Hi! I just bought an 08 SS / TC and I NNEEDD help!!
Old Feb 28, 2018 | 03:05 PM
Dillpickler's Avatar
Exclamation Hi! I just bought an 08 SS / TC and I NNEEDD help!!
It's a maroon one with the G85.
ZZP turbo piping
Catless downpipe
HP tuned
Bigger ZZP intercooler
Lightweight radiator
But my airbag light is on!! I have the codes for it and am looking for some help.... I am not sure where to even start diagnosing this issue? I can give the codes. Let me know if anyone can help. Thanks!
Old Feb 28, 2018 | 03:07 PM
user 72239's Avatar
probably the passenger airbag sensor. Mine went bad on my 08 at around 60k miles
cost $~500 from the dealer to get replaced.
take it to them to get the code and then go from there.
Old Feb 28, 2018 | 03:13 PM
I have a code for that, but I also have other codes... here they are... what do you think?
B1000 - Symptom 31. ECU performance?
B0012 (0D) - Driver frontal deployment loop stage 1 resistance above threshold
B0013 - Driver frontal deployment loop stage 2
B0081 - Passenger presence system (common seat belt issue?)
B3031 - Theft system (security system controller in learn mode) KEYS???
B3055 - Theft system (no transponder modulation or transponder) KEYS???
B3060 - Unprogrammed transponder identification code received KEYS???
Old Feb 28, 2018 | 03:18 PM
user 72239's Avatar
Wow.
Looks like someone was trying to program keys with a tech2 and left it?
b0081 is the code for passenger seat belt sensor. its got a weight sensor to verify if someone is sitting in the seat
the others I dont know about.
Old Feb 28, 2018 | 03:19 PM
So either way, I am probably going to have to fix that seat belt sensor because the code is there huh?
As far as someone programming the key, codes 3031, 3055, 3060, are all probably because someone didn't program the keys correctly?
Old Feb 28, 2018 | 03:22 PM
user 72239's Avatar
that what it looks like.
does your Theft light blink a bunch when you first get in the car?
Old Feb 28, 2018 | 03:24 PM
Nope. That's the weird thing. I really just want to fix my airbag light so my airbags can be on haha
Old Feb 28, 2018 | 03:26 PM
user 72239's Avatar
yeah. i know the part is around $200 and there was a writeup on here about how to swap it. I just paid for it to be done as I was like you, wanting my airbag to work.
Old Mar 3, 2018 | 11:49 AM
63 Nova SS's Avatar
It could also be in the wiring for the seatbelt retractor. I took mine off to install a harness bar and when I put it back on I twisted and broke the wire installing the belt retractor.
cHz
May 25, 2017 05:45 PM
tan305
Sep 18, 2009 12:19 AM
Rome
Jul 15, 2008 02:34 AM
