WTB Idler Pulley Tension Relief Tool
Old Jun 2, 2008 | 12:46 PM
godsfshrmn's Avatar
Looking to buy one asap. Stupid shoddy GM design has already rounded off...
Old Jun 2, 2008 | 12:48 PM
LamboW9's Avatar
if the corner is rounded on your tensioner then hammer down a 14mm instead of a 15 an then jus pull it off...its what i did an it came off easily when i was done
Old Jun 2, 2008 | 01:06 PM
godsfshrmn's Avatar
Thanks for the tip. How hard would it be to remove the whole thing and machine it down?
Can I still use this tool if it gets worse?
Old Jun 2, 2008 | 01:28 PM
LamboW9's Avatar
theres really no need to machine it down...do you mean so you can make it a square again?...wat would be the point?....the 15mm wrench is loose anyway an when you hammer down a 14mm on it, it makes it easier than the 15 cuz its tight an theres no play to come off when your pushing the tensioner down
Old Jun 2, 2008 | 01:34 PM
06_SS_S/C's Avatar
I took my dremel and grinded down one side until a 14mm fit on there snugly. working good so far.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
patooyee
Oct 1, 2015 01:07 PM
