Which Nitrous Kits/Setups is everyone running
Perhaps you misinterpreted what I said. Yes cyl pres will be higher on a sc car vs turbo car. I am pretty sure they will not be more immense on a ~900hp car then on a ~500hp tvs/nitrous car. I am pretty sure the motor can take it being as it is the same setup.
Besides, I remember someone saying they were on a tvs with nitrous on a built motor. I don't remember what shot or what pulley. I really need to bookmark post that are informative. Haha, Everytime, I have to go find them when I want to reread over the information lol
If I am wrong, I welcome the validated proof. I just know what I have been told and experienced, like everyone else.
Also, don't try to be condescending behind a keyboard. It makes people look like a douches. No one likes douches.
We are all friends in here, though. Some of us are just not fully informed
*raises hand*
It appears we have Bryan coming here to do our tunes so that won't be a problem. (Woohoo!)
*raises hand*It appears we have Bryan coming here to do our tunes so that won't be a problem. (Woohoo!)
maybe back off a pulley size? you will more than make up for it with N02. And it wont push everything so hard. Should see a lot more torque with the N02 then before.
Also blazin07 did a lot of nitrous along with italianjoe. might wanna see if you can get their input on good setups.
Op,
Progressive hit, back the timing off and enjoy it.
Wouldn't be a bad idea to up the pulley to a 2.9-3.15.
Gen 1 girdle will have no problem holding it.
The progressive shot will save your transaxle.
in a dry shot the fuel is delivered by your injectors in a wet shot it will be delivered by an aux. source. now befor you all hound me on this i know that most wet kits for fuel injected cars use the check valve on the fuel rail to support the (wet side) of a wet kit but i think in that case you should just run a dry kit because if you have enough fuel in the rail to support the wet kit then why not just put it through the injectors. and if you want a true wet kit run an aux. fuel pump from the tank to run a stand alone fuel system for the nitrous.
South Central *********
PROTON FLY BY WIRE NITROUS SYSTEM W/ 10LB BOTTLE
GEN X 2 ACCESSORY PACKAGE, EFI
i also picked up an MSD Digital Windo Swith and ZZP blower spacer.
im going to spray 100 wet between the blower and IM.
I still need to get a remote bottle opener.
I also am going to be running a inline fuel pump and surege tank to keep up with fuel demand as i am currently maxing my fuel system.
im likely going to feed the wet side of the shot off a spare fitting on the surge tank.
9.5:1
9.5:1
Sl0wbaltSS
Nov 21, 2018 11:11 PM
