Nitrous Oxide N20
Nitrous Guru's Please Help
Old Jan 2, 2008 | 01:14 AM
bluecobaltss06's Avatar
Well I was given a free nitrous setup. I was told before I was actually given the kit, and I was super excited because I wanted it but, at the moment I can't really afford it. So i got the kid today and its a Boon Docker ATV setup. Pics are below. I found the receipt in the box (it's new in box) and its a 700 dollar setup!!! In the kit is (this is from the booklet it came with) a nitrous manifold with fittings installed, a nitrous bottle with 4AN fitting, bottle clamps, high pressure braided hose, a 12 inch l.ength of 1/8 black nylon hose, a solenoid a solenoid holding bracket. A 1/8 inch NPT compression fitting for solenoid, a 1/8 inch NPT to 4AN adapter for solenoid, a push button switch, two mounting clamps for the pushbutton switch, a rectifier, female electrical connectors, electrical butt connectors, orificed cup plugs 1/8inch and 3/16inch. It also has 3 feet of 1/4'' tubing and 3/16'' x 3/16'' x 3/16'' barbed Tee.
Here are the pics.
Once I found out the price of the kit I immediatly gave it back, but he told me to see if it worked first. So my question to you is will this kit work at all. It's a 4 lb bottle and it holds 2lbs 8oz of gas so total weight would be 6lbs 8oz. I know nothing about this kit and have never heard of it. I didn't even know you could put nitrous on quads. So I'm gonna do some research on this kit and see what comes up, but any input would be awesome.
Old Jan 3, 2008 | 06:14 PM
Area47's Avatar
Rent me! per hour
not for your car.
06blackg85ss
83
Jan 18, 2017 04:35 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ncstateredline
Sep 10, 2015 07:22 AM
Tofu
Nitrous Oxide
25
Mar 17, 2006 01:07 PM
