Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
New Rotated Trans Mounts
Old Nov 17, 2008 | 11:34 AM
  #76
Johnboy12358's Avatar
I am interested, but confused... To install these, you have to physically rotate the engine? How would one be able to do this in their driveway?
I like the sound of this mod, but I would personally really benefit from some kind of how to... Might just be me, I am somewhat of a newb
Old Nov 17, 2008 | 12:54 PM
  #77
Josh@ottp's Avatar
I have a how to for it, I'll post it up tonight.
Old Nov 17, 2008 | 01:23 PM
  #78
N8s07SS's Avatar
Originally Posted by Dainslaif
I'd like to see a modified front mount next to a stock front mount - I couldn't tell the difference. Also, I have an 04, I'm guessing a solution for those doesn't exist yet since those mounts looked like the 05+?
For the top tier, I'm assuming that once we send you our stock mounts it only comes out to $400 +SH, yes? 500 initially then we send you our front and get a $100 refund?
It clearly sounded like it WAS hopping. >_>
The other thing that the poly bushings did was make shifting a lot firmer because the transmission didn't move when you engage the clutch. Going back to stock bushings (even in a rotated transmission) means it will be sloppy shifting again, yes?
Lastly, are you actually making the front mounts from scratch or just machining the stock ones? The price sounds high if the latter is the case ($400 for some machining, a small spacer and stock bushings?). Some may say "well what about the R&D costs?" - John said they were developed inside a week. I can't imagine he spent THAT much in a week unless he went on a bender of coke and hookers, besides, if the product really works, it'll sell in volume, so you can afford to reduce your profit margin. Having another new, even more expensive product in a long line of products 'that are guaranteed to stop hop' smells funny when you could clearly hear the wheels hopping in that video.
The reaction to this seems like the generic bandwagon mentality I've seen with every other hop reduction product. When I was stock I looked into the torque dampeners and traction bars, and everyone I asked said 'Oh these are awesome and stop hop, use them!' but it didn't stop it. Then I looked into poly bushings and a solid motor mount and everyone I asked about those said 'Oh these are awesome and stop hop more than dampers, use them instead!' except they didn't, and now everyone in this thread is running around shouting 'Oh those were crap and don't work, but these do, honest!' and while John knows more about these transmissions than most anyone else, it sounds really sketchy. I'd love to drive a car with these installed to see the difference, but I'm not about to drop $400 and find out they also don't work, just like every other product that "solves wheel hop."
Just my opinion. Good luck with it.
So your poly bushings did not even reduce wheel hop? I did the DIY poly bushings and I would say it solved it 80% on dry pavement and 15% on wet. It made a HUGE difference from stock. The big seller for me on this product is the reduction of cabin vibes. I have noticed many of my interior panels rattling & squeaking much more since I installed the poly mounts. I would love to kill 2 birds with one stone, but do agree with others that it seems a little overpriced. I think I'd be more willing if it was like $100-150 per mount, and the turnaround time better be damn fast if there is a core charge. Not sure I can just have my car out of commission for a week or so?
Originally Posted by fast98
Yes they are brand new control arm bushings and they are very durable. Also as you stated they are easy to get and replace. The lnf mount is just a little firmer then the lsj, it helps transfer power on the high HP cars. The upper trans mount is very lose and has no problem twisting anywhere, the upper engine mount also has room to move but not as much as the upper trans. You will not want to run a poly upper with this setup, it's simply not needed. The driveline angle is now straight with these mounts, the only movement you will see it that the engine is slightly closer to the firewall.
Am I missing something or are these NOT "control arm bushings"? They don't have anything to do with the control arms do they? I think it's just a matter of terminology, but it's a bit confusing.
Old Nov 17, 2008 | 02:38 PM
  #79
ralliartist's Avatar
Originally Posted by victory_red_SS
I already have all of the solid mounts in my DD (mounts soon for sale). I will be pulling these out and installing the rotated mounts once I received them. Right now I get zero wheel hop, so why am I changing them?
I want the added security for when I am at the track next year. I want to minimise the possibility of damage to my axles and transmission. The cost of these mounts vs the cost of a new transaxle makes this a no brainer to me.
Then again, what do I know?
just saw this thread, and this is the best explanation of why everyone should get these mounts. It really is a no brainer. You want added security of not breaking things, then get these mounts.
Old Nov 17, 2008 | 04:35 PM
  #80
Witt's Avatar
Just saw this myself. I bitched about not being able to purchase rotated mounts in the past.
This takes care of several problems, namely torsional windup of the axles as well as the parasitic loss attributed to the drivetrain.
