NE Ohio Thread FTW
Yeah I pulled it. I've had em in for months an all of a sudden my drivers side lo-beam fuse keeps blowing. I don't have relays but I've been fine for quite a while now so it's wierd. I've got the kid this weekend so I don't have time to check it out
if you meant me also? yes i pulled it, the guy at NTB said the positive wire was drawing too much power from the fuse box and doo dads and thingys from the area, and my car wouldnt start cus of that. it had been working fine tho, and i have an optima red top..
also its HID bulbs in stock housing. prolly makes a difference?
Drew, did you have the system grounded good? A bad ground would cause problems. I am running HIDS in both my regular lights and my driving/fog lights. I am still in the regular housings, as the projectors are not together yet. Check to make sure you have a good ground and that all connections are tight.
ill do that this week, thanks bill, perhaps i will give you a call like you mentioned about the spark plugs , and was there something else smalll and inexpensive you may have said youd help with? you know we never did my brake fluid! haha im thinking thats why my brakes are still slippy
^what you get? I'm ordering a gmpp touring exhaust sometime this week to replace my tsudo. The tsudo sounds ok but it fits like **** and doesn't exactly compliment the sound of an auto
As for plugs for the car, I would go with either NGK or AcDelco (41103) ones. Iridiums are the factory style plugs for the car. Plugs are easy, I did mine in less than a half hour last week, and that was working around the charge pipe.
I have a Hahn on my car, sounds nice. It is not that loud, and it runs good.
