Idle RPM going up and down
Old Dec 3, 2015 | 05:07 PM
Lehi's Avatar
Team,
So when I'm on neutral or coasting my rpms go up and down below 1000 rpm. I recently switch the spark plugs, got new air filter and changed the oil, but for some reason it keeps doing it. Can someone let me know what the problem can be?
Thanks
-Lehi
Old Dec 3, 2015 | 09:41 PM
T-fog's Avatar
Could you please let us know what type engine you have? and how many kms you have?
A random guess I would say the throttle body needs cleaning. Just a guess tho
Old Dec 3, 2015 | 10:59 PM
Lehi's Avatar
2.4 super charged with 97k miles
I changed the spark plugs, changed air filter and did an oil change hoping it will help but still doing the same thing.today on the way home I was at a complete stop when my car started to roll the rpm again started to go up and down
Thanks for the responds !!!
Old Dec 3, 2015 | 11:18 PM
T-fog's Avatar
Yep sounds like the throttle body needs a cleaning.
I am not sure if this works or if its beneficial on a supercharged model, But check out Powell racings oil/air separator to help avoid or at least get more miles/kms out of it before it needs a cleaning again.
Maybe let a supercharged guy chime in to see if the separator is beneficial for you or do some thread searching and see.
Hope this helps, Keep us posted
Old Dec 3, 2015 | 11:57 PM
has it always done it since you supercharged or is it just now happening?
Old Dec 4, 2015 | 12:04 AM
YelloEye's Avatar
Welcome! Please post up pictures!
Old Dec 4, 2015 | 01:16 AM
Lehi's Avatar
It's stock super charged from the manufacturer. It has never happen before. It just started acting up
Old Dec 4, 2015 | 01:22 AM
Lehi's Avatar
@yelloweye Pic of my car
Old Dec 4, 2015 | 01:39 AM
ah then you must have a 2.0 nvm then
Old Dec 4, 2015 | 07:17 AM
Staged07SS's Avatar
Administrator
Administrator
idle hunting... check your throttle body.
more than likely it needs a cleaning.
Old Dec 4, 2015 | 12:51 PM
YelloEye's Avatar
Ah, so the Supercharged 2.0L LSJ. Sorry, thought you had supercharged the 2.4L LE5 that came on the lower model SS.
Is the check engine light on? Any codes?
Old Dec 4, 2015 | 01:10 PM
Lehi's Avatar
No check engine lights or any codes.
Joshua Sloan
Dec 25, 2015 10:34 AM
Sean Cummings
Dec 9, 2015 01:32 AM
JimmySpencer
Nov 28, 2015 12:29 PM
Gugi96
Nov 22, 2015 10:19 AM
Davulao
Nov 6, 2015 12:37 PM