Old Nov 17, 2008 | 04:38 PM
  #81
SlowBalt_06's Avatar
this is probly a noob question and most likely already covered but i'm to lazy to read..how hard is the intsall..the same as the poly mounts?i've installed a few sets of those
Old Nov 17, 2008 | 05:37 PM
  #82
Josh@ottp's Avatar
These are easier as all you have to do is bolt in the mounts, the bushings are already in the aluminum brackets. I'll have a how to up in a little
Old Nov 17, 2008 | 06:17 PM
  #83
spike's Avatar
saved
Old Nov 17, 2008 | 07:39 PM
  #84
Rodimus_Prime's Avatar
i know some others asked but i didnt see an answer posted will these work with an existing turbo tech upper mount?
if so im very interested in this mod it could save me alot of hassle next year, good job on developing products that come to market ready to go rather than asking us to finance the project unlike certain other companies
Old Nov 17, 2008 | 07:57 PM
  #85
DoMiStIc_RuSh_06's Avatar
Out of curiosity, how much would it cost for the stage 2 mounts shipped to b0s1p0, Middleton, Nova Scotia. With the exchange and everything.
Old Nov 17, 2008 | 08:34 PM
  #86
cobaltR's Avatar
subscribed......I need alittle more proof to justify the price on these. That video showed me nothing except that there is still WHEEL HOP! Last I checked....wheel hop still equals broken axles on these cars.
Old Nov 17, 2008 | 08:39 PM
  #87
UmeNNis's Avatar
Hmmm... I agree with those who say the price seems too steep. But, would be nice to see if there really will be a benefit or not. And also as stated, you will lose other benefits if you remove poly mounts/traction bars/etc when you do this.
If your interior is rattling, that can be fixed. Where are all you 'you have to pay to play' guys with that one?
If anything, stick with all the other traction mods, AND get this mod, if you think it will help as well.
Old Nov 17, 2008 | 08:46 PM
  #88
Edubs's Avatar
click...
I'll be down for these when the GB comes out.
Been waiting for this!
Old Nov 17, 2008 | 09:16 PM
  #89
brandondrecksage's Avatar
I kind of like the vibrating. Feels more connected and cough:::you have to pay to play:::cough..lol
I have poly trans mounts and ttr upper mount. i get no wheel hop on the street, but still get bad wheel hop on the track.
Old Nov 17, 2008 | 09:47 PM
  #90
RBC's Avatar
RBC
So does stg 3 include both 1&2?
Old Nov 17, 2008 | 09:52 PM
  #91
sput's Avatar
Would it be advisable to remove the ingalls torque dampener with these mounts installed or is it better to leave it in place?
Old Nov 17, 2008 | 10:11 PM
  #92
Dainslaif's Avatar
It's been asked - you need to go back to a stock top mount. The TTR one doesn't allow the movement that having a rotated engine will cause. Same with Ingalls.
It helped a bit more than the torque dampers, but it still didn't stop it completely. I can still hop on command if I want to. I have a feeling that even with this installed I could as well.
Yep. Considering it uses stock trans mounts, I'd be willing to bet a large part of the hop reduction in that video was from losing power delivery to the ground (since the transmission will move around without the polys).
  #93
cobaltR's Avatar
Pay to play.....I've got no problem with that....but I read it elimanated wheel hop...then watched the video.....its obvious that it did not eliminate all the wheel hop. I need to see all little more proof and testimony from other members to justify its price.
Old Nov 17, 2008 | 10:16 PM
  #94
chris88z24's Avatar
That car in the video still hopped....
not impressed. That was also on the street... at the track that car would have broke.
Old Nov 17, 2008 | 10:24 PM
  #95
cobaltR's Avatar
Thats what I'm saying...and I assuming that was the stage 3 setup....soooo $400+200 in core charges upfront for something that is still gonna give me wheel hop which still=axle death..... If more proof comes.....with a slightly lower price...done deal...otherwise I'd stick with polys and deal with the vibes.....I'm not trying to diss OTT because they make great products....but I think this a good step in the direction of fixing this issue.
Old Nov 17, 2008 | 10:55 PM
  #96
Dainslaif's Avatar
I would be really curious to see what would happen with poly mounts inside the rotated brackets. Best of both worlds.
Old Nov 18, 2008 | 02:08 PM
  #97
did i miss a post, wheres the video?
Old Nov 18, 2008 | 02:21 PM
  #98
Area47's Avatar
Rent me! per hour
not all cars that wheel hop break.
mine is proof of it.
Old Nov 18, 2008 | 03:07 PM
  #99
csementuh's Avatar
Click...
Old Nov 18, 2008 | 03:23 PM
  #100
N8s07SS's Avatar
I see what ur sayin, but i think his point was that this part is CLAIMED to ELIMINATE wheel hop, yet the vehicle equipped with said part still had wheel hop.
