06 SS/SC detonation/predetonation?!
Old 03-28-2018, 10:35 AM
LogicalKaos's Avatar
Let me start off by saying I recently got this car on cheap because I helped the guy who was rebuilding the engine find parts and somewhat put the car back together. First issues when I finally took ownership of the car. P0017, wouldn’t boost over 4-5 psi, and all around really shitty stock suspension. Anyway engine went down originally due to timing chain guide breaking. The whole engine was rebuilt top to bottom. Aftermarket upgrades include 3” pulley, possibly 42# injectors, I need to investigate that, k&n typhoon intake, and catback exhaust (stock header and downpipe still)
I aligned the cam sensor housing properly and that addressed the P0017 issue. Some vacuum lines to the boost solenoid were routed wrong and that addressed the low boost issue. Now it has plenty of power, but in the higher RPMs it seems to break up. Crackle and pop and basically lose power. First thing I did was pull the plugs. They all look the same, but I’m wondering if the plugs should be a step colder considering the mods, and if that would even cause the problems I’m having. Also need to mention that no CELs are triggering. Sorry for the long post, I just really would like to figure this out so I can actually DRIVE the car. Thanks!
Old 03-28-2018, 11:30 AM
jmix's Avatar
I think once you go below stock pulley it's a good idea to run one step colder plugs. Also, what do you have them gapped at? You could be experiencing spark blowout as well.
Old 03-28-2018, 11:35 AM
user 72239's Avatar
dont really need colder plugs for anything the m62 can put out.
ZZP stage 2 kit includes new plugs gapped to .035
(4) NGK 4644 Spark Plugs (.035 gap)
try that
Old 03-29-2018, 03:15 PM
Old 03-29-2018, 03:20 PM
user 72239's Avatar
god damn. you could drive a truck through that gap on the old one lol
Old 03-29-2018, 04:34 PM
mrbelvedere's Avatar
you do need to drop 1 step on the plugs when start dropping pulleys on a m62
More_Torque_More_HP
09-09-2009 07:20 PM
06superchargedbalt
04-25-2008 08:01 AM
ItalianJoe1
Tuning
10-31-2007 06:39 PM
dervin3
03-16-2007 12:32 AM
jester
07-03-2006 10:14 PM
Quick Reply: 06 SS/SC detonation/predetonation?!
