05' Cobalt won't start HELP please
Old Sep 6, 2010 | 02:29 AM
brandon11482's Avatar
05' Cobalt won't start HELP please *Resolved*
I have a Cobalt that all of a sudden won't start. If I turn the key on the only light that turns on in the instrument cluster is the amber security light (car w/ lock icon). No other lights turn on at all, and turning the key does nothing.
Battery is good / keyless entry works etc.
Car also has a Viper 5701 alarm and a XK06 bypass. Everything was working fine for months until now...
Tried: turn the key on and left it for 10+ mins. which is supposedly supposed to reset the Passlock 2 system... nothing still.
any help would be greatly appreciated.
-Brandon
Old Sep 6, 2010 | 02:41 AM
xmusic_addictx's Avatar
I'm actually having the same problem right now. Was trying to hook-up my HPT to even try and fix this, and I cant even connect.
Old Sep 6, 2010 | 02:48 AM
Damn. In your instrument cluster is the Amber lock light the ONLY light that turns on too?
Old Sep 6, 2010 | 02:50 AM
Yup, it sure is.
Old Sep 6, 2010 | 03:01 AM
Yup, it sure is.
Is your light on solid or does it blink?
Old Sep 6, 2010 | 12:07 PM
07blackss86's Avatar
Sounds like you could have a bad passlock sensor, especially if you tried the reset procedure and still get nothing. I just had to replace the sensor on my wife's Alero last month because the same thing happened.
Old Sep 6, 2010 | 12:26 PM
bbrewbaker's Avatar
Make sure that the starter will for the alarm isn't bad.
We had that problem with our 05 Monte. It ended up being that the trigger wire for the starter kill for the DEI remote start came loose.
We were going to have the car towed to the dealer. Then after about a hour of searching i found a wire that looked like it belonged on a wire tap.
So i connected it. Turned the key and it started right up.
Also the remote that worked again that hadn't for a few months.
Old Sep 6, 2010 | 12:45 PM
Thanks for the responses guys, 06black, do you remember what the passlock sensor looks like? is it like a black box under the driver side foot-well on the right or up by the ignition?
Thanks again.
-Brandon
Old Sep 6, 2010 | 12:50 PM
reddevil's Avatar
my neighbor is having the exact same problem with his explorer, it is not identifying the key..
told him to let it sit for 30 minutes and try with another key..
Old Sep 6, 2010 | 12:52 PM
I checked all these wires and they seem good.
Old Sep 6, 2010 | 12:54 PM
He must have a slightly different system, as far as I know, the GM Passlock 2 system does not have a "chip" in the keys. FWIW I did try my other key though.
Also, I think the GM cars that do have the "chip" on the key it will have a "+" on the key to identify it, mine don't.
Thanks for the reply though.
Old Sep 6, 2010 | 01:12 PM
krizlx's Avatar
this happened to me about a month ago and i just gave the car a little push while in gear and bamn turned right on...
Old Sep 6, 2010 | 02:48 PM
Everything will be at the ignition switch, and that picture is what you are looking for. However the XK06 is garbage on GM vehicles, I stopped using it completely because I had too many issues with it locking people out of the vehicle. It would learn the correct resistance initially but then for some reason send the wrong signal and cause headaches. I just went straight to the relay trick for bypassing passlock 2, hasn't failed me yet. My suggestion to you is to pull those wires from the XK module and reconnect any wires that had to be cut. Once you do this perform the 10 minute reset procedure and see if you can start the vehicle. During the reset process, the light should flash until the 10 minute mark, at which point it should come on solid, indicating that that passlock has been reset and you should be able to fire it up. Just keep an eye on the light while resetting it to see what it does.
Old Sep 7, 2010 | 12:45 PM
Ok figured it out last night and now I feel dumb, lol. It was a fuse, of course the one I DIDN'T CHECK, lol.
It was fuse #16 in this pic that screwed me:
Thanks everyone for all your help though, I really appreciate it. I guess this is why they say start with the simple stuff first. Now I guess I just need to find out WHY the fuse popped. Probably my big feet hitting some wiring under there made something come loose over time.
Edit: BTW, anyone know what "BTSI" stands for?
Old Sep 7, 2010 | 07:10 PM
Glad you got it fixed man. Gotta keep looking for a solution to mine lol. I've pulled every single fuse out and checked them. I just want to fix mine so I can install my damn turbo kit.
Old Sep 7, 2010 | 07:12 PM
bbrewbaker's Avatar
The BTSI is the Brake Transmission Shift Interlock
Old Sep 8, 2010 | 10:19 PM
Hope ya get it goin man, any leads yet?
Oh ok, thanks man.
Last edited by brandon11482; Sep 8, 2010 at 10:19 PM. Reason: Automerged Doublepost
Turbo Johnny
Feb 21, 2019 09:41 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Wind
Sep 11, 2015 06:57 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
