06 SS/SC bouncing AFR and KR
Old May 18, 2012 | 05:38 AM
robertmichaels's Avatar
So over the past few days I noticed my AFR gauge was bouncing even at idle. I will get a video this morning of the idle on a cold start up and after its warmed up. I thought it might be a dirty O2 but now when I get on the gass it piggs out at 20 untill I let off the gas, I also notice KR, But not concistant KR. Sometimes I can do a full pull from 40-100 and not see any, sometimes just getting on it to get up to speed, it will show up to 7 degrees for a split second. I will try to get a video of the KR today too..
Do I have an intake leak or possibly a bad upstream O2, No CEL yet, but I havent driven the car too much since I noticed the AFR and KR
What do you guys think??
AFR with cruise set at 80mph, you can hear and see when I get on the gass(5th no down shift)
VIDEO0035.mp4 video by robertmichaels199 - Photobucket
EDIT: mods in sig...v
Edit 2: cleaned the MAF, upstream O2 and wideband O2, sprayed starting fluid around the engine bay and found no leak, checked intake and S/C bolts
EDIT 3: Now I have a code. P1133- Heated Oxygen Sensor Insufficient Switching Sensor 1.
Also the back of the car is still getting covered in soot like its running rich (not burning any oil) It always used to do this due to a canned GM tune, the wideband would always be a little rich
Video of cold start up
VIDEO0036.mp4 video by robertmichaels199 - Photobucket
Pull showing almost no KR
VIDEO0037.mp4 video by robertmichaels199 - Photobucket
same pull after I turned around with KR (withing 30 seconds of each other)
VIDEO0039.mp4 video by robertmichaels199 - Photobucket
Old May 19, 2012 | 06:00 PM
danielhubbard2001's Avatar
Wow my 06 ss/sc is doing the same thing but the AFR is going down to 10.0 and stays there when under throttle. I have been trying to figure mine out for about two weeks now. No CEL so I don't know what is going on. Sub'd so maybe I can find out what is going on.
Old May 19, 2012 | 06:19 PM
06cobalt racer's Avatar
i would not be driving with it like that. you are WAY lean!!!! either you have an air leak after your MAF or in your exhaust.
Old May 20, 2012 | 04:54 AM
insylem's Avatar
AFR with cruise set at 80mph, you can hear and see when I get on the gass(no down shift)
Doesn't really sound like you have a problem to me. During normal operations afrs will flucutate even at idle.
The KR at random is probably "false knock" ZZP wrote an artical about that. If you do a 40-100 mph pull without KR you should be okay. Espessly if its 7 degrees for a split second. If you had real KR of 7 degrees it would take 7 seconds to return to 0, as the PCM decreases KR at a rate of about 1 degree per second.
Old May 20, 2012 | 08:02 AM
i was more talking about him going way lean, not really the false knock. wheneer he would hit the gas it would instantly go very very lean.
Old May 20, 2012 | 09:32 PM
more added to OP!
and going to change my upstream O2 in the morning
Old May 21, 2012 | 02:01 PM
insylem's Avatar
The dirty on the back of the car I think is normal. Mine gets really dirty in the back too, I think it has to do with the way the wind vortex goes arround and what not.
Old May 21, 2012 | 02:11 PM
CannonBalt's Avatar
It does not sound like anything is wrong to me, I'm going to guess you have a bad Sensor, AEM has had a lot of returns.
Old May 21, 2012 | 02:42 PM
LaserblueSS's Avatar
that much black stuff on the back of the car is not normal. doesn't that mean its usually running too rich? either that or oil. but still, that's not normal.
Old May 21, 2012 | 03:57 PM
this. when i was pig rich (gauge pegged at 10.0) it was only dirty around the tailpipe.
Old May 21, 2012 | 04:04 PM
zerosk8ter83's Avatar
what happened to the grill inserts??
Turbo Johnny
Feb 21, 2019 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
ATOMbomb
Sep 11, 2015 10:48 AM
Bluelightning
Sep 8, 2015 05:18 PM
