Nitrous Wiring: 923439 Me: 1
Originally Posted by Blown 4-banger
You could use an electric core heating pad, for back aches and stuff. My dad has one it gets pretty damn hot. You could just use a power inverter.
Heating it via air conditioner doesnt work, unless its there forever..
You definitely need a bottle heater. The pressure drops fast and it literally returns to stock slowness. Ive done this plenty of times, you only get two good sprays, its all downhil from there.
yup...
I still need to get mine up and running, I installed it and couldn't get the relay to click over but haven't had time to go back and check my wiring. I hate relays...
oh Fatalis if you want I've got this Zex bottle warmer if you wanna give it a try...didn't do anything for me but if you wanna give it a try its yours.
ok since i am new to the "wet" kit i am not sure how to set up the jets.. you need jets in both the fuel and the n20 correct.. also what size do you use.. if i use a .50 n20 do i use a .50 fuel jet also??? or do they have to be diffrent.. please i need some input
-drew
-drew
Moderator Alumni
-drew
-drew
no offence but Zex is not for the win. I never like there set up's at all I just never liked them to begin with. but if you know what you are doing as far as what goes where I would recommend a NX system that is what we run and there bottle heaters our pretty nice but in the end a torch does wonders for you.
what brand nozzle do you have and what jets do you have? if you're using a Zex nozzle and zex jets then look on the zex website under the 4 cyl wet kit instructions, they list the nitrous & fuel jettings for a 55,65 and 75 shot.
Also Zex is not a bad kit, its cleaner and more simple than a traditional setup. In the end you get the same result. The only thing I didn't like is that when I was having wiring issues there wasn't **** out there to refer to for help. Everything pointed to traditional setups...
Other than that, their base kit, purge, and window switch have treated me just fine. For a bottle heater I recommend going elsewhere...
It takes longer to heat the bottle up with a bottle heater then it does with the car heater. I have been doing this for around 5 years and it work great. When you spray large amounts of nitrous you need a hot box. Hot water is the best way to heat a bottle. It give the bottle a even heat and not just around the middle. That is why I say use your heater in your car. Wrape it up in a blanket and turn it on. It will get the bottle to around 1200psi in about 10 mins.
#36
next time they fill it make sure they purge it.
#37
#38
I'm pretty sure you need to take the bottle out and put it under the vents down by your feet.
if u leave it in the trunk and just put your heater on full blast it wont do ****...trust me I tried.
I would recommend putting your bottle in warm water to up the pressure but of course none of this stuff works like a good heater because u need to maintain that pressure and once u start spraying your pressure starts dropping.
#41
Do a quick search. I started a post about it and got help from ionninja. itz in the 2.2 section. itz realy easy.
#42
Based on the raptor shift light install thread though, on the LSJ I would try the brown/white wire coming from cylinder #1 ignition coil...not sure which cylinder mode to set it to though but I bet once u get the tach signal read that'll be easy to configure. Possible 1 cyl mode...
#44
I think since our ignition setup is slightly different the wire I chose won't work for you...which was the tan wire coming off the ICM plug.
#45
actually on the 2.0 they're setup is different...they have the coil on plug setup like the 07 Cobalts instead of the big plate with the ICM plug
I know they're slightly different because when I tried connecting my raptor shift light up like the LSJ guys it didn't work right...
#46
#47
#48
oh man the pain is coming back! lol
just thought I'd point out that the MSD switch I was attempting to hook up was fried and thats why I couldn't get it to work. Switched to a Zex and been problem free...
anyway, good job with the search...now perform the same one in the how-to section. there is a how-to on the Raptor shift light in that section that tells you how to hook it up on the LSJ.
ncstateredline
09-10-2015 07:22 AM
