Wanted Midlength Header/Catted DP Combo
Old Mar 28, 2010 | 01:38 PM
Mr_Slobalt's Avatar
Must be local (Indiana) or close enough for me to drive in a few hours to pick up, and it must have a catalytic converter!
Let me know what you setup have for the LSJ and your price. CTI, Hahn, Vibrant, or anything good..... NO SHORTY, ZZP, PACESETTER, OR WEAPON R midlength
I prefer stainless steel, but I don't absolutely need it! Extra O2 sensor bung, 1.75" primaries w/3" collector, and being able to bolt to stock catback would be great.
You can PM, comment on this thread, or reach me at ericv84@gmail.com Please send or post pictures.
*PENDING ON QWIKREDLINE'S*
Old Mar 28, 2010 | 08:14 PM
G11's Avatar
G11
i have one but haven't decided if i want to fix it or to get sell them
Old Mar 28, 2010 | 08:33 PM
Mr_Slobalt's Avatar
Utah is a bit of a stretch
Old Mar 29, 2010 | 11:36 AM
G11's Avatar
G11
ya i know lol but it has all of the options you are looking for including the plus sides! only problem with them is they leak at the flange between the header and dp...trying to see if a remflex gasket will work out or not
1.75" primaries, 3" collector and dp w/ hi flow cat, wideband bung w/plug, 2.5" exit, and 304 stainless... i also have the extension for the rear o2 sensor still! has less than 1000 miles on them
Old Mar 29, 2010 | 10:20 PM
Mr_Slobalt's Avatar
let me know what you find out about the flange part.... now that I think about it, I may just want to take ZZP off of the list unless I weld the bastard hmmm
Old Mar 29, 2010 | 11:35 PM
G11's Avatar
G11
well i just need to figure out with the remflex i will swing by a exhaust shop and see what they can do! they told me it is a lot thicker and if you wanted i could get the gasket for you at no extra price cuz i just found out that my syncros are bad in my tranny so i need all the money i can get right now!
Old Apr 3, 2010 | 08:01 PM
Mr_Slobalt's Avatar
IDK I'm really wanting to pick it up, but I don't want to drive that far. The last few times I paid for parts on here I got screwed. Sorry.
Old Apr 3, 2010 | 08:06 PM
nicksredline's Avatar
i have a zzp header dp combo but i would have to swap back to stock setup if i do sell it... its 1.75 to 3 inch to 2.5( i have a spare o2 bung u can have welded in and its catted) give me a price and ile see if its worth it to take it off or not lol
EDIT: i seen u took zzp off the list but now there combo is fixed and they are having no problemsd from what i know ive had mine for like 20k miles and no problems
Old Apr 3, 2010 | 08:10 PM
Mr_Slobalt's Avatar
is the header stainless steel?
Old Apr 3, 2010 | 08:20 PM
G11's Avatar
G11
no bueno on mine?
Old Apr 3, 2010 | 08:54 PM
Mr_Slobalt's Avatar
Yeah, I'm taking ZZP off of the list. I thought they fixed the flange leak issue a long time ago. I know their flex sections used to come apart and that's probably still the case. I don't want my exhaust coming apart from "not having mounts" or by not welding the dp to the header. I just don't feel comfortable spending that kind of money only to have issues down the road. :/
Old Apr 4, 2010 | 02:24 AM
G11's Avatar
G11
ok sounds good man gl!
Old Apr 4, 2010 | 03:10 AM
xander40's Avatar
https://www.cobaltss.net/forums/parts-66/vibrant-header-downpipe-sale-189667/
Old Apr 4, 2010 | 06:33 PM
i am almost serton zzp fixed there flex section... it used to have like 4 spot welds on it to hold it on and now its welded all the way around instead of being takced on.
Old Apr 4, 2010 | 08:57 PM
xander40's Avatar
yes it is, i got my set up last month, 1.5" primaries 2.5" catless dp for 331 shipped and it's welded all the way around
Old Apr 5, 2010 | 08:27 PM
Mr_Slobalt's Avatar
lol this is so confusing!
ok, I will call ZZP tomorrow and see what's up
Old Apr 5, 2010 | 08:32 PM
Mr.N00bLaR's Avatar
Our downpipes are made from stainless steel. No worries about rusting or paint flaking off. It costs a little more but we feel it's worth it. All welding is done to the strictest of standards and bears a professional finish. Weld quality is higher than any other downpipe manufacture and a sample of one of our welds can be seen here: WELD We promise our welds to be 100% leak free. Even the flanges are stainless, which isn't something most companies can say.
Seen below, the stock pipe narrows down to a 2" hole before lowering into the cat. This is very restrictive, causes KR and a loss of HP.
Our 3" downpipe includes a Magnaflow converter, which flows 40% more than the stock unit. It eliminates the 2" restriction and the dimple where the O2 sensor normally resides. Look for gains of 5HP on a stock engine and over 10 on a modified Cobalt.
No welding or special tools required, 1/2 hour install. O2 bung and factory style hangers. Available in a mandrel taper to 2.5", 3" flanged exit for 3" cat back or a 3" weld in.
**Shipping charges are based on dimensional weight
***Due to the movement of the engine on WOT shifts, 1 or more solid engine/trans mounts will be required. If they are not used, then the flex sections warranty is voided
Source: http://www.zzperformance.com/cobalt_...=540&catid=188
Old Apr 9, 2010 | 01:39 AM
Mr_Slobalt's Avatar
I'm avoiding ZZP like the plague
Northindy
Oct 31, 2015 01:35 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
goaliemo
Sep 28, 2015 01:37 PM
frost3
Sep 3, 2015 12:20 PM
Josh@ottp
Aug 31, 2015 01:16 PM
