Wanted Manifold Gaskets and Studs/Nuts
Old Feb 11, 2010 | 05:05 PM
BULLETSSMOKE's Avatar
Before I go to the dealer and get my ass handed to me with an invoice I was wondering if anyone had the following:
1. Lower exhaust manifold gasket; the one where the header and downpipe meet
2. Downpipe to catback gasket; just like it says, the gasket that connects the downpipe and catback
3. Manifold studs x3
4. Manifold stud nuts x3
This is all for the LSJ (2.0 Supercharged) header and downpipe.
Old Feb 11, 2010 | 09:01 PM
ItalianJoe1's Avatar
Unless you have your heart set on replacing the studs, best bet is to just put bolts back in. 3/8-16 thread, get some nice grade 8 bolts, put a little anti-sieze on them.
I've removed so many stripped studs from stock LSJ manifolds, I hate using them over again. Dunno what they use from the factory, but it's a shitty material.
Old Feb 11, 2010 | 09:49 PM
How do you take broken studs out btw? I guess I could get new bolts.
Old Feb 12, 2010 | 02:42 PM
I've always had the manifolds out of the car, so I just grab whats left with some vice grips and twist it out after a good soaking with PB Blaster or a similar penetrant. If they don't snap, there is a hex end to them, put a small 6-7mm socket on them and take them out.
If they do snap off in the manifold completely, drill them out and helicoil the manifold. I've never seen that happen personally, and i've dealt with over a dozen LSJ manifolds myself.
Old Feb 12, 2010 | 02:45 PM
jonxxxedge1's Avatar
you can get the gaskets at autozone pretty cheap
Old Feb 12, 2010 | 02:47 PM
Staged07SS's Avatar
Administrator
Administrator
i have one of these from my ss/sc. it only has about 1000 miles on it. ill sell it to you for $5. they are about $6 new on CED + S&H.
Old Feb 12, 2010 | 02:49 PM
ls1fbody's Avatar
Haz l33t wheelz.
You can get all of that together from CED for 40 bucks.
http://www.crateenginedepot.com/stor...P1801C146.aspx
Old Feb 12, 2010 | 02:57 PM
Yeah I know, and then theyll rape you on shipping.
I was hoping to get all of it for about $20.
I'll probably just get bolts and nuts from autozone and the gaskets from Chevy. I'm going back to stock and I never want to see anything before a catback on my car ever again. I hope the bolts will hold up and not come loose.
Old Feb 12, 2010 | 03:02 PM
you can probably find the gaskets at an auto parts store as well. just pretty standard 2 and 3 bolt flanges.
Old Feb 12, 2010 | 03:48 PM
True but isnt factory on factory better?
Old Feb 12, 2010 | 03:51 PM
Staged07SS's Avatar
Administrator
Administrator
i went to autozone to try and find a gasket for the downpipe once, and what they had was complete junk. stick with gm man. you should pick up the gasket i have for sale man. i wont charge for shipping. $5 is a good deal for it. its pretty much brand new.
Old Feb 12, 2010 | 03:53 PM
header to dp gasket or dp to catback gasket?
Old Feb 12, 2010 | 04:24 PM
Staged07SS's Avatar
Administrator
Administrator
header to downpipe gasket
Old Feb 12, 2010 | 05:02 PM
Yeah, factory gaskets are MLS, which is nice. You're looking to save money though, so...
Old Feb 12, 2010 | 05:08 PM
A couple dollars versus another exhaust problem is totally worth it. Exhaust leaks f*cking suck.
Old Feb 12, 2010 | 05:13 PM
Agree 100%. I had to find a copper dp-catback gasket to keep them from blowing out, but it was well worth the trouble, never leaked again. I blame it on my crooked XTC downpipe though.
Old Feb 12, 2010 | 06:11 PM
What do you mean by a copper gasket? I also think I need to have my downpipe to header flange machined on the downpipe.
Old Feb 12, 2010 | 06:41 PM
A gasket made out of copper. Popular in turbo setups because they don't blow under high pressure.
Old Feb 12, 2010 | 09:34 PM
hmmmm
Old Feb 12, 2010 | 10:09 PM
06G85's Avatar
Don't you ever put Studs and Nuts in the same sentence A-GAIN! That's just gross...
Unless they're
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
