Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
New Return Style Fuel System
Old Jun 10, 2012 | 10:31 PM
  #76
jhaddock21's Avatar
Instructions on how to install this?
Old Jun 11, 2012 | 11:16 AM
  #77
ebristol's Avatar
I don't think anyone has a good how to on this...
Old Jun 11, 2012 | 04:27 PM
  #78
jhaddock21's Avatar
Is there anyone on here who can write up a quick how to. Doesn't need to be super detailed. Just something to get me going
Old Jun 12, 2012 | 11:19 AM
  #79
CCrunner84's Avatar
Disconnect all connections to the fuel tank (3 lines, two connectors?)
Drop the tank (4 bolts - 2 Brackets)
Remove fuel pump bucket (Use a punch and hammer to rotate the locking mechanism)
Remove the small bearing from the pressure regulator.
Reinstall fuel pump bucket and tank, leave fuel lines disconnected.
Up front remove the pulse dampner at the end of the fuel rail, attach the supplied adapter
Connect the straight end of the short hose to the adapter
Connect the angled connector of the long hose to the bottom of the new regulator, start to feed it down under the car
Connect the 90 from the short hose to either side of the regulator, plug the other side
Route the long hose along side the original fuel lines, keep it far away from the header and the over the axle exhaust bend
Attach the fitting to the other end that plugs into the return line to the tank
Remove and replace the stock fuel filter with the new setup and attach the feed lines
Modify your tune and set the base pressure
I'm sure there is something I've missed but that should get you going..
Old Jun 13, 2012 | 09:49 AM
  #80
jhaddock21's Avatar
Thanks alot!
Old Nov 29, 2012 | 04:18 PM
  #81
MP Cobalt's Avatar
Hopefully someone can give more detailed instructions with pretty pop up pictures
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
ashalle2
Sep 27, 2015 03:28 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
