My HID Retrofit project
Originally Posted by IonNinja
do my retrofit for free or I'm going to buy a 5K HID kit...and drive behind you, everyday...of your life.
Originally Posted by Hutnek
Mine too, or I'll buy a 5k HID kit and drive facing you, in reverse, everyday, and post pictures of you squinting! LOL
Originally Posted by Brian MP5T
BS, they make a HID low Beam convetional High beam combo bulb for the Mazdaspeed.
The only OEM HID bulbs are D2S and D2R.
Originally Posted by Mercury
Xenon combo bulb? Please enlighten me. And I really hope you aren't talking about those HID kits that move the bulb up and down....
There are two bulbs attached in close proximity. One is HID and set to Low Beam. One is conventional set to High. The only negative is the cost. If your High beam craps out, you need to replace the entire light.
Or is it one of those things on ebay like this?
Now is this an OEM Mazda part?
dude where did u find thouse???
i want my high beams back!! i love my HID's but high beams would be cool!
Dont s2000's have the same bulb set up as these. I ask because my friend has one and he has HID's but his high beams are a regular type of light.
They do have "high beam low beam" HID's they are called Bi-Xeon and work by using a tiny servo to remove the cutoff and blinding anybody near by and maybe incinerating small birds, lol, but seriously bi-xenon's are great if you dont have the room for a low beam and high beam projector!
There is no OEM bulb that looks like that
Here is the thing, My Protege 5 has 4 bulbs up fron to I don't have to **** around looking for High and Low. I simply change the Low Bulb to Hid and it's done.
It's a product that I have seen alot and it solves the High Low Issue.
The Blue are LED's in the High Beam as Running Lights..
Not OEM,
You are talking about Bi-Xenon projectors right?
http://www.hidplanet.com/forums/ have you been to that site yet they have lots of help and lots of guys that know there ****!!!
What balasts are you using, and do you have any plans on how you are going to make the shroud?
Okay you have what you have, but you called BS on what I said which you weren't correct in trying to call me out on. There is no such thing as an HID Highbeam bulb. That crazy thing with a halogen thing beneath the Xenon capsule is not a single HID Bulb, as it is two bulbs based together, one HID, the other halogen.
I thought you meant a dual Hi/Low HID Bulb for replacing the stock one.
As you know, normally people lose the function of the High Beam when they switch to HID with a light system like on the cobalt. I was just trying to inform this forum that it is not required to loose the High Beam.
As you know, normally people loose the function of the High Beam when they switch to HID with a light system like on the cobalt. I was just trying to inform this forum that it is not required to loose the High Beam.
If your High beams are loose you should tighten them
If you LOSE your highbeams, then you need bi-xenon projectors.
HID's with no projector are the devil. I HATE HATE HATE them. 5000k+ kit are a joke made by someone painting normal HID bulbs blue and selling them to ricers and laughing as they actually make money off of the crap.
