Turbo 2.4 up and running but not great...video inside
Old Apr 4, 2007 | 11:24 PM
SilverSS/SC's Avatar
Good luck with the tuning , though complicated .....the 2.4 PCM sounds interesting to play with once all the tables are accessible .
Old Apr 4, 2007 | 11:32 PM
Witt's Avatar
Originally Posted by PpAzZ1101
I'm sure we'll figure it out. It'd be easier if Dan wasn't in Michigan. He could read it and then we'd check this out in HPT. The tuner left the PCM unlocked so we could play with it.
You guys should of asked him if he ended up recalibrating the MAF, I bet its not only out of cal, but being run out of range.
I couldn't make it today, I got stuck in Willard in a hotel, won't be back till tomorrow, but if you guys need any help, you all have my number.
Old Apr 5, 2007 | 06:02 AM
Brandon97Z's Avatar
Check with boostedsol from the solsticeforums. He's used the LS2 to edit his turbo set-up, althought he's running an extra set of injectors so that might not help much with the fueling problems since you just went with bigger injectors.
Old Apr 5, 2007 | 09:04 AM
celicacobalt's Avatar
thats a good point, maybe on the next tuning session you could come with us and see whats up
also, my installer couldnt seem to locate and 2 step colder plugs for me to run, would any of you know exactly what plugs work for the 2.4 that would be 2 steps colder
Last edited by celicacobalt; Apr 5, 2007 at 09:04 AM. Reason: Automerged Doublepost
Old Apr 5, 2007 | 09:08 AM
WSFrazier's Avatar
I assumed plugs for the 2.0 would work with the 2.4. But assuming isnt always right.
Old Apr 5, 2007 | 10:14 AM
GTP's Avatar
GTP
Al..I was voicing my opinion on the MAF too. Tuner dismissed it right away. I still think its a MAF related issue. Gotta be!
Old Apr 5, 2007 | 10:30 AM
BlueThunder2006's Avatar
Not bad, not bad... should be pretty quick once you get the lean issue ironed out. I'm interested to see what kind of quarter-mile times it turns, keep us posted on when you plan on going to PRP this summer.
Old Apr 5, 2007 | 11:03 AM
well if this is solved by the 22nd ill be racing that day
got my cel codes read here they go:
P0121
The PCM has determined that the actual input from the
throttle position sensor does not match the calculated
input for the throttle position sensor derived from
the input gathered from the other sensors ie: manifold
absolute pressure sensor, idle air control motor
position, ECT.
P0172
The PCM has determined that dring testing, the fuel
system for bank 1 was too rich. (Bank 1 identifies the
location of cylinder #1, while bank 2 identifies the
cylinders on the opposite bank)
also, i wanna report that my coolant temps are up by about 5 degrees into 203 even though i am staying in vacuum
Last edited by celicacobalt; Apr 5, 2007 at 11:03 AM. Reason: Automerged Doublepost
Old Apr 5, 2007 | 11:20 AM
06blackg85ss's Avatar
P0121
position, ECT.
P0172
how did you run the maf? pull through or blow through
You'll never be faster than the ss/sc
that was just a joke people to keep you on your toes
Old Apr 5, 2007 | 11:42 AM
maf is before the turbo
Old Apr 5, 2007 | 11:48 AM
  #36
PpAzZ1101's Avatar
Pull through... MAF sensor is before the turbo.
I got the joke.
Old Apr 5, 2007 | 11:49 AM
  #37
TCarter's Avatar
good job Celica, you make me proud.
Old Apr 5, 2007 | 03:13 PM
  #38
saunders1986's Avatar
man, it always takes someone to lead the pack, and thats what ur doin! once u get these issues figured out, u'll have **** loads of fun, you have some very big ***** to take this on!!!.......good luck! i cant wait to see this finished
Old Apr 5, 2007 | 03:23 PM
  #39
LewiSS's Avatar
See above.
My 2.4 on the dyno shows that same drop in HP and torque at 3750, then a sharper rise in both than before the drop. I don't think your lean spike is causing the drop, I think the drop is causing the lean spike. The reason I say that is because mine doesn't exhibit that lean spike, but does show that drop at 3750. We assume that 3750 is the switch point for the cam. As the cam advances, there is some drop in HP and torque as overlap goes up, and then it picks up better than before as the revs rise. I think GM may have put the switch point just a hair early, or it's done on purpose so the switch doesn't cause a HP spike if switched later.
Anyway, bottom line is that stock 2.4's show this little dip at 3750. What it doesn't show is that earlier spike, which I assume is where boost comes up. It would be beneficial to add a plot line for boost to this so you can see if boost rise is causing the lean spike.
Keep it in mind as you tune.
Are you monitoring the knock sensor? If you're not getting knock retard, then it might not be too lean (but it looks REALLY close!).
  #40
Witt's Avatar
The first code is gonna have to be disabled, your VE table isn't setup to see boost, and won't be able to until cam phasing can be locked and logged. The p0172 code is because the MAF is out of calibration.
Old Apr 5, 2007 | 03:24 PM
  #41
Cobalt_SSTuner's Avatar
that is sweet, good luck with tuning
  #42
nramlow2006's Avatar
dude im so impress have fun!!!!!!!
Old Apr 5, 2007 | 03:28 PM
  #43
hoffa's Avatar
i can't wait to see the end result of this! i've been waiting for someone to do this to their 2.4, considering i have one as well
(don't let the sig fool ya... i'm ss/na)
Old Apr 5, 2007 | 03:34 PM
  #44
then fix your sig! its soo misleading...
Old Apr 5, 2007 | 03:40 PM
  #45
GTP's Avatar
GTP
I agree..I also didn't hear a vac leak. But that doesn't mean anything my ears are shot.
Old Apr 5, 2007 | 03:59 PM
  #46
LewiSS's Avatar
MAF, or MAP? If MAF, then is it because of too much air flow? I could understand MAP being out of cal under boost, since it will swing over to positive.
I don't see how cam phasing will have any effect on any of the parameters that need to be logged/changed for boost (namely, fuel flow and ignition retard).
Old Apr 5, 2007 | 04:02 PM
  #47
Witt's Avatar
Cobalt PCMs fuel exclusively from the MAF readings and only use MAP for correlation checks and MAF failure.
Because the VE table is based partly on cam phasing, changing any values would be always incorrect since cam phasing will always occur as preset values that cannot be changed or even logged.
Old Apr 5, 2007 | 04:23 PM
  #48
bigworm's Avatar
I strongly agree with witt on this. you need someone to calibrate the maf and then tune your PE... i hate to say it but the guy you had to tune doesnt seem like the best choice...
as for the codes, dont freak out those are typical codes you'll need to disable. your only boosting 10psi, you shouldnt need to replace the map.
It does suprise me tho that the maf is on the turbo inlet, just changing to this location alone will require alot of maf calibrations. just find someone with hpt-EIO and a wideband... these issues are simple to fix.
Old Apr 5, 2007 | 04:27 PM
  #49
LewiSS's Avatar
Thanks!
I always learn from your answers - that's why I ask!
Are you suggesting putting the MAF between the turbo and the throttle body (in the pressurized intake stream)?
Old Apr 5, 2007 | 04:30 PM
  #50
Witt's Avatar
I'm learning about them just as much as anyone, I just benefit from the fact that I have redline dan (djt81185) and a few others (WSFrazier, PpAzZ1101, etc) as drinking buddies as they are tuning geniouses.
Edit: My opinion on putting the MAF after the turbo (blow through) may be one way to get around having to upgrade to a larger MAF, but will detract from the sensor's precision. all imo tho.
