Nitrous Oxide N20
Zex window switch question
Old Mar 17, 2008 | 03:54 PM
cfcobalt's Avatar
Alright...tried the search button and nothing came up...
trying to wire in my window switch and can't f*%^ing find a wiring diagram that shows the tachometer signal...anyone know where it branches off????.....wire color????...anything usefel???
right now zex owns me....
Old Mar 18, 2008 | 12:42 AM
firestorm's Avatar
bump as i need the same damn info. i saw a pinout of the pcm somewhere.
i also need to know which tps wire to hook up to on the TB.
https://www.cobaltss.net/resources/pcm/05cobalt20.htm
Old Mar 18, 2008 | 12:47 AM
Red2.4SS's Avatar
Go to the dealer and find which pinout on your ECM is a tach output.
Old Mar 18, 2008 | 12:49 AM
ItalianJoe1's Avatar
Call Zex tech support. If they can't help, call Holley NOS tech line, they can tell you what wire is the tach signal. I installed a window switch on my dads truck and one of the example cars they listed was a 2.2 Ion.
firestorm's Avatar
i dont really wanna let the bag out of the cat as far as spray.
i kinda wanna plum my naws (via s/c spacer) at the same time i do my endplate cooling mod.
Old Mar 18, 2008 | 12:53 AM
JPizzle's Avatar
Do you mean the cat out of the bag?
Old Mar 18, 2008 | 12:57 AM
firestorm's Avatar
yup, but i gotta say it my way. besides, itgets the pita's all in a bunch.
Old Mar 20, 2008 | 09:02 AM
cfcobalt's Avatar
I think i finally found the answer...maybe.....who knows...
the tach signal is any wire NOT PINK or PINK/BLACK at any fuel injector...
Old Mar 20, 2008 | 01:51 PM
RollermanDan's Avatar
Fair warning to those using the Zex window switch....Also, although I can't remember which wires it is exactly, I'll try to find the diagram that I have.
Old Mar 20, 2008 | 02:50 PM
lil_kano's Avatar
its actually in the nitrous section. thats where i had found it when i did mine. its in the harness that connects to the coil-on plug on top of the motor. don't quote me but its a pinkish wire with a white strip on it (its suppose to be brown i believe but because of heat and stuff it changes almost to pink). i will double check when i get home.
check post 42
https://www.cobaltss.net/forums/show...ht=tach&page=3
see what searching can do.
Old Mar 20, 2008 | 05:21 PM
firestorm's Avatar
wouldnt the pcm pinoout....crank position sensor, pulse every revolution.???
Old Mar 24, 2008 | 02:46 PM
-the.k.w.c-'s Avatar
for tach u can go to a injector find the wire that does not repeat on each injector and that your tach
Old Mar 24, 2008 | 08:04 PM
like 60 times...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
