Turbo 2.4 up and running but not great...video inside
Old Apr 5, 2007 | 05:00 PM
  #51
PpAzZ1101's Avatar
Originally Posted by Witt
I'm learning about them just as much as anyone, I just benefit from the fact that I have redline dan (djt81185) and a few others (WSFrazier, PpAzZ1101, etc) as drinking buddies as they are tuning geniouses.
Edit: My opinion on putting the MAF after the turbo (blow through) may be one way to get around having to upgrade to a larger MAF, but will detract from the sensor's precision. all imo tho.
Au contraire.... I learn from you and Dan (djt81185). I am just a learning apprentice in the tuning world.
I did surprise myself though... I had a few ideas yesterday while watching the charts on the dyno. My ideas were all mentioned in the information I found while searching online today. Just too bad that none of them applied in this case.
I really think we just need to get a wideband on this car and take it out ourselves. I'm pretty confident we'd be able to iron this out on our own.
Also, I agree on the MAF sensor placement. Pull-through should allow for more accurate readings on this setup. Too much turbulence in the charge piping... especially with these smaller pipes with a lot of bends. I think the longest straight piece in the entire setup is where the MAF sensor is now.... and the recirc entry is pretty far up the pipe from the sensor. It's pretty much ideal placement IMO.
Old Apr 5, 2007 | 05:07 PM
  #52
Witt's Avatar
I agree with this X100. The car is going to need more than just a dyno tune to smooth PE. Since its a daily driver in a county where OBD2 emissions are a must, every sensor should be decently recalibrated.
Old Apr 5, 2007 | 05:17 PM
  #53
GTP's Avatar
GTP
Cobalt PCMs fuel exclusively from the MAF readings and only use MAP for correlation checks and MAF failure.
Same with Subaru systems and I brought this up to the tuner yesterday. He just looked at me.
I guess I'm dirt...
Old Apr 5, 2007 | 05:18 PM
  #54
potatoe's Avatar
This sounds like my frenzy trying to tune my twincharged setup....
Old Apr 5, 2007 | 05:19 PM
  #55
Witt's Avatar
Originally Posted by GTP
I guess I'm dirt...
OMG, come out for a beer once and a while then. grrrr
/end threadjack
Celica, any chance you can make it out towards Robinson or Monroeville tonight for some wings and tuning?
Old Apr 5, 2007 | 05:26 PM
  #56
GTP's Avatar
GTP
/end threadjack
Just call me. Only one who calls me is Dano X2. Don;t blame you guys though who wants to hangout with a DAD.
Old Apr 5, 2007 | 05:40 PM
  #57
LewiSS's Avatar
Agree on the MAF, which was why I was asking.
The Alpine set-up that will be going on my 2.4 Auto next week will use the SMT-6 for tuning. Obviously I'll report back on tuning issues with it. What we come up with there can be directly applied to your situation, just programming a different processor.
Old Apr 5, 2007 | 05:59 PM
  #58
GTP's Avatar
GTP
Alpine uses a pull through set-up right? I would think that blow through set ups are a recipe for MAf turbulence and although tunable, it tends to throw CELs later on.
Old Apr 5, 2007 | 06:06 PM
  #59
LewiSS's Avatar
Yes, Alpine places the MAF between the filter and the turbo inlet. John there was commenting to me that you want it in the straightest run with the lease turbulence, which is the same thing you all have been talking about.
I'd also worry about sealing a MAF in the pressure tube - while it is relatively easy to seal it to the tube, the MAF itself isn't designed to hold pressure and I'd wonder where it would spring a leak (I can just see it blow the connector off like a champagne cork!). Also, does the MAF also act as the inlet temp sensor (ambient air temp sensor)? If so, then ambient temp going into the engine would actually be more accurate with the MAF in the boost tube. But it might not be worth the other hassles just to get this precision.
Old Apr 5, 2007 | 06:17 PM
  #60
celicacobalt's Avatar
/end threadjack
that sounds awesome but im at work till 10pm tonight i actually wont have a day off till wed of next week, but if garrett,pcmforless,asaperformance and you guys figure out the issue before then , that would be a call off day i guess.
im a dad but then again that makes me not be able to hang as much lol
Last edited by celicacobalt; Apr 5, 2007 at 06:17 PM. Reason: Automerged Doublepost
Old Apr 5, 2007 | 06:39 PM
  #61
PpAzZ1101's Avatar
I don't think we'll figure anything out without seeing your tune. We have some ideas, but there's no way to tell if they might work without seeing what Brian did to the car already.
I guess I'm dirt...
Aw come on... you know I meant you too. I just mentioned Dan and Al cause that's all that Al mentioned in his post. You teach me a lot about the hardware and the setup as well as the tuning.
Old Apr 5, 2007 | 06:42 PM
  #62
well id like you guys to look at the car, are any mornings good, i dont leave for work till 1230 everyday. other than that i gotta work till 10pm most nights
Old Apr 5, 2007 | 07:23 PM
  #63
GTP's Avatar
GTP
Its ok...I was just yankin yer chain. i am MIA most of the time I know. I've had a tough year, I hope everyone excuses me. (BIG CYBER HUG)
Old Apr 5, 2007 | 08:34 PM
  #64
djt81185's Avatar
SHENANIGANS...shut your mouth!!!!!!!!!
Dan runs back and looks at his blow thru maf and whispers:
"its ok baby he didnt mean it...you'll work just as intended evil laugh"
Old Apr 5, 2007 | 08:41 PM
  #65
potatoe's Avatar
Mines also blow thru dan.....
Old Apr 5, 2007 | 09:21 PM
  #66
PpAzZ1101's Avatar
Haha... it's ok. Your turbo has to actually spool in order to produce any pressure in your charge pipe.
Old Apr 5, 2007 | 09:54 PM
  #67
Witt's Avatar
O no u di'int!
Old Apr 5, 2007 | 11:02 PM
  #68
well, the tuner said he wants to erase everything now and start all over...
Old Apr 5, 2007 | 11:26 PM
  #69
zomghax's Avatar
also, my installer couldnt seem to locate and 2 step colder plugs for me to run, would any of you know exactly what plugs work for the 2.4 that would be 2 steps colder
NGK LTR7IX-11 is 2 steps colder than stock.
Old Apr 5, 2007 | 11:38 PM
  #70
whats the code for our stock plugs?
Old Apr 6, 2007 | 12:00 AM
  #71
zomghax's Avatar
According to the NGK website, ILTR5B11 is our stock OE laser iridium plug.
Old Apr 6, 2007 | 09:10 AM
  #72
GTP's Avatar
GTP
Have fun with those CELs senior boost.. (GTP hopings he's wrong)...
Old Apr 6, 2007 | 09:11 AM
  #73
well i figured now that im just gonna go 1 step colder for street use and mild boost with the NGK Iridium LTR6IX-11 , thanks for the help ill go pick these up now
Old Apr 6, 2007 | 09:54 AM
  #74
GTP's Avatar
GTP
Kinda makes you wonder why the shop said "there are no plugs out for this car...???"
Old Apr 6, 2007 | 10:43 AM
  #75
zomghax's Avatar
NGK LTR5ix11 is actually stock heat range plug for a 2.2L ecotec J-Body. There are 6ix and 7ix heat variations for these plugs. (I have 6's at home that I bought last year from sparkplugs.com)
The 2.2/2.4L Cobalts use slightly different plugs, and last time I was looking there were no heat variations available. That's probably why the shop said that.
