frustrated new chic
Old Dec 31, 2013 | 01:09 PM
christinec587's Avatar
frustrated new chic
Hello everybody, I have been viewing this site for the last three months and I just joined today. I have found tons of information here about cobalts but I am not car savvy at all!!! Everyone here seems to be very knowledgeable and boy do I need the help
Old Dec 31, 2013 | 01:11 PM
blueLNFftw's Avatar
What can we help you with?
Omiotek's Avatar
with what????? shoot me a messege if its easier
Old Dec 31, 2013 | 01:15 PM
sandman's Avatar
Inb4everybodyasksforpicsandinb4riceburner
Old Dec 31, 2013 | 01:17 PM
Welcome to Cobalt land. Once you enter there's no escape.
Old Dec 31, 2013 | 01:20 PM
i read her post in a frustrated chick voice
Old Dec 31, 2013 | 01:28 PM
Well my car started sputtering and losing power almost 3 months ago. Got codes p0171 p0113 and p0102. Cleaned maf , new acdelco sparks, new upstream and downstream o2 sensors, seafoamed the car, etc and it turned out to be the fuel pump. Two days after getting the car back from the mechanic the cel comes back on and I get code p0301 misfire cylinder 1. Couldn't afford to put it back in the shop so i had no choice and continied
Old Dec 31, 2013 | 01:30 PM
yellow dragon's Avatar
Whats 'sup!
Sox-Fan's Avatar
Got Brakes?
is this an LSJ, LNF? LAP?
what model and year is this car Christine? Helps if we know what we're dealing with.
And, welcome to the site.
Old Dec 31, 2013 | 01:33 PM
qwank's Avatar
bring your fuel pump receipt to a GM dealer for a reimbursement. There's a special policy on them and they are covered under warranty indefinitely.
Old Dec 31, 2013 | 01:34 PM
swap spark plug 1 & 2 around to see if thats the cause, if the cel changes to p0302 it could easily be a bad gapped plug maybe
Old Dec 31, 2013 | 01:36 PM
blueLNFftw's Avatar
Id swap coils tho.
Old Dec 31, 2013 | 01:38 PM
Sox-Fan's Avatar
Got Brakes?
I'd do both.
Old Dec 31, 2013 | 01:39 PM
blueLNFftw's Avatar
Originally Posted by Sox-Fan
I'd do both.
giggity
Old Dec 31, 2013 | 01:40 PM
Tsbbzm's Avatar
Jedi Master
Id do all 3..
Old Dec 31, 2013 | 01:41 PM
armcclure's Avatar
Adam's been off his game lately. WTF.
Old Dec 31, 2013 | 01:42 PM
sandman's Avatar
I had a misfire on numero uno from oil leaking into the spark plug area
Old Dec 31, 2013 | 01:48 PM
zrated89's Avatar
wheres da noodz ?!?!
Old Dec 31, 2013 | 01:59 PM
2009 cobalt LT 2.2
Old Dec 31, 2013 | 02:01 PM
Engine power reduced came on after second wk code p0068
Old Dec 31, 2013 | 02:03 PM
Sox-Fan's Avatar
Got Brakes?
Ok, go with the advice given above. Swap the coils from 1 to 2. See if the misfire moves from 1 to 2. If not then swap plugs. See what that does.
And also, as you're in a State that I think was part of the recall you'll want to call the dealer and look into reimbursement for the fuel pump.
Old Dec 31, 2013 | 02:04 PM
Boostin15's Avatar
Welcome..
Originally Posted by sox-fan
ok, go with the advice given above. Swap the coils from 1 to 2. See if the misfire moves from 1 to 2. If not then swap plugs. See what that does.
And also, as you're in a state that i think was part of the recall you'll want to call the dealer and look into reimbursement for the fuel pump.
x2
Old Dec 31, 2013 | 02:05 PM
umrdyldo's Avatar
Originally Posted by christinec587
2009 cobalt LT 2.2
What part of Missouri are you in? I'm in Springfield.
First things first.
Swap the coil from cylinder one to cylinder 2.
Very easy to do. Just unplug the electrical connector from the 2 coil plugs. Then use a 10mm socket to unbolt the coil plugs. Then just pull up and move them.
If the CEL comes on for the second cylinder after moving then the coil plug is bad. I believe someone on her just replaced the boot not the whole plug and it was super cheap.
Carefully cleaned TB with TB cleaner and tried starting car but she wouldn't crank. Tried jumping but she wouldn't turn over then key got stuck but thanks to cobaltss i found out about lil white key release button
Old Dec 31, 2013 | 02:07 PM
Carlock came on then started flashing now car is completely dead and won't take a jump. Ended up with codes p0301 p0102 p0068 p0532
