No Cobalt .... but the engine.
Old Dec 20, 2013 | 04:40 PM
samuste007's Avatar
Old Dec 20, 2013 | 05:21 PM
Disposable-Hero's Avatar
its a vauxhall they are a shared thing with gm i believe? like holden?
anyway. throw an lsj in there
Yep, Vauxhall VX220/Opel Speedster, big over in the UK. Would love to have one here.
Nice car OP, looks like a ton of fun.
Old Dec 20, 2013 | 05:37 PM
Boostin15's Avatar
Welcome!! I hope you find all the help you need. There is alot of knowledgeable people on here!
Old Dec 20, 2013 | 05:50 PM
Garret's Avatar
not vauxhaull its an opel. opel speedster
Old Dec 20, 2013 | 06:03 PM
noorj's Avatar
really like the manifold, nice bracing too.
If your replacing the rod bearings go with these:
Dezod Motorsports. Clevite 77 Rod Bearing Set-Cobalt 2.2L 02-05 (Set of 4)
Old Dec 20, 2013 | 06:06 PM
ItalianJoe1's Avatar
About your turbo question, have you measured the oil pressure at the turbo feed line to be sure it's really that high?
Worse case, you could run a restrictor on the inlet to cut the flow down a little if you are concerned about pushing oil past the seals.
Old Dec 20, 2013 | 06:26 PM
mongorat427's Avatar
Originally Posted by samuste007
Now it works?
There severall vid on my channel.
He can put the Reluctor wheel off the 2.2 on the Saab B207 (LSJ)
Old Dec 20, 2013 | 06:28 PM
I'm going on to prepare al for mount new engine, exaust, and so on.......
Will post some pics later.
But I have a (for me) important question.
In the EFR manual from Borg Warner is written:
"Inlet oil pressure (gage) is recommended to be at least 1bar (15psi) and not more than
4bar (60psi) under all “fully warmed-up” conditions."
I know that my engine has 7 bar (105psi) oilpressure, so I think yours also.
Here are many guy's with EFR turbo so I hope somebody can telle me how did you solve this problem?
Restrictor I think . It has to be a certain kind
Old Dec 20, 2013 | 10:57 PM
I know this car is a Speedster, but the VX220 is the same thing. Kind of like the Cobalt/G5.
Old Dec 21, 2013 | 12:47 PM
samuste007's Avatar
No I didn't measure it.
Before I start to make measures and modify something and so on I thinked to asked
here because I hope to find somebody who knows what's to do.
Old Dec 21, 2013 | 01:18 PM
  #36
BlackielawlessSS's Avatar
Welcome nice car. GL with your build. This is the best site for info. If it is not on here, it doesn't exsist.
Old Dec 21, 2013 | 04:06 PM
  #37
EmperorJJ1's Avatar
in for updates.
Old Dec 28, 2013 | 04:07 PM
  #38
samuste007's Avatar
Old Dec 28, 2013 | 04:22 PM
  #39
cluelessk's Avatar
Click on the video name for it to work.
Anyway sounds mean. Looks like it'd be fun to work in that engine bay so much room.
Old Dec 28, 2013 | 04:31 PM
  #40
mexi_loco's Avatar
I like your car, your turbo, your beer, your women, and your highways. Welcome to our deranged little forum...
Old Jan 14, 2014 | 10:52 AM
  #41
samuste007's Avatar
Befor i mounted the rear clam to make the first check on the road a friend made this video.
Next weekend I will start with the mapping.
Can't wait to run with it.
Old Feb 10, 2014 | 03:39 AM
  #42
samuste007's Avatar
After fixing some small issues I have finished the base map.
Now I'm going to make the finish of the map.....but there is still to decide how much
turbo pressure and where to make the rpm limit.
Until now im running with 1,2bar (18Psi) and a rpm limit of 7200.
Don't know the HP until now, but I think (hope) it will be around 370.
Engine is a LK9 (same like a LSJ) with Wiseco pistons and eagle rods.
Here are 2 diagrammes which shows the current performance....
Third gear 100-160 km/h (62-100 mph) in 2,9 seconds
Fourth gear 100-193 km/h (62-120 mph) in 6,6 seconds
My plan is to go to 1,5 bar (22,5Psi) and 7500 rpm limit.
It is to much for a hard track use?
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
TheSandMan
Sep 20, 2015 06:02 AM
jthwjde
Sep 7, 2015 09:24 AM
Adam144
Sep 3, 2015 07:48 PM
