2.8 and fueling. it'll be identical to this car. 6.06@115
http://www.youtube.com/watch?v=WWcKd...eature=related
Old Aug 27, 2009 | 01:19 AM
  #2760
EatonTVS07's Avatar
i'm more fond of the "built not bought" thing
Old Aug 27, 2009 | 01:22 AM
  #2761
yeah. but does that count when you bought something built?? eh? eh? plus. that phrase is dumb. maybe if you bought the car new and did the work. but not when its built in a shop, the guy is selling for a rediculous price
Old Aug 27, 2009 | 01:23 AM
  #2762
EatonTVS07's Avatar
i didnt buy it built. it had some mods on it sure but thats far from ^that.
Old Aug 27, 2009 | 01:25 AM
  #2763
so you wouldn't buy a 600whp car for $14k simple because you didn't "build it"???
Old Aug 27, 2009 | 01:28 AM
  #2764
EatonTVS07's Avatar
did i say that? nope. i said i am more fond of the built not bought deal.
Old Aug 27, 2009 | 01:30 AM
  #2765
well if i happened to have a mustang gt laying around. along with about $30k. i would build one. hahah
Old Aug 27, 2009 | 01:32 AM
  #2766
EatonTVS07's Avatar
build it as you go.
Old Aug 27, 2009 | 01:33 AM
  #2767
or buy it all at once for half the cost. smell what i'm steppin' in? lol
Old Aug 27, 2009 | 02:03 AM
  #2768
EatonTVS07's Avatar
Old Aug 27, 2009 | 03:56 PM
  #2769
travis who's that jessica lawrence chick you keep commenting on. she's pretty smokin'
Old Aug 27, 2009 | 04:01 PM
  #2770
EatonTVS07's Avatar
thats this chick i be talkin to
Old Aug 27, 2009 | 04:36 PM
  #2771
she needs some, as bryan would put it, bendy bendy pictures
Old Aug 27, 2009 | 09:21 PM
  #2772
revhigh18's Avatar
hahahaha psyke!!!
Old Aug 27, 2009 | 10:03 PM
  #2773
elite_Cyborg's Avatar
hows kcmo
Old Aug 28, 2009 | 03:05 PM
  #2774
EatonTVS07's Avatar
it is just dandy
Old Aug 28, 2009 | 03:33 PM
  #2775
travis when are you gonna introduce me to that girl
