09' Cobalt SS Brake Squeaking??
Old May 5, 2011 | 08:51 AM
MadCity SS's Avatar
i just bought a 2009 SS with only 13500 miles on it and the brakes are squeaking already?? does anyone else have this problem? the lady i bought it from took it in at 5ooo miles to see what was wrong and got a letter from Gm saying this is normal for the brembo brakes... and should not be replaced under warrenty... just seems a brand new car shouldnt have brake problems... so just seeing what others thoughts on this are. thanks
Old May 5, 2011 | 08:58 AM
Grishbok's Avatar
There is a thread about it here: https://www.cobaltss.net/forums/08-1...recall-187787/
Old May 5, 2011 | 09:23 AM
RoadconeTuning's Avatar
has anyone tried to see if the solstice rear caliper slide pin with the dust boot would fit on our rear brakes? its the same stuff right?
Old May 7, 2011 | 12:48 AM
Malaclypse's Avatar
He's talking about the front brakes. Not a premature wear issue.. just a noise issue.
Yes, its normal. I even talked to my service manager and shop foreman. Even though I'm a dealer employee they can't replace the pads or do anything because of that bulletin.
I have a temporary fix. This stopped the noise for a few weeks... maybe a month. I removed both sets of front pads and removed the dust from the beveled edge of the pads. After I put them back in they were quiet again.
I've just learned to live with it.
Old May 7, 2011 | 12:49 AM
Dart_SI's Avatar
its just the nature of the brakes. these cars arent made for comfort.
Old May 7, 2011 | 09:49 AM
BlueStang's Avatar
Join the club of shitty brakes
Old May 7, 2011 | 09:54 AM
swazzees's Avatar
its actually very simple.
you need to set the brakes, I do it every spring..
basicallt if you driv elike a sally and use the brakes very sparingly they will get a glaze on them, hence the swkeeeeeks and stuff when you stop.
go out on a very non busy road and hammer the brakes on from like 50 or so, do it like 10 times, and your good...they will be quiet as they can be....make sure you use the brakes pretty hard.
Cobalt08LS
Jun 19, 2016 07:29 PM
ashalle2
Sep 17, 2015 04:58 PM
calo247
Sep 8, 2015 12:29 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
