Nitrous Oxide N20
100 shot?
Old Aug 19, 2007 | 02:20 PM
drailSS's Avatar
100 shot?
Is there a kit that i can get to spray 100 shot without having to retard the timing that much. i was reading the NEX kit has a "shark" nozzle but i havent heard of anyone on here using it. it claims to not need timing of fuel pump upgrades. any input would be helpful thanks.
Old Aug 20, 2007 | 06:20 PM
drailSS's Avatar
*bump*
Old Aug 20, 2007 | 06:24 PM
06blackg85ss's Avatar
umm read up on nitrous man, anything over a 50 shot you should retard some timing, and your car is not gonna like a 100shot for long.
The shark nozzle is just a little bit more efficient injection method where it uses the nitrous to pull the fuel through and atomize it better for better distribution.
If you want to run a 100 shot, spend the extra money and do it right,
progressive direct port and your motor will thank you down the line
Old Aug 20, 2007 | 06:25 PM
ItalianJoe1's Avatar
Its not about the kit, you just need to keep the engine happy with that much of a shot. The more you spray the more timing you will have to take out to keep the pistons together. I would advise against a 100 shot on the stock pistons. You should be fine with a 50-75 shot, but I know of one person who blew pistons on a 100 shot, with stock tuning, not even advanced timing.
Old Aug 20, 2007 | 06:28 PM
IonNinja's Avatar
thats going to put you well over 300whp so building the motor is a given
I believe most nitrous manufacturers recommend about 4* of timing pulled for 100 shot IIRC. Just going off the top of my head on that one...
USMCFieldMP's Avatar
Rattlesnake Race Shop
If you are making 288/250 with those mods... I don't see your engine liking you for very long even off off the NOS! That's gotta be one hell of an Aggressive Tune!
Old Aug 21, 2007 | 06:37 AM
drailSS's Avatar
i have pistons going in sept. 11. studs, and gasket aswell. i was just wonding about hte timing. how will retarsing my timing affect my everyday driving. b\c i have a tuning shop i go to that can do everything with the HP software.
Old Aug 21, 2007 | 04:13 PM
Black SS 07's Avatar
dont do a 100 shot unless you do some serious reading on it..
i ran a 100 shot on my grand prix (v6 3800) for about 4 months. went thru 15 bottles. end result.. 2 popped pistons and a cracked flexplate.
but if for some crazy reason you decide to do a 100 shot at LEAST go with a direct port kit.. (and good luck)
Old Aug 21, 2007 | 06:00 PM
IonNinja's Avatar
well retarded timing of course means less power off the bottle.
so as far as I know it shouldn't effect your daily driving any you'll just simply make less power off the bottle.
Old Aug 21, 2007 | 06:40 PM
That's why you don't get a permanant retardation of power. You just get the ability to run multiple maps... and you have a NOZ map... and a No NAWZ map.
Old Aug 22, 2007 | 12:05 AM
drailSS's Avatar
yeah but if i get different maps. i would have to load up the nos map and go to the track and then load up the reg. map as i drive around. if i only retard it a little like 3-5 degs. will it make that big of a difference in my none nos power. like 270-280hp and not 290. or is it more of a difference then that?
Old Aug 25, 2007 | 07:54 AM
drailSS's Avatar
can anybody help me out? thanks
Old Aug 25, 2007 | 08:51 AM
NJHK's Avatar
It wouldn't be that dramatic but you might notice it, yes.
Old Aug 25, 2007 | 10:37 AM
drailSS's Avatar
thanks
Old Aug 25, 2007 | 11:26 AM
NJHK's Avatar
You're welcome
Old Aug 25, 2007 | 11:51 AM
Area47's Avatar
Rent me! per hour
back up a second there turbo. 288 out of a 2.85? i want dyno sheets.
Old Aug 25, 2007 | 03:28 PM
drailSS's Avatar
i already posted once. i think it was my first tune. it was 272 and now its 288 i will try to fine it at home later and post it.
Old Sep 1, 2007 | 09:53 AM
drailSS's Avatar
when i tune the motor what is the biggest shot i can do. not for everyday use just track. a whole new map i can load it just for the track. thanks
Old Sep 1, 2007 | 09:56 AM
NJHK's Avatar
wait
You're not using a wet shot?
Old Sep 1, 2007 | 10:00 AM
justin04's Avatar
ive done alot of reading i wouldnt go over a 50 shot with your mods.
Old Sep 1, 2007 | 10:11 AM
2fastforyouraSS's Avatar
im right around the same hp u r and im spraying a 55 shot I wouldn't recommend spraying anything over that, my clutch is really starting to hate life, and my internals are hanging on by a thread
NJHK's Avatar
You guys who have 60 lbs and running nitrous...I feel sorry for your fuel pump.
Old Sep 1, 2007 | 10:14 AM
I know I need to step it up a size, I went to the track I could definately tell the fuel to nitrous mixture was all fucked up, bigger fuel pump or fuel jets is next
Turbo Johnny
Feb 21, 2019 09:41 AM
SmitBag
Sep 7, 2016 08:05 AM
Oct 20, 2015 09:56 PM
dennis69
Sep 22, 2015 08:56 AM
n20saturn
Sep 21, 2015 01:50 AM
