My 335i Top Mount Project
#51
Aside from pressure, can the stock fuel lines handle the massive amount of volume needed to supply e85 to the entire fuel system without heating the snot out of the fuel? That just seems like a ton of fuel to push through those little fuel lines.
Wow. So the port injector setup is essentially just a manifold spacer with injector ports and billet rail? Now that's pretty slick! No need to modify the manifold and you have less heat transfer to the manifold. Me likey!
What did that setup set you back and what size injectors are you using? 1000cc?
#52
As well as being able to change to 8 different maps on the fly at a push of a button while the car is on and driving etc. The JB4 is a great tuning device/tool.
We shall definitely find out tho, that is why I am a beta. I am pushing the limits of the N54 where others have only dreamed of. I have the second highest hp 335 in the world, so it's hard to tell what can and can't be done . I'm the one that will figure it out for all of us tho!
Yep, that is exactly what that is! Retain the plastic manifold, it is better for heat compared to aluminum etc. As well as just being clean, nobody can really tell I have port injection at all.
Rail and spacer kit, with injectors and AIC1 with harness everything should be around 1600$ retail. I am a vendor so I get wholesale pricing which I can't disclose of course lol.
550cc injectors from Bosch.
52lb/h 550cc Bosch Fuel Injector w/ EV6 / USCAR Connector - 0280158117
I just wish there was a way to just modify the stock HPFP to make it flow more and still retain the pressure it needs for the rail. It's literally impossible to modify. The injectors in my car are rated at 3300cc each. If that could some how be done it would be great.
Problem with spraying all this meth and port injection for fueling is that I can't NLS. The amount I am spraying is enormous. That one second can mess it all up and blow the intake manifold apart if it catches. I heard ethanol doesn't detonate as much as meth, so I shouldn't have that issue with PI and NLS. Who knows tho, it would be great to no lift with this bigger turbo.
#54
#55
Wouldn't mind a nice 2010 again. I'm trying to find my old one with the built motor and stuff but its hard .
I don't go canyoning as much as I used to before. I haven't been to a meet in a long time either. I'll probably go down to a meet soon and just cruise on a sunday. I miss those days.
n20saturn
09-30-2015 12:26 AM
