For Sale LNF DI injectors & fuel rail w/ pressure sensor
1 LNF DI injector used, $100
Fuel rail complete with wiring harness and pressure sensor - $150
PM me for paypal info.
Not likely, I had a misfire on #3 under load, found no mechanical/electrical cause. Ring lands & valves, coilpacks & plugs all ok. Went to swap the injector on #3 and found it had no teflon seal. Compression has always been lower on mine on #3 until today. Now they are all 165-167. I think it was left out upon assembly but the blowby for all the miles looks like it may be cooked. I wouldn't trust it but it's probably fine also. I had purchased the entire injector assembly, rail & all so I swapped 'em out today.
Injectors new range from $225 to $275, last time I checked they were on national backorder from GM.
IDK about the rail, never priced it separately. I found 4 injectors, rail et al so I jumped on it before I found my issue was just the missing seal on #3. Installed the new lot since I purchased it complete. Mine was $700 surplus. You'll have to shop around.
The rail I'm selling held 2800 psi fuel pressure fine for months. If someone wants to risk #3 is still fine, (prob is) I'll throw it in with another injector purchased for free.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
roth
Sep 26, 2015 12:16 PM
